Old 07-27-2013, 03:49 PM   #101
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I'll start by saying I don't know.
I'd remove one to see if it's a "dead end" bolt hole, or does that hole go through & into the exhaust. If it's a dead end hole & goes nowhere, well then remove them. If it does go through, cap them with an Allen Head Screw Plug so it's flush when it's screwed in.
SUMMIT POINT WV 1:24:229 SCCA
Old 07-27-2013, 04:48 PM   #102
zaharias
My Ride: M3 E46 6MT 3/2005
Thanks for the reply my friend..
There are 2 holes in every pipe (6) and each pipe has only 1 bolt, same at all 6..
I was thinking of doing what you suggest.. but decided to ask first if somebody knows..
I will take pics tomorrow and update the thread..
zaharias is offline   Reply With Quote
Old 07-28-2013, 03:46 AM   #103
zaharias
Some better pics..
Old 07-28-2013, 07:45 AM   #104
zaharias
Just removed one and it's not a "dead end" bolt.. you can see the inside of the exhaust..
Old 07-28-2013, 08:58 AM   #105
zaharias
My car is LHD.. BUT the engine i have came from a UK RHD 330Ci..
So my OEM RHD headers right know look like these..
http://bmwfans.info/parts/catalog/E4...with_catalyst/ which means that i have 8 studs (RHD).. instead of 12 (LHD) per flange..
Should i join up the flanges of the E36 M3 headers? Or will i be ok if i put it as it is? Don't want to go there twice, i don't want to mess with exhaust leak..
Old 07-31-2013, 08:19 AM   #106
dableds
My Ride: 328
Originally Posted by Alun1976 View Post
I've fitted the s50 headers to my M54b30 engine, they fitted with very little modification. I will provide full details of what I did if anyone would like to do the same. Just very busy at the moment.
Al
still waiting...
dableds is offline   Reply With Quote
Old 07-31-2013, 12:13 PM   #107
zaharias
No S50 headers for me..
Originally Posted by zaharias View Post
I ended up putting the M52 headers cause the S50 (M3 E36) needed alot of modifications to fit..
While test fitment.. the 6th cyl pipe was touching the gearbox, the 3rd was touching the engine block and of course it needed cut/weld at the end, to mate with the OEM M54 cat back exhaust..
Old 08-04-2013, 06:44 AM   #108
zaharias
M52 headers to M54
M52 Headers with magnaflow 200 cell cats (no cell), oem resonator and custom muffler..
I will make a video when i find some free time..
Old 08-05-2013, 02:10 AM   #109
reggid
My Ride: .
what size primary and secondary OD's?
reggid is offline   Reply With Quote
Old 08-06-2013, 12:55 PM   #110
zaharias
OEM M52 headers..
Primary is where the pipes start just after the flange that bolts on the head?
If yes.. i think it was around 40+ mm OD.. i will see if i can measure and tell you exactly..
After the primary it's all the way dual 2" (51mm) OD..
Old 08-06-2013, 01:18 PM   #111
zaharias
Old 08-07-2013, 03:09 AM   #112
reggid
My Ride: .
yes, the OD after the flange, if you measure do it on the straight part not at a bend as it always a little smaller on the bend
Old 08-12-2013, 10:28 AM   #113
zaharias
Old 08-23-2013, 11:04 AM   #114
murph1379
My Ride: 2006 M3
Euro S50B32 Headers on M52TU/M54 Engine
Finished the install of the BMP E36 shorty style headers last night. They don't fit quite like stock, and so my down pipe/merge has an exhaust leak, and it was a little tricky getting them onto the head studs.
On the plus side, the low-rpm bog I was getting with the S52 headers is gone, and it should be a good longer tube solution for the E46 non-M.
The downside is that they cost $500, don't fit as well as you'd expect at that price, and still need custom down pipes.
murph1379 is offline   Reply With Quote
Old 08-25-2013, 01:16 PM   #115
zaharias
Old 09-04-2013, 09:14 PM   #116
sephyroth1
My Ride: 330ci
headers for 330ci (RHD)
I'm thinking about buying these headers:
http://www.ebay.com/itm/92-99-BMW-32...e0ff10&vxp=mtr
or these ones:
http://www.ebay.com/itm/200935867692...84.m1423.l2649
but I've heard they both fit into an e46 330ci (RHD)
can someone help me with any details in regards to these headers? I would really appreciate it.
sephyroth1 is offline   Reply With Quote
Old 09-25-2013, 12:10 PM   #117
murph1379
My Ride: 2006 M3
Not sure about RHD, they both should bolt up to the head, just a matter of what you need to do from there.
Both will likely require custom downpipes.
Old 10-24-2013, 05:00 AM   #118
Race
My Ride: BMW
My first post here. I had to register because this is one of the only places where I found something about S50 headers on M54 engine. I'm changing the engine in my LHD E36 race car from M50 to M54. I already have the M54B30 engine and thinking now about the headers. I have a set of S50 headers, but they do not fit nicely with the engine block. Cylinder #1 pipe hits the engine block even though I use a 10mm spacer between header flange and cylinder head.
Does anyone have more details how the S50 headers should be fitted to M54?
Race is offline   Reply With Quote
Old 10-27-2013, 12:44 PM   #119
Race
My Ride: BMW
Tried with another set of headers and same problem exists. I tried also with 5-speed ZF transmission used in e36 328i/M3 (Euro). Pipe #6 hits the transmission. It should fit with a 0.4-0.5" thick spacer and two gaskets.
Old 10-27-2013, 12:52 PM   #120
zaharias
That's why i went with the M52 headers at my 330Ci..
I believe you can make them fit cause the engine is down and you can work it better (spacer)..
