Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 08-25-2013, 03:43 AM   #1
lowrider
My Ride: modified 323Ci
Send a message via AIM to lowrider
Arrow ||DIY|| How to Rebuild a 5-Speed Transmission -- THE REAL DEAL
Let's start off with a little background. 7 years ago I bought my 2000 323ci used with 124k miles on the clock. I drove straight to the doctor who informed me I had the "mod-bug" and that there was no cure.
All joking aside, I have absolutely loved every minute of owning and wrenching on my BMW. For a while I even ran a small business through E46Fanatics where I worked on fellow fanatics' cars. But, when my car reached (well almost) the 200k mile mark, I decided it was time for some major maintenance. The car was leaking from almost every place possible which had created a thick film of sludge over the entire engine and transmission as well as most of the underbody.
On July 4, 2013 I pulled the engine and transmission out and began to address problem areas. I had never intended on rebuilding the transmission (was crossing my fingers that it was OK) but sadly there was significant axial play in the shafts which indicated bad bearings. I will soon post about my entire rebuild, but this thread should serve to detail and demystify how to disassemble/reassemble a 5-speed transmission (Getrag S5D-250G)
I know I took plenty of photos of the disassembly, but for the life of me I cannot find them. The photos below should help though if you run them in reverse. Here is a link to the ONLY information I was able to find on how to get a Getrag apart (http://www.bmw-m50.com/transmission/getrag-250g/)
DISASSEMBLY
The Bentley manual should be able to get you this far.
The liberated and filthy engine/trans:
Disassembly steps that I don't have pictures of:
Remove the 9 bolts holding the two halves together (13mm)
Remove output shaft flange (30mm, use impact)
Remove output shaft seal (screw driver and pliers or seal puller)
Remove selector shaft seal (screw driver and pliers or seal puller)
Remove reverse gear bolt on bell housing side (13mm socket, directly below where slave cylinder mounts)
Remove reverse switch (19mm)
Remove throwout bearing sleeve (10mm, inside bell housing)
Remove input shaft seal (screw driver and pliers or seal puller)
Remove snap ring and support ring (my snap ring was not tool removable so I torched it and bent it until it came out)
I then made a tool out of pipe material to separate the two halves. I machined the pipe flange to pick up the bolt circle inside the bell housing. Connect a three jaw puller and you should be able to separate the two halves. BE CAREFUL!!! There is a pin that must be removed after you start pushing the two halves apart, but before you get too far.
To remove the main shaft and counter shaft (guts) of the transmission, simply turn the casing over so that you can set the case flat inside a press. Don't forget to remove all the detent balls and pins (see link above). Then press on the output shaft until it rains gears and shafts (prepare a soft landing for the parts).
From here I put everything into a parts washer for a couple days. I was surprised to find that my 5th gear synchronizer ring was almost completely destroyed. Don't know how I was getting into 5th, but by then you are almost turning at engine speed anyways.
ASSEMBLY
After a month waiting on parts to come in from Germany, finally ready to go!
I managed to lose the detent balls/plates/springs for my 1st/2nd gear selector so I ordered new parts from BMW, but they wont sell you the springs...you have to buy the whole gear selector for some ungodly expensive cost. So, if you need replacement springs check out www.centryspring.com (P/N: FF-2).
Press in the input shaft bearing
Press in the output shaft bearing
Photobucket
Picture courtesy of EAS
lowrider is offline   Reply With Quote
Old 08-25-2013, 03:44 AM   #2
lowrider
Install new 5th/Reverse resistance springs (long, softer one on top, short, stiffer one on bottom). Point reliefs toward each other.
Install input shaft bearing retainer (7 ft-lb)
Install arm and wheel
Assemble pivot, spring, and sleeve
Install the assembly (pivot bolts in from front and top, 7 ft-lb)
Install output shaft bearing retainer (7 ft-lb)
Install new 5th gear synchro (Green grease is lubricant that will help with break-in that dissolves in transmission fluid and also helps to keep components in place during assembly. YOU WILL NEED THIS STUFF, it is called "Assemblee Goo")
Install counter shaft roller cage
Mate the main and counter shaft and install all 3 gear selector rods. You will also need to insert the detent pin into the middle gear selector rod and use assemblee goo to keep in place. (I tried to be clever and zip tie it all together but it turned out that it was not necessary)
Install the assembly into the rear case. Align the counter shaft bearing and all gear selector shafts.
You will need to drop the counter shaft bearing retainer into the transmission and fish it into place because it bolts in from the outside (Patience Required!)
Bolt in the counter shaft bearing retainer (7 ft-lb)
Photobucket
Old 08-25-2013, 03:45 AM   #3
lowrider
Install detent ball/pins/springs
Install reverse gear (Tighten by ratchet until fairly snug). I also chose to apply a RTV to the seal surface.
A picture is missing here, but before you slide the bell housing back on, you need to insert one more short shaft (~5" long) into the right hand side of the rear case. Place the lever into the groove on the short shaft and the groove on the 5th/Reverse gear selector shaft. Use assemblee goo to hold it into place.
Turned a special tool for pressing the two halves back together. This ensures that only the input shaft bearing is pressed against and NOT the bell housing.
Press the main shaft through the input shaft bearing until the hole in the pivot piece and lever line up. This will take some "fiddling" to get right. When the holes line up, insert the pivot pin.
Bolt cases together (no torque value given, but I went to 17 ft-lb).
Reinstall the reverse switch (19mm, 13 ft-lb). Bolt in the reverse gear on the bell housing side, again there is no given torque value, so just snug it up (picture missing).
