Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 08-25-2013, 02:44 AM   #1
jamesT335I
My Ride: 2009 E-92 335i
Silence is a virtue
Friends dont let friends fire unsuppressed. sent from my GT-I9300 using BimmerApp mobile app
ID:	523523   Click image for larger version
ID:	523524   Click image for larger version
jamesT335I is offline   Reply With Quote
Old 08-26-2013, 12:56 AM   #2
david05111
My Ride: drei hundert dreißig
Nice!
"You'll Never Walk Alone"
"Psycho Murican" -- beeemerdude of Canada
david05111 is offline   Reply With Quote
Old 08-26-2013, 01:51 AM   #3
tailo
My Ride: 02 330I
The m1's a airsoft, AO marks on the right hand side are not marked as far back below the rear sight as that one is. Could possibly be a semi auto SBR (as I'm not accustom with there markings) but she dose not look quite right to me. Never mind 90K+ in machine guns laying on the floor with socks in the photos and junk on the bed.
That's a HK G36KE also? Don't look right...... Selector cut on EBR stock is not as deep as I've seen them before, atleast on the sages. Never mind the markings on the pistol silencer look a lot like the "special forces" fake cans that I see around a lot.
I don't know man, hard to tell with bad photos but these aint looking to good.
tailo is offline   Reply With Quote
Old 09-08-2013, 05:27 PM   #4
tailo
My Ride: 02 330I
Airsoft....
Old 09-09-2013, 02:37 AM   #5
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
If the G36 is an actual gun, it's likely not a G36. Probably an SL8 conversion.
Also trying to figure out why we see shiny metal in the receiver when charging handle indicates that the bolt is to the rear...???
You know- aside from the fact that a civilian cannot own a G36 at all since it's a post-86 weapon, and HK does not authorize dealer samples to non-LE/GOV/MIL dealers.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 09-09-2013, 02:19 PM   #6
brew
My Ride: F150 X5 MR2
Originally Posted by tailo View Post
. . . Never mind 90K+ in machine guns laying on the floor with socks in the photos and junk on the bed.
That describes half of the photos you post here.
brew is offline   Reply With Quote
Old 09-09-2013, 02:35 PM   #7
SLVR JDM
My Ride: 4Runner
Was thinking the same thing. The gun is always worth 100x the surroundings.
SLVR JDM is offline   Reply With Quote
Old 09-09-2013, 02:52 PM   #8
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
I want a suppressor for my PPK... would be ultra 007
Timeless Motor Group
Old 09-09-2013, 06:16 PM   #9
tailo
My Ride: 02 330I
I'm a unique case, there are no others.
Old 09-09-2013, 07:08 PM   #10
david05111
PPKs are notoriously difficult to suppress. Probably not worth the trouble
Old 09-09-2013, 07:31 PM   #11
2000_328CI
2000_328CI's Avatar
Silence is a virtue
You think that holds true for my PPK/S .22? I heard its the p22 barrel which is already threaded
Old 09-09-2013, 07:50 PM   #12
tailo
My Ride: 02 330I
Yeah, the .22 is no problem at all. Base suppressors are $250 and up.
1/2x28 thread adaptor and any .22 can will do. I can "convert it" In about 3 minutes.
Old 09-09-2013, 09:45 PM   #13
david05111
I think they're designed slightly different so yeah, probably will work
Old 09-09-2013, 10:51 PM   #14
tailo
My Ride: 02 330I
The real PPK is hard to suppress. The blow back design tends to be on the loud and gaseous side. You can play with spring weights but it's not generally considered worth it (unless you just want bonds gun)
The .22lr version is a breeze.
