Australia
Old 09-12-2013, 12:12 PM   #1
lateral
My Ride: M3 CSL
BMW mechanical repair centre Sydney
Hi guys , have a continual problem with exhuast fumes when moving and windows are opened.Took to BMW for inspection 2 ,whist there they checked car fully over and whilst they smelt it ,could not rectify .i took the car to a exhaust specialist who advised full exhaust system is sound .The car has only 35000 kms since new .i also replaced rear boot seal as I could smell the fumes there
Can you advise where I can go and get my M3 sorted .i live in the inner city area,many thanks.
lateral is offline   Reply With Quote
Old 09-12-2013, 07:23 PM   #2
Ballistic325
My Ride: slow and steady
Hi and welcome
Are you sure it's exhaust fumes and not burning oil? The E46 has known issues with valve cover gasket leaks, oil filter housing gasket leaks and so on which could be oil seeping out and burning off as you drive. Just an idea... the smell is similar to wax burning. As far as workshops go, there are a few located close to where you are - Haberfield, Annandale (bottom of Johnston St) and others. Someone will chime in with names
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 09-12-2013, 09:16 PM   #3
SKR7
My Ride: E46 MY04.5 SMG M3
What does it smell like? A rotten egg smell would be the cat. If the inside of your exhaust tips are carbon black its burning oil.
There is a great mechanic in St.Peters/Marrickville, who has both joined this board, serviced mine and just bought a E46 M3 for himself.
///M
2004 E46 M3
SKR7 is offline   Reply With Quote
Old 09-12-2013, 09:36 PM   #4
aar0n_91
My Ride: 04 BMW325CI///MSport
bavarian engineering in taren point/caringbah is who i use now. very happy with them, im sure they'll sort your prob out. they are BMW specialists
BMW 325 CI ///M-SPORT INDIVIDUAL
aar0n_91 is offline   Reply With Quote
Old 09-14-2013, 02:16 AM   #5
KOpower
My Ride: 325ci
Close the windows??
Haha just trolling ! Are You sure there is a smell?? Maybe it's coming from the hood area??
My Ride:
2002 e46 325ci Manual - Sport & Premium Pkg
KOpower is offline   Reply With Quote
Old 09-14-2013, 02:47 AM   #6
boersy
My Ride: 04.5 E46 M3 SMG
Also use bavarian. Great people. Great service.
boersy is offline   Reply With Quote
Old 09-14-2013, 04:31 AM   #7
dimi_108
My Ride: 2003 E46 M3
I always get my work done by Matt at Bimmertech in Balgowlah (near Manly) and I also go to BEMW in Castle Hill.
Both are very knowledgeable, honest and the best priced in Sydney if you need work done on your BMW.
Try them, you won't be disappointed.
Australian E46 ///M3 Owners click here to join the Facebook Group
2003 Le Mans Edition M3 (Pics)
dimi_108 is offline   Reply With Quote
Old 09-14-2013, 04:47 AM   #8
jayb328i
My Ride: E46 2000 328i
Why don't you ship that car to me in Jersey and I will test drive it for you to determine if it is just a local problem where you live. No charge for my service.
jayb328i is offline   Reply With Quote
Old 09-15-2013, 07:32 AM   #9
ArcticFox
My Ride: 2003 M3 CSL
Have you checked the CPV? Could be leaking oil from there. Common problem.
It may be running down the side of the engine and dropping onto ur hot exhaust causing fumes. Worth checking.
M3/CSL is pretty bullet proof for oil leaks otherwise.
ArcticFox is offline   Reply With Quote