Install input shaft bearing support ring and snap ring
Install new input shaft seal (Apply coating of transmission fluid). Used special tool from before.
Install throwout bearing sleeve (7 ft-lb)
Install output shaft seal (Apply coating of transmission fluid). Can be drawn in using output flange and nut.
Photobucket
Old 08-25-2013, 03:45 AM   #4
lowrider
Tighten output flange nut, apply Loctite to threads (140 ft-lb, then break free, then 89 ft-lb).
Install selector shaft seal (Apply coating of transmission fluid).
Install shift rod joint
Fill her up with fluid, I chose Royal Purple 75w-90 (Plug, 37 ft-lb)
ALL FINISHED
Video my brother took of me running through the gears:
All in all, I would rate this as a 10 out of 10 for difficulty. I definitely want to thank my brothers for helping me out even when we got extremely frustrated at the trans. The job required many expensive and special tools to complete. This job took me about 30 hours to complete, although now I feel like I could do it in 1/3 the time. I probably had to split the cases close to 10 times before I figured out how to do it just right. I spent about $500-600 to rebuild a transmission that would have cost me more than $2000 if I sent it in, so I am still ahead by a lot.
Hope you enjoyed looking and that I might have helped in some way if you are considering this job yourself. Will offer tool rental if anyone wants.
Photobucket
Old 08-25-2013, 06:25 AM   #5
jwm5
My Ride: station wagon
DIY Extreme good work. how does it feel/shift back in the car?
jwm5 is offline   Reply With Quote
Old 08-25-2013, 01:36 PM   #6
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Nice work. I can appreciate the time and dedication that went into this. The tools make all the difference too. Job well done!
/// MODS
Old 08-25-2013, 03:46 PM   #7
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Holy crap, I am impressed!
Chris
dreamdrivedrift is offline   Reply With Quote
Old 08-25-2013, 06:42 PM   #8
BDUB328I
My Ride: bmw 328i S54 sedan (
Nice write up
BDUB328I is offline   Reply With Quote
Old 08-25-2013, 07:27 PM   #9
NurburgringBMW
My Ride: 2001 330i
Re: ||DIY|| How to Rebuild a 5-Speed Transmission -- THE REAL DEAL
Amazing work!
Sent from my Sony Tablet S using BimmerApp mobile app
NurburgringBMW is offline   Reply With Quote
Old 08-25-2013, 11:11 PM   #10
lowrider
Small update: Machined a new clutch lever pivot pin out of aluminum to replace the factory plastic one.
New clutch, pressure plate, flywheel, SSK, and SS clutch line in the mail. Should be able to drop the engine/trans in this weekend. Back on the road soon
Photobucket
Old 08-26-2013, 11:40 PM   #11
TitaniumCranium
/// Limitless
You should ask mods if they can relocate this thread to "General E46" or DIY. It may not get the traffic it deserves in Showroom.
/// MODS
Old 08-27-2013, 12:38 AM   #12
lowrider
Looks like that got handled for me. But you're right, I have noticed a decline in activity on this forum. Not nearly what it used to be 3 or 4 years ago. I guess everybody is driving e90's now.
Clutch/flywheel should be here tomorrow!
Photobucket
Old 08-27-2013, 12:52 AM   #13
Aedion
My Ride: 2001 330CI 5spd
wow this was absolutely amazing.
Aedion is offline   Reply With Quote
Old 08-28-2013, 06:44 PM   #14
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
My Ride: 328i, M3, 525iT
Very nice job, it compliments my 5L40E DIY nicely. Now we just need another good ZF and we would be all set! All but the damn Getrag 226 M3 6 speed that they wont sell parts for.
ddaniel1 is offline   Reply With Quote
Old 08-28-2013, 07:53 PM   #15
lowrider
Thanks!
Yea I saw your DIY, holy crap what a lot of work for an auto. You did a great job of identifying all the details
You can't get Getrag 226 stuff from Germany through getBMWparts?
Photobucket
Old 08-28-2013, 08:10 PM   #16
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
Originally Posted by lowrider View Post
Thanks!
That is what I have read, no parts sold to the public outside of some external stuff, I hope I am wrong, I have one that may need rebuilt.
Old 08-28-2013, 08:40 PM   #17
lowrider
Wow ya, checked realoem and there is nothing there besides the stuff you said. Looks like I got lucky then.
Photobucket
Old 08-28-2013, 09:24 PM   #18
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
I am trying a new quality shifter this weekend, hopefully it cures an intermittent not wanting to go into gear problem, if I have to replace the tranny I will definitely attempt the rebuild.
Old 08-29-2013, 07:42 AM   #19
philliplong
My Ride: 2002 325CI
Wow this is an ultimate DIY.
Sent from my SGH-I317 using BimmerApp mobile app
philliplong is offline   Reply With Quote
Old 08-30-2013, 02:22 AM   #20
lowrider
Small update: received the clutch kit from gripforce (trying them out). Waiting on orders from ECS and UUC to finish the car.
Went with the carbon/kevlar option:
Not cleaned up yet
Pilot bearing puller rental from AutoZone made the job a breeze
The new pilot bearing can be installed with a dead-blow hammer to start
Then use a socket or equivalent push rod to land it on the shoulder
Use the supplied bolts, apply some Loctite, torque to 80 ft-lbs (was getting conflicting values of 77 and 85 ft-lbs from online sources so I chose 80. No torque value given in the Bentley manual)
SMFW-FTW!
More to come later...
Photobucket
