E46 Xi Forum
Old 09-05-2013, 10:32 AM   #1
Zac 330i
My Ride: 330i individual
transmission problem
Hi
There please advice I have a steptronic gearbox for my e46 and it is showing the transmission sighn. 2days ago oil started to leak out the gear box what could it be? is my gearbox broken down?,
Regards
Z.P Morodi
Zac 330i is offline   Reply With Quote
Old 09-05-2013, 10:56 AM   #2
SamDoe1
My Ride: 4cyl of fury
Where's it leaking from? Is it the actual transmission or the differential?
Old 09-05-2013, 11:07 AM   #3
Zac 330i
Re: transmission problem
Hi sam
it's leaking bwtween the gearbox and engine. after the leak the car started to drive hard in a way that the raves went up to 7000.,I took off the manifold to see for oil leaks on the block and head but I found no oil leaks there
Regards
Z.P Morodi
Old 09-05-2013, 11:19 AM   #4
SamDoe1
That sounds like a rear main seal leak. Is the fluid brown or reddish? Stop driving it immediately until you get the leak fixed.
Old 09-05-2013, 11:33 AM   #5
Zac 330i
The oil is brownish. but what about the sign showing showing does that mean I need a new gearbox or repairing the seal will be the problem solving?
Regards
Z.P Morodi
Old 09-05-2013, 03:34 PM   #6
SamDoe1
If the oil is brownish then it's likely not ATF unless you've never changed the transmission fluid. ATF is naturally red so as to differentiate itself from engine oil.
The only thing between the engine and transmission that can leak (unless you have a cracked block) is the rear main seal which seals the output shaft to the engine block and oil pan.
