Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 26 votes, 4.08 average. Display Modes
Old 09-19-2013, 02:57 PM   #41
My Ride: Lexus
Originally Posted by cposk View Post
You will not notice any NVH with the balljoints unless you are a hypersensitive person. These points are not directly connected to the chassis (the vibration has to go through a second bushing to get to the car, either the TA Bushing, Shock/Spring, Subframe bushing). This mod just helps to tighten things up/reduce variation when under load, which will translate to better handling characteristics.
I think as fanatics, we are all hypersensitive. I like it though. not at all turned off by the increased vibration.
Old 09-19-2013, 03:48 PM   #42
taylor192
My Ride: 2003.5 M3
Can someone post a link to a bushing/ball joint press that can be used to replace the upper/lower bushings/ball joints. Thanks!
Old 09-19-2013, 03:50 PM   #43
My Ride: Lexus
I already did. See post 1
Old 09-19-2013, 04:47 PM   #44
taylor192
My Ride: 2003.5 M3
See it now. I was hoping someone would point out the generic (aka cheaper!) ball joint press kits would work, preferably the kind I can rent at local auto stores.
Old 09-19-2013, 04:52 PM   #45
My Ride: Lexus
There is none. The true BMW kit for this is upwards of $800-$1,000. Consider the tool I linked a bargain.
Old 09-19-2013, 05:22 PM   #46
ClaytonL
My Ride: 2003 325i
Re: So, you wanna service the rear trailing arm? Definitive Trailing Arm Guide
This.
The MIS tool is really amazing. I was doing two e46 suspension refreshes which took me about 12 hours total. That's everything including struts, control arms, bushings, springs, shocks, tie rods, sway bar bushings and linkage, mounts, and RTABs. I saved the RTABs till last and at 3am the last thing I wanted to do was "rig" an autozone tool to work. I was already tired, frustrated, sweaty, and just plain sore. The tool put a smile on my face on how easy it worked. Almost as easy as replacing a thermostat.
Many members have then for rent. I got mine for $20. Well worth it. I actually regret not buying it.
Sent from my SAMSUNG S4 using BimmerApp mobile app
ClaytonL is offline   Reply With Quote
Old 09-19-2013, 05:28 PM   #47
My Ride: Lexus
Originally Posted by ClaytonL View Post
This.
I believe he is talking about the E36/E46 rear axle service kit, not the RTAB tool.
Old 09-19-2013, 05:33 PM   #48
taylor192
My Ride: 2003.5 M3
Ball joints not RTABs.
Looks like I'll be making a tool then. These are bargains:
Old 09-19-2013, 05:35 PM   #49
My Ride: Lexus
I tried making similar tools but the truth is the rods arent big or sturdy enough. I snapped two custom tools in half and bent a hardened steel socket. The bushing didn't budge one bit. Depending on how corroded the original bushings/balljoints are, you may have a difficult time removing them with home-made tools. Some have done it but I found it best to not waste my time. Plus flying steel is never safe. Wear eye protection.
Old 09-19-2013, 05:56 PM   #50
ClaytonL
My Ride: 2003 325i
Wow. My fault. Sorry.
That's why I hate using my phone app. It's harder to keep up.
Disregard.
Old 09-20-2013, 09:00 AM   #51
Zell
Zell's Avatar
My Ride: so turbo wow
Yeah I've read online as well that those ball joints are near impossible to remove without the special tool, even with heat.
When I do my overhaul at a local "DIY garage" shop thing around here, I'll ask them if they have any tools that might be able to do it. If they have some tool that'll work I'll let you know.
http://forums.bimmerforums.com/forum...all-Joint-Tool
This guy is renting out a tool that can do it, the thread is old but maybe he's still around.
Old 09-20-2013, 09:29 AM   #52
My Ride: Lexus
Oh yeah. I have the tool? How do you think I did it? Tim has it at the moment otherwise I'd show you how it's set up. Or I might have a pic around somewhere. but it's pretty much like the home made tool but a LOT sturdier. For one, the rod is solid as fvck. Heavy duty. Designed for the job. The pieces also have to be machined to a certain shape so they don't come into contact with the brake heat shield.
Old 09-28-2013, 02:27 PM   #53
ti317
My Ride: 02 330ci coupe 5 spd
I just Googled "The shiznitt" and Mango's picture came up!
Thanks Mango! Great thread! Big ups!
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 10-01-2013, 09:43 AM   #54
Patton323I
My Ride: R1100GS E46 E53
I need to do this. Go Mango on getting on the E46 front page!
Patton323I is offline   Reply With Quote
Old 10-01-2013, 11:20 AM   #55
My Ride: Lexus
Thanks! and yay didn't notice. i should check that more often.
yes if you track your non-M, or even M3, it's best to upgrade/service these trailing arm components and/or upgrade to the M3 balljoints
Old 10-01-2013, 11:55 AM   #56
pyo
My Ride: Z4 3.0i '04
Send a message via AIM to pyo Send a message via MSN to pyo
Awesome guide! I need to stop reading your guides cause its making me spend too much money =P
2000 328i [Sold]
2004 Z4 3.0i 6spd
pyo is offline   Reply With Quote
Old 10-01-2013, 12:36 PM   #57
My Ride: Lexus
hahaha
Old 10-01-2013, 03:53 PM   #58
ti317
I ordered FCABs and RTABs both by Febi Bilstein. I'll do them this weekend and report on the quality.
Old 10-01-2013, 06:14 PM   #59
smolck
My Ride: 2004 ZHP Sedan
Yeah that's the thing. Also not sure I'd trust something pressed in with hand pressure that's supposed to be pressed.
Have you ever DRIVEN a car with the powerflex or UUC RTAB's?
I have had powerflex on my own cars, and installed them on other peoples cars. They are a wonderful upgrade, one you can actually feel.
When going this route you don't need anything beyond a drill bit and air chisel for removal and your hands to install. It is a thing of beauty.
Nothing wrong with OE bushings, but nothing wrong with powerflex either.
Oh, and there is more movement of a stock bushing than a powerflex, pressed or not. Both are BOLTED to the car.
As for special tools, whatever. People said I couldn't do rear wheel bearings without a special tool, I did that too. Even documented it on youtube. There is always a way around things. It is the difference between experience and book knowledge.
Nice write-up, and Kudos for adding the other ball joints, most people skip that item.
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 10-01-2013, 08:27 PM   #60
XKR
My Ride: 2001 M3 Convertible
THANK YOU FOR THIS i think mine needs some "maintenance"
Don't ask, I blame the tow truck driver who probably attached a winch to it
XKR is offline   Reply With Quote
