Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 09-25-2013, 01:05 PM   #1521
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
trans oil quick disconnect
Originally Posted by djbradle View Post
Maybe the only in/out are the inlet and outlet cooling line quick connectors?
There are lots of places to drain the coolant: block drain plug, radiator drain plug, lower radiator hose, auto trans oil cooler. Disconnect all these for an optimal drain.
Those quick disconnects from the auto trans oil cooler will spill trans fluid, not drain coolant. You know that, right?
Also, be aware that once you open the cooling system you have committed yourself to the infamous coolant bleeding procedure.
Finally, if you are going to work on the cooling system then follow Mango's advice and completely replace everything that is aged and suspect. It's not that costly and will save you thousands from a blown head gasket. As me how I know...
Old 09-25-2013, 04:40 PM   #1522
djbradle
My Ride: 2002 325 xit
Ahhh Okay. I didn't know that the tranny fluid flowed to the heat exchanger. I thought it was the other way around and that coolant flowed around the tranny somehow but I never ventured to seek out the facts on that. Thanks for the correction! It is obvious know that my former opinion would never be a viable choice for tranny fluid cooling, ha!
djbradle is offline   Reply With Quote
Old 09-25-2013, 05:14 PM   #1523
My Ride: 2016 Lexus
Make sure you replace your trans cooler o-rings if you disconnect it
Old 09-26-2013, 11:27 PM   #1524
jmo69
My Ride: 03 325xi 98 328is
I know it was put there for a reason, but is it possible to run without the auto trans coolant thermostat? What would be the consequences of deleting it?
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
Old 09-27-2013, 12:05 AM   #1525
BaliDawg
Mango should probably have the final word on that question, but I can confirm that I removed it six months ago without issue. I believe it's there to preheat the trans fluid thereby reducing trans wear. It is really fragile (I broke mine during a cooling system overhaul) and restricts the coolant flow a bit.
Old 09-27-2013, 12:13 AM   #1526
eneka
My Ride: 2003 325i
I ran mine without for quite some time while i waited for parts and time to put it in. Ran perfectly fine.
eneka is offline   Reply With Quote
Old 09-27-2013, 01:35 AM   #1527
My Ride: 2016 Lexus
I'm no expert on the auto trans, but common sense tells me BMW put it there for a reason. You don't want the fluid too cold. Without it, seems the trans fluid would be over-cooled.
Old 09-29-2013, 01:53 PM   #1528
gwnickerson
My Ride: 2006 330Ci Convertib
Expansion Tank Mounting Question
Originally Posted by Mango View Post
Sure, I can add the mounting plate. In my experience, it's a robust part and is essentially just a plastic frame. should be fine if you're careful. I'll add it!
Since this part isn't a typical failure item, I didn't include it in the grand totals. It's $54 and somewhat substantially drives up the cost of the rebuild.
New to forums. Have read a lot about coolant leaks and expansion tank. Had a slow leak at the temperature sensor. It finally got big enough that I had to attend to it. There was indication of leakage at the top of the expansion tank and I fought my way through removing it. When I looked from the bottom after removing it, I saw that the mounting plate seems to be loose from the radiator, but not sure how it is supposed to look. Any thoughts on the questions on the photo would be appreciated.
gwnickerson is offline   Reply With Quote
Old 09-30-2013, 08:41 AM   #1529
djbradle
* E46 Cooling Guide (Information w/parts list/bleeding) *
Thanks for the confirmation Mango and BaliDawg
Old 10-05-2013, 09:08 AM   #1530
tommy320i
My Ride: 2003 E46 320i 2.2L
Hey guys,
I have tried to search but haven't found the info I need, I have a 2003 E46 320i AUTO and am looking to buy a radiator, will this part fit? part # 17 11 9 071 519?
Is there a forum or thread with part numbers to look up so you can confirm they fit for specific models?
Thanks for you help in advance
tommy320i is offline   Reply With Quote
Old 10-05-2013, 11:31 AM   #1531
Stinger9
My Ride: '04 330Ci
Use your vin at www.realoem.com
Old 10-08-2013, 05:10 AM   #1532
tommy320i
Thanks Stinger9!
Old 10-09-2013, 05:16 AM   #1533
Lynchy
My Ride: 05 325i
Glad to help. There's also other misc. hard pipes and even one soft hose which connects to back of expansion tank and goes to the hard cooling pipe towards the firewall. But nobody replaces that but maybe I should add that too. I totally forgot about it when I did my cooling update. But, FWIW, I don't think I've ever heard of a hose failure on these cars.
once again my friend you never sieze to amaze me i shall be doing an oil change and chaging my coolant/antifreeze with some distilled water this weekend and of course i shall be using your DIY guide to do this well need maintance i know the PO didnt do
Lynchy is offline   Reply With Quote
Old 10-09-2013, 07:21 AM   #1534
ti317
My Ride: 02 330ci coupe 5 spd
Don't follow Mango's cooling system guide!
Far better to drive along obliviously until something needs replacing. You get to experience the thrill of waiting by the side of the road in freezing rain or in a really bad neighborhood, till the tow truck get there.
As an added bonus, you get to buy a complete engine instead of a few measly parts.
I'm sick of following Mango's advice! I have been doing that for a while now and I have not had any excitement.
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is online now   Reply With Quote
Old 10-09-2013, 07:34 AM   #1535
Lynchy
My Ride: 05 325i
how about no thanks man im not going to just let my car die on me or let the engine overheat making me spends more money than i have to And 1. im already due for an oil change and my low coolant/antifreeze light (or w.e you want to call it) JUST turned on on my way to work last night so im doing it! and 2. he already gave me advice on how to change my fuel pump and everthing went great so as of now i have no reason not to follow his diy guides
Old 10-09-2013, 09:11 PM   #1536
dirty vert
My Ride: 2001 330ci
He's just messing with you..... we all know maintenance is priority. Unless you like to push your luck and don't care.
dirty vert is offline   Reply With Quote
Old 10-09-2013, 09:50 PM   #1537
Lynchy
My Ride: 05 325i
Good haha maintaince over everything
Old 10-18-2013, 10:24 PM   #1538
Robert. l
My Ride: 2005 325i
rad light comes on when heater is turned on and gos off when heater is turned off
What's the deal I'm a mechanic and I bought the car for my wife on our 25th anniversary 2005 325i she wants to keep it forever
Robert. l is offline   Reply With Quote
Old 10-20-2013, 10:15 PM   #1539
dirty vert
My Ride: 2001 330ci
Needs coolant....
Old 10-21-2013, 08:38 AM   #1540
SDL
My Ride: 2002 325i
I have everything removed, and am going to order the replacement parts today. What hoses are normally replaced? I know Upper and Lower, but what about the two smaller hoses that come off the bottom of the expansion tank and mount? - I think they go to the heater core, correct? Do these need to be replaced? I worry about 12 year old rubber o-rings on those connections. Can you replace the o-ring?
Thanks!
SDL is offline   Reply With Quote
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
