Sponsored by The Tire Rack
Old 07-28-2013, 04:54 PM   #1
magicchef
My Ride: 2001 330 Csi
Front end wobble
I have a 2001 330 Ci. I switched to good quality 18-inch wheels, and after maybe a year the wheels-and steering wheel-started to wobble. After buying new tires-but inexpensive ones-replacing struts and lower control arms, it still wobbles! I've been told 18" wheels don't work on my car, although lots of E46ers are using 18s and 19s. I've also been told that only Michelins or other high-quality tires work well. Has anyone had this experience? Thanks
magicchef is offline   Reply With Quote
Old 07-28-2013, 05:17 PM   #2
Llink78
My Ride: 2002 330i
Your fine with the 18" have them re balanced. Maybe a wheel weight fell off. How old are your Fcabs?
Llink78 is offline   Reply With Quote
Old 07-28-2013, 05:22 PM   #3
CharlzO
My Ride: 2000 328ci
Check the balance, maybe a weight fell off one? Wheel bearings? I assume the bushings were changed along with the control arms? It is also possible that there is a defect in a tire. Try rotating your tires around, see if the wobble seems to follow the wheel?
CharlzO is offline   Reply With Quote
Old 07-29-2013, 01:17 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
I would recommend Road Force Balancing your tires, if they have not been Road Forced already, and checking your bushings.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 07-29-2013, 04:25 PM   #5
Richard_e46
My Ride: 330i
Front end wobble
I think I have the same prob! But I don't think the wheels have anything to do with the wobbling! I changed the struts like 3 mounts ago but I had sport suspension but installed the cheap non sport struts ! And now I think one of them is blown! Im guessing thats Causing the wobbling !
Richard_e46 is offline   Reply With Quote
Old 07-30-2013, 12:33 AM   #6
magicchef
Balanced the tires again. Mechanic said one was out of 'true' from right to left, not fixable. Other out of round a little, possibly fixable. I sold those tires and put on Michelin Pilots today. Tracking is 95% improved, but still a trace of wobbling at about 60 mph and above. (Had replaced control arm bushings also a few weeks ago.) Struts and lower control arms replaced. Is there anything else that can produce wobbling-even a little?
Old 08-20-2013, 12:04 AM   #7
magicchef
Update on front end wobble: Slight wobble is still there at 60 mph and above. Had the front wheels switched to the rear, and rear to front today, and balanced. New Michelins stayed on the front. Still some wobble at 60+, though very little. At America's Tire Warehouse one employee said that some cars have "wheel bearing rings, made out of plastic", that keep the wheel tight when attached, "especially on BMWs." I have never heard of these. Anyone else? (Again: new struts, new control arms and bushings, new Michelin Pilots.) I appreciate any input.
Old 08-20-2013, 11:20 AM   #8
My Ride: 2016 Lexus
he said that cause you're likely riding on crap wheels. those "rings" aren't necessary but on wheels that aren't for your car. trash them immediately
Old 08-20-2013, 11:24 AM   #9
TnT817
My Ride: 01 330ci
Front end wobble
I think that's a little harsh.. Plenty of people run hub centric rings with no problems.
TnT817 is offline   Reply With Quote
Old 08-20-2013, 12:39 PM   #10
VMRWheels
VMRWheels's Avatar
+1
Nothing wrong with hubrings. If a manufacturer is able to offer various sizes for one bolt pattern across many platforms, hubrings make more sense. For instance, our wheels are hubcentric to BMW, but not for the Pontiac G8 and GTO, Acura TL, etc. We still have customers in those cars, and all they need are some hubrings to keep things centered.
From my experience, it's much more common with Japanese cars though, as a lot of manufacturers share the 5x114.3 bolt pattern.
Old 08-20-2013, 01:34 PM   #11
magicchef
I should have said I would appreciate most input. Thanks, I'll look into hub rings.
Old 08-20-2013, 05:59 PM   #12
My Ride: 2016 Lexus
Originally Posted by VMRWheels View Post
+1
Nobody said there's anything wrong with hub rings.
Hub rings are required on aftermarket wheels or wheels that aren't made for the car.
OP has vibrations and can't get rid of them.
Many aftermarket wheels are junk.
OP did not say what specific model of wheels he has, nor did he say if they were damaged/used/etc.
Old 08-20-2013, 06:34 PM   #13
VMRWheels
VMRWheels's Avatar
Well, it sounded like you were sort of implying that any wheel that is not hubcentric is junk, not meant for the car, and should be tossed. If I misinterpreted what you were saying, I apologize.
Old 08-20-2013, 08:08 PM   #14
magicchef
Not at all referring to what you said, Kevin, if your last comment was to me. It's a learning process, too. Btw, are hub rings specific to the car, or to the brand of wheels? Thanks.
Old 08-22-2013, 12:10 AM   #15
My Ride: 2016 Lexus
I was implying that any shop that installed a wheel without hub rings that REQUIRED hub rings is probably selling junk wheels. Any quality wheel will be installed by a quality installer/retailer and any quality installer would know to install hub rings on a wheel that requires them. Even if the wheels aren't junk, obviously a de-centered wheel would cause nasty vibrations. I don't know the OP or his situation but generally I don't put it past people to install junk wheels on their car then complain of vibration problems later. This is over the internet where I can't see the OP's car or the quality of installation. Would help to have more info.
Hub rings center the wheel. You need whatever size required to center your wheel on the hub. BMW wheels or wheels fitted for your particular application don't need hub rings because the wheel naturally centers itself.
Old 08-22-2013, 12:31 AM   #16
magicchef
Thanks, Mango, I'm on it!
Old 08-31-2013, 11:55 AM   #17
magicchef
The hub rings did the trick! The wheels run solid and smooth. Hooray! Thanks for everyone's input.
