Old 05-01-2004, 01:00 AM   #1
peterlai
My Ride: 2003 M3
Send a message via ICQ to peterlai
Turning on LED Taillight Retrofit Ring w/o ABLAS
After the LED Taillight retrofit, I want to get the outside ring to light up with the Brake Light, so I dig into the wiring diagram as well as the intruction of the ABLAS.
I figured out that if you just want the ring to light up with the brake light, you just need to connect the black/green wire to position #4 of the plug like the pic shown below:
Hope this can help a little if you guys are having a hard time getting ABLAS. But for me, I just want the ring to light up no matter what, which is a cheaper way to do...
Peter
2003 M3: Pheonix Yellow / Black Leather / Aluminum Trims
Premium, Cold Weather, SMG, GPS, Bi-Xenon, Adjustable Seat, H/K, 18" OEM
08/20/2002 - Place Order (111)
09/21/2002 - Production Started (150)
09/25/2002 - Production Completed (155)
09/27/2002 - Released to Distribution (160)
10/01/2002 - Loaded on Vessel
10/25/2002 - Arrived at Port Hueneme, CA
11/05/2002 - Arrived at Dealer
11/07/2002 - Took Delivery
peterlai is offline   Reply With Quote
Old 05-01-2004, 02:00 AM   #2
330CI-silver
My Ride: 330CI
so is there anything we need to get, or jus simply spice the wires and connect it.
330CI-silver is offline   Reply With Quote
Old 05-01-2004, 09:51 AM   #3
peterlai
My Ride: 2003 M3
That's all you need to do...
Old 05-01-2004, 01:40 PM   #4
330CI-silver
My Ride: 330CI
do i need to buy the white wire at and is the pink thing a transistor or sumthing its probably a stupid ? but im a newb when it comes to things with wires. thx
Old 05-01-2004, 01:44 PM   #5
peterlai
My Ride: 2003 M3
White wire is just a normal 20 wire and the pink thing is just a wire connector, just connect 2 wires without the need of cutting...
Old 05-01-2004, 06:17 PM   #6
330CI-silver
My Ride: 330CI
what brand and type of female connector pin you use to connect the white wire with.
Old 05-02-2004, 05:00 AM   #7
Datake
My Ride: E46 ///M3 - E87 116i
Send a message via MSN to Datake
Datake is offline   Reply With Quote
Old 05-02-2004, 11:05 PM   #8
330CI-silver
My Ride: 330CI
peter where u at bro
Old 05-02-2004, 11:44 PM   #9
peterlai
My Ride: 2003 M3
Just got them from a electonics store...
Old 05-02-2004, 11:58 PM   #10
GarrettF
needs a new sig...
GarrettF's Avatar
My Ride: '02 330Ci
Send a message via AIM to GarrettF
so basically tap into the blk/grn wire and run a wire to position 4 on the plug and the outer ring will ight up?
[LEFT]
CAR IS GONE
GarrettF is offline   Reply With Quote
Old 05-03-2004, 12:01 AM   #11
peterlai
My Ride: 2003 M3
Yup, it will light up with the inner brake light...
Old 05-04-2004, 12:24 AM   #12
330CI-silver
My Ride: 330CI
well do you know what the connector is call or jus get something that fit into position 4. well my friend was trying to install it for me but he said i need to know what type of female connector? tia
Old 05-04-2004, 10:39 PM   #13
330CI-silver
My Ride: 330CI
i went to radio shack, pepboys, o'reilly, autozone...none of them had it
Old 05-04-2004, 11:02 PM   #14
gixxer_kidd
My Ride: '02 M3 Cab
u da man. i'm gonna give this a try.
gixxer_kidd is offline   Reply With Quote
Old 05-05-2004, 12:07 AM   #15
peterlai
My Ride: 2003 M3
I got it from a local electronics store.
It's only $0.079 a piece.
It's the connector the the wiring harness. I dunno exactly what it's called, but if you bring that to them, they should be able to find one that's close.
Try those store which they sell transistor, resistors and stuff like that...
Old 05-05-2004, 04:40 PM   #16
330CI-silver
My Ride: 330CI
i got it working thx for the help peter, i couldnt find a electronic store around my area so i went to the dealer ship and they have the wire and connector. well it look so much better now and didnt even have to spend $60 for the ablas, great job
Old 05-12-2004, 01:48 AM   #17
hotcello
My Ride: 2002 M3
Peter
you really don't have to get the conector at all, just stick a regular wire from pin number 4(the empty slot)on the light side and stick the other side to the blue wire on the other side and that is it! NO connectors need it! just 1 wire, even the error indicator on the dash will disapear!!
hotcello is offline   Reply With Quote
Old 05-12-2004, 11:08 AM   #18
peterlai
My Ride: 2003 M3
Blue wire? Which wire in the pic are you talking about? The 2nd from the bottom?
I know you can stick the wire in, but that will be kind of loose, I rather use a splice.
Old 05-12-2004, 11:40 AM   #19
hotcello
My Ride: 2002 M3
the one next to the red one!! you can make the wire thicker and stick it in without cutting the wire, incase something happen you can just take the extra wire out!
Old 07-21-2004, 01:19 PM   #20
SoFla328
My Ride: 2000 328i
Send a message via AIM to SoFla328
pics?
does anyone have pictures of the after?
2000 328i
Electric Red/Black - SP - 5 Speed
Dinan CAI - Dinan Chip - Dinan Exhaust- Dinan Strut Bar
2 points shy of the DINAN badge.. anyone selling Dinan stuff??
SoFla328 is offline   Reply With Quote
