Sponsored by BimmerWorld
Old 08-09-2013, 06:27 AM   #1
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
Lightbulb If you're curious what a non-M looks like with M3 lowering springs, stay tuned...
I just ordered a set of Tein S-Tech springs for the M3 - I own a 328Ci.
Few reasons why I chose these springs:
-Tein actually lists their spring rates
-M3 rates are a little higher than non-M
-Spring perches are the same between M and non-M
I know pretty much every advertisement says "M3 ONLY!!" or "SPORT SUSPENSION ONLY!!" etc etc. Well this thread proves that they are a lot more similar than any advertisement leads you to believe.
So, if anyone wants to know what happens when you put springs that are "M3 ONLY!!" in a non-M, keep an eye on this thread.
No, I haven't ordered shocks yet. If this little experiment proves unsuccessful, I'm going with some nice coilovers.
Cavi Mike is offline   Reply With Quote
Old 08-09-2013, 12:47 PM   #2
Llink78
My Ride: 2002 330i
You will just sit a little higher so it won't lower as much. The m3 only compensates for the extra weight a M has. So putting even stock or aftermarket M suspention will have you sitting a little high.
Llink78 is offline   Reply With Quote
Old 08-09-2013, 11:57 PM   #3
Cavi Mike
Banned User
My Ride: 2000 328Ci
Reasonable theory - until you factor in the convertible. Non-M convertible weighs more (far more) than the M3 coupe. You also have to subtract added unsprung weight of the much larger, heavier wheel/tire combination of the M3.
Clearly the weight is not a factor.
Old 08-10-2013, 12:10 AM   #4
Llink78
My Ride: 2002 330i
When you get this installed measure. I bet you will be higher than you think.
Old 08-13-2013, 09:41 PM   #5
Cavi Mike
Banned User
My Ride: 2000 328Ci
Springs are here. Weather is looking good all week, I should get to it Thursday or Friday morning.
Old 08-16-2013, 12:34 PM   #6
Cavi Mike
Banned User
My Ride: 2000 328Ci
Here's where the snag occurs in the front. The diameter of the M3 spring is too small to fit in the hat. The non-M spring is larger on one end and fits a specific way, the M3 spring is identical on either end. So, no, the M3 spring will not fit right out of the box.
Unfortunately I won't be able to get any comparisons in ride-height in the front. I'm still installing these springs - albeit with some modification - but this modification is going to net me 1/2" or more drop in the front.
Stay tuned for the rear.
Old 08-16-2013, 12:51 PM   #7
Cavi Mike
Banned User
My Ride: 2000 328Ci
And that is how you make an M3 spring fit in a non-M hat.
Old 08-16-2013, 01:24 PM   #8
My Ride: Lexus
So modification is necessary to fit M3 springs. Good to know.
Old 08-16-2013, 05:47 PM   #9
Cavi Mike
Banned User
My Ride: 2000 328Ci
Fronts have been done only.
Before:
After:
Old 08-16-2013, 05:48 PM   #10
Cavi Mike
Banned User
My Ride: 2000 328Ci
Don't mind the red calipers - that's getting de-riced next. Anyone want some faux-M3 mirrors? hahaha
Old 08-16-2013, 05:56 PM   #11
Snik
Snik's Avatar
My Ride: IR M3 Vert.
My buddy zx5rider took tein coilovers off his 330 and put them on his M3.
Only the top mounts up front are different it seems.
Do you ride a sportbike?
Old 08-16-2013, 06:06 PM   #12
Llink78
My Ride: 2002 330i
Wow congrats man. So the front would be a 1/2 inch higher if you didn't cut?
Old 08-16-2013, 06:56 PM   #13
Cavi Mike
Banned User
My Ride: 2000 328Ci
At first I thought I was gonna need to cut a whole coil, but half a coil was enough, so I doubt it's even 1/2" difference. Prolly the difference between running spring pads or not.
Old 08-16-2013, 07:25 PM   #14
mkodama
mkodama's Avatar
Hmm, so to fit M3 springs to non-M struts, you need to either cut the springs or buy the M3 strut and strut mount combo. I never tested that or tried that out when I made my thread.
Good to know they can fit and don't raise the front of the car significantly.
Old 08-22-2013, 09:18 AM   #15
Cavi Mike
Banned User
My Ride: 2000 328Ci
They didn't raise the car, they lowered the front at least 1-1/2" but I just did the back and the drop is barely noticeable, maybe 1/2". Over time I'm sure it will settle a little bit but they definitely lowered the car, not raise it.
All 4 Tein M3 springs in, with all spring pads as well.
Bilstein short-strokes are next.
Old 08-24-2013, 08:59 PM   #16
sedanpowersc
My Ride: 330i 5 speed
I feel like my car sits lower than that on non-m Tein S Techs
| BB Gen 3 Headers | Cosmos Racing V2 CAI | Muffler Delete | RE Underdrive Pulleys |
| 3.46 Diff | Tein S-Tech | Bilstein Sports | Hawk HPS | ASA AR1 | 35% Tint |
sedanpowersc is offline   Reply With Quote
Old 08-25-2013, 01:25 AM   #17
Cavi Mike
Banned User
My Ride: 2000 328Ci
That's very possible. I explained in the OP why I went with the M3 version over the non-M.
Old 08-27-2013, 04:53 AM   #18
MJM Distributing
Past Site Sponsor
My Ride: TOO MANY TO LIST
Send a message via AIM to MJM Distributing Send a message via Yahoo to MJM Distributing
Drop it like it's hot. Very nice.
MJM Distributing is offline   Reply With Quote
Old 10-02-2013, 11:50 AM   #19
Xtiananything
My Ride: '01 330i Mtech1
Now what if i was doing the absolute opposite of what you're doing... I have a non-m sedan lowered on Tein-S tech springs with blown out non m shocks/struts (my car sits really low cause of this). From research, I can use m3 rear shocks as a direct fitment into a non-m. How would i go about doing the front? is it a direct swap? I have seen some people saying that i can use the m3 front suspension, i would just need to change out the top hats as well.
Xtiananything is offline   Reply With Quote
