Old 09-01-2013, 10:10 PM   #21
Imanewbie
My Ride: is my crack.
Question about modding dme
Originally Posted by daniel_f. View Post
Why? What should be that different compared to MS43 so you couldn´t tune it correctly?
I'm not saying you can't tune it, you yourself are not going to tune it.
Imanewbie is offline   Reply With Quote
Old 09-02-2013, 01:32 AM   #22
StrdCloud
My Ride: 323
Re: Question about modding dme
Well, here where I am, there are no tuners for my car. Engine swap is not possible due to yearly inspection. Only choice I have left is turbocharging it and figure out the tuning myself.
There are motec and unichip tuners here but they charge a bomb and aren't actually professionally trained.
I am hoping to find a PnP module. Whether it replaces the ECU or chips the ECU are both fine by me. Any recommendations?
Sent from my PadFone using BimmerApp mobile app
StrdCloud is offline   Reply With Quote
Old 09-02-2013, 11:40 AM   #23
daniel_f.
My Ride: 330iC
Well, i donīt get it... please tell me a explicit reason to why one canīt tune a ms42/43 to adapt for a charger?
i even uploaded 2 files for supercharged MS43 units!
Iīm currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 09-02-2013, 01:23 PM   #24
Imanewbie
You don't have the skills to, unless your a underground programming wizard. You don't simply just change ratios and timings, you change the code, to do that you have to know how to write the computer code.
Old 09-02-2013, 01:30 PM   #25
Imanewbie
Here is what I would do, find someone who can "tune" your dme. There is a small handful of people in this country that can do it, when you talk to them ask them how much boost/ everything you can do. Then ship your car to them, get a boat, fill it with cash, and pull the boat there with you.
Old 09-02-2013, 01:43 PM   #26
Imanewbie
The best BMW engine to boost is the m30 with megasquirt, put that in a e30 and you have a crazy fast machine for 1/3 the cost. Type in m30 in YouTube and you will see. Don't forget in trying to help you and these are my opinions, you don't have to listen to them.
Old 09-02-2013, 03:01 PM   #27
daniel_f.
My Ride: 330iC
Well, even for me, i donīt listen to you One doesnīt need to disassemble the code of th C167CR processor, its plain simple with the right software perhaps you need at least a wideband lambda, but thats obvious.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 09-02-2013, 03:42 PM   #28
Imanewbie
I wish the best of luck to you, perhaps you can update us after you do this.
Old 09-02-2013, 06:41 PM   #29
StrdCloud
My Ride: 323
How do you upload the files?
What software do you use??
What hardwares are required??
Old 09-03-2013, 01:14 AM   #30
daniel_f.
My Ride: 330iC
its all in threads here at this forums
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 09-03-2013, 07:59 AM   #31
StrdCloud
My Ride: 323
How do I find it??
Old 09-03-2013, 08:32 AM   #32
daniel_f.
My Ride: 330iC
beeing not too lazy, you could have a search.
http://www.e46fanatics.com/forum/search.php
otherwise you could spend one hour and look through some threads which seem promising to find good answers.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 09-03-2013, 02:24 PM   #33
HakenTT
My Ride: 323i with S54
Daniel is German he is never lazy, germans get up and work, nothing like greeks.
HakenTT is offline   Reply With Quote
