///M3 Forum
Old 12-07-2009, 09:46 AM   #1
flipture
My Ride: 2001 M3
Open hole in M3 washer fluid reservoir bottle
So the other day when I took my headlight out to check it out, I noticed that there is an open hole in my washer fluid reservoir bottle. I can stick my finger in the hole and touch fluid. Is this normal? I would think it would be plugged with something and not open...
Also, when I went to fill it up, I poured fluid in to the filler neck for a bit then it started overflowing from below. I didnt' see any kind of full line or anything... :-\
flipture is offline   Reply With Quote
Old 12-07-2009, 10:04 AM   #2
Messe46
My Ride: 325xi ZSP - ONRLS
Send a message via AIM to Messe46
duct tape fixes all!!
but seriously, pics would help.
-Mike
Im sorry, but having an Aston Martin DB9 on the drive and not driving it is a bit like having Keira Knightley in your bed and sleeping on the couch. If youve got even half a scrotum its not going to happen.
-Jeremy Clarkson
Messe46 is offline   Reply With Quote
Old 12-07-2009, 03:10 PM   #3
flipture
My Ride: 2001 M3
I thought I took pics when the headlight was out but its all back together now so I can't take pics at the moment... I'll take them when I can but if anyone knows what I'm talking about, please chime in...
Old 12-08-2009, 12:01 PM   #4
Messe46
the only thing i can think of is the hole for the pump for headlight washers.
-Mike
-Jeremy Clarkson
Old 12-08-2009, 02:25 PM   #5
cityjohn
My Ride: 2001 M3
Mine has that too -- I discovered it when filling the bottle and hearing the fluid leak back out. I removed the bumper to fix the problem and found that it's apparently designed that way.
cityjohn is offline   Reply With Quote
Old 03-09-2010, 01:04 PM   #6
flipture
My Ride: 2001 M3
Strange. I think there is something wrong with mine since I can fill it up then the light comes on shortly after to tell me that its low.
Old 03-10-2010, 06:36 PM   #7
mastley
My Ride: 2005 BMW M3
Mine has the exact same problem. It will leak to the point where after two washes, the windshield washer light is on. I have not taken the bumper off but I can tell there is a leak from the front of the reservoir, but its a fairly slow leak. If you have pictures with the bumper off it would be awesome. I am planning on replacing the tank this weekend if I can go pick up the part.
mastley is offline   Reply With Quote
Old 03-11-2010, 08:33 AM   #8
flipture
My Ride: 2001 M3
Take some pics of the new part if you get it and also of what you currently have there if you can. I'll do the same if I pull mine off first...
Old 03-15-2010, 07:04 PM   #9
mastley
I picked up the new reservoir today from tischer (those guys rock btw). I only took pics of the front since i figured thats where most people had problems. I could not see any obvious holes, so I am thinking its a rub point? If somebody has seen the hole point out where it was.
I am going to swap it out this weekend.
Matt
ID:	352255   Click image for larger version
Old 03-16-2010, 01:06 AM   #10
flipture
My Ride: 2001 M3
The hole in the top of mine is perfeclty circular and in the middle. It was either cut or meant to be there and definitely not rubbed...
Old 03-16-2010, 01:18 AM   #11
m3e46freak
My Ride: m Twee lol
"double bubble" Or a strong ass superglue/sealant type fluid.
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 05-24-2010, 08:45 AM   #12
mastley
Finally got this fixed and figured I should post. It was not the reservoir in the end, it was actually the pump that was leaking. The pump was leaking slowly and it was spraying onto the reservoir, making it a PITA to figure out where the leak was. Replacing the reservoir was pretty easy. Take off bumper, two screws, done.
I would highly suggest taking both pumps out and giving them a really good look before you change the reservoir. check the seams where the plastic was joined and in the plastic ridges near the bottom. Mine had a very small crack that was causing the leak. Pumps are cheap and easy to replace in comparison.
PS. Anybody want to buy a gently used windshield washer reservoir?
Old 07-22-2011, 12:29 PM   #13
Evo-2-M3
My Ride: 04 SMG M3
whats wrong with this site? cant PM a user? only a sponsor haha
still have the "PS. Anybody want to buy a gently used windshield washer reservoir?" lol.. Also where can i buy the pumps and sensor??
Evo-2-M3 is offline   Reply With Quote
Old 06-04-2012, 04:06 PM   #14
asuen435
My Ride: E46 M3
Hi, anyone knows how to remove the washer fluid container? The grommet's strainer fell in the container while I was trying to remove it, I can't fish it out, its all the way on the other side, so looks like I would have to remove the tank and dump it out. Thanks for the help in advance
asuen435 is offline   Reply With Quote
Old 09-21-2013, 05:40 PM   #15
M3B
My Ride: 2002 M3 coupe
Matt
As I'm sure you don't still have your unused reservoir, do you by chance still know the oem part number? Mine looks like yours (with the filler tube,) but all I'm finding through searches is another, with a cap, that they say will fit but is totally different (61667007970?? wrong). I also googled the part number on the side (61672695531) and there all I'm getting is a headlamp washing pump. Weird, I know! Any help is appreciated. Thanks.
M3B is offline   Reply With Quote
