Old 08-28-2013, 09:26 AM   #1
StrdCloud
My Ride: 323
Question about Steptronic.
Hi all, ive been wondering, since the E36 manuals fit into the E46 cars, is it true that my Steptronic would fit into a E36??
My brother has a E36 and he is thinking of installing my Steptronic into his car.
Has anyone ever succeeded in doing so or knows if this is possible?
Sent from my PadFone using BimmerApp mobile app
StrdCloud is offline   Reply With Quote
Old 08-28-2013, 07:42 PM   #2
jdjg
My Ride: e39, m52tub30
no, since you have to install the transmission DME (aka EGS) also, you need in your cluster the 1 2 3 4 5 for each gear... also you need to match your EGS with your ms41 DME, and I think, this is impossible....
manual transmissions are straight bolt
jdjg is offline   Reply With Quote
Old 08-28-2013, 08:03 PM   #3
StrdCloud
My Ride: 323
Hmm from my understanding, the gearbox is controlled by the EGS only no?
Cluster for 1 2 3 4 5? I'm not sure what you are referring to. can you please elaborate?
here's my chasis EE93500
Anyone could give some advice?
Old 08-28-2013, 11:26 PM   #4
jdjg
when you use the steptronic, in your cluster, show in what gear you are,
1 gear, 2 gear, etc.....
Old 08-29-2013, 02:16 AM   #5
daniel_f.
My Ride: 330iC
well, its controlled by the egs, but egs gets it signals via can-bus, e.g. vehicle speed.
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 08-29-2013, 10:29 AM   #6
StrdCloud
My Ride: 323
so will the GB work even if it doesn't display?
Old 08-29-2013, 08:05 PM   #7
jdjg
no
Old 08-29-2013, 08:20 PM   #8
StrdCloud
My Ride: 323
Ic thanks.
Guess I have to give up that idea
Old 08-30-2013, 03:35 AM   #9
daniel_f.
My Ride: 330iC
I havent tried, but i would say it will work. the problem is, how can you tell in which gear the gearbox is?
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 08-30-2013, 12:35 PM   #10
StrdCloud
My Ride: 323
Re: Question about Steptronic.
Cant tell from the original E36 anyway lol
Old 08-30-2013, 06:57 PM   #11
lszlszx
My Ride: 1.8T, XC70
What's the advantage of having a steptronic in an E36? It's just an autobox.
They're slow to shift, too.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 08-31-2013, 02:37 AM   #12
daniel_f.
My Ride: 330iC
Have you driven a ZF5HP19 with short diff and alpina software?
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 08-31-2013, 10:19 AM   #13
StrdCloud
My Ride: 323
My ZF5HP19 shifts very fast and its pretty comfortable for my brother to drive.
I'm swapping in a manual and don't really wanna buy another zf5hp18 for my bro's e36. Thus I am thinking of how I could fit the zf5hp19 in.
