Thread Tools Search this Thread Rating: Thread Rating: 102 votes, 5.00 average. Display Modes
Old 05-19-2013, 10:12 AM   #61
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yes, try that. Go to the lighting options (LCM) and on the bottom right you will see a setting for xenon lighting. Check that off.
Old 05-19-2013, 10:21 AM   #62
halo0
My Ride: '02 330i 5mt
yep just did that an hour ago. Still have a bulb out indicator. I'm not really sure if it's flickering or not because it's daylight out now.
^Click, stop by and say hi.^ ------ 5% off Redline leather
halo0 is offline   Reply With Quote
Old 05-19-2013, 09:36 PM   #63
halo0
So it seems like after coding the flickering is gone, but I still have a front pass warning light on the dash. :/
Old 05-19-2013, 09:45 PM   #64
halo0
So I just found this
http://e46fanatics.com/forum/showpos...99&postcount=1
19. Start the vehicle. Turn headlights on. If the D2S bulbs power-up but flicker and you have two front bulb-out warning lights, you will need to take the vehicle to your Indy shop (or Stealer) to get the LCM reflashed to enable the LCM to recognize the "Xenon Retrofit." After the LCM reflash, the lights will not flicker anymore, but you will still get a right-side bulb-out warning light. This is because the right side low beam connection is not attached to anything. Recall, the Morimoto wiring harness only connects to one low beam connection, not both. If you have a pre-facelift vehicle, you can pull fuse #32 from the fusebox and the bulb-out light will go away. Apparently, fuse #32 powers the "bulb-out" testing function.
I have a facelift, so I'm going to try the resistor method. I have some left over from when I had LED turn signals on my last car. Frustrating that TRS doesn't account for this problem.
Old 06-05-2013, 02:57 PM   #65
ohiwish
My Ride: 325xi
New owner here. . and thanks for the great post. Question ; Replaced my front axles on 325xi, and removed the headlight 'box/leveler' from the lower control-arm. All back otgether and Now headlights turned down. Can you pass along the 'adjustment' of that control box to get the lights back up to position?
Many thanks.
Jim Ohiwish@q.com
ohiwish is offline   Reply With Quote
Old 06-06-2013, 10:47 PM   #66
zimi117
My Ride: 2001 330Ci
About to purchase OEM xenon's from 2003 330ci. Headlight, lens, ballasts and igniters are included. Is there anything else I need to do for my 2001 halogens? Any resistors or reprogramming I've read on? If anything i just hope its just the fuse pull.
zimi117 is offline   Reply With Quote
Old 06-09-2013, 12:15 AM   #67
Solidjake
Zero. Leaks.
Solidjake's Avatar
Many thanks.
Jim Ohiwish@q.com
Reinstall it the way it way then you will probably have to rotate the knobs on top of the headlights to aim them properly.
Old 09-04-2013, 01:57 PM   #68
FcBarcelona
My Ride: 325ci
My 2004 325ci has this issue where my right projector shoots really poorly and goes off to the left. On both headlights, the projectors move up and down freely. But my right projector shoots normally. I wanted to upgrade to HIDs but not with the headlights shooting properly. (And the adjusters are dead)
This is the one piece headlight! It's quite annoying..
FcBarcelona is offline   Reply With Quote
Old 09-27-2013, 01:34 AM   #69
RECCER
My Ride: 2001 330ci
i apologize in advanced if this is a question that has been asked already i may have over looked it in hours past researching how i can improve my light set up...
where can i buy AL projectors!? i have a 2001 330ci in serious need of an update, i already have projectors in my xenon healights all im looking for is to replace the projectors so i can have a nice crisp clean output again like i know it should be doing. so if anyone can help direct me in the right direction that would be greatly appreciated.
01' 330ci/Dinan CF CAI/Dinan High flow throttle body/Dinan Stage 3 ECU chip/
RECCER is offline   Reply With Quote
Old 10-31-2013, 09:42 PM   #70
Platano20
My Ride: e46 3-Series
*** Official E46 Lighting Guide ***
Originally Posted by mightymouse777 View Post
believe me i have read and read and read on headlights. i want good ones not the cheap ebay crap. but when i look them up i just get lost. i need the full set up. my driver side head light fixture is broke anyway so i want a full upgrade. what i dont get is there are ones that are plug and play and others they say they should be installed by a pro. do these plug and play have everything i need? ballasts and all etc. i have factory halogens right now and they are the worst at night and i work nights thats the man reason i want to upgrade. someone direct me to some sites please? here is what ive looked at...
http://www.umnitza.com/projector46-t...ing-p-208.html all the options i dont understand.
http://www.stealthauto.com/Products/...LK-1-PRNT.aspx
+1
Myself: Upper/Lower Intake Boots, Head Light Lenses, Kicker L5 12" Sub, Tints 18% all around, smoked corners & side markers, Spark Plugs, Front Eibach front & rear Sway Bars, Front & rear Sway Bar End Links, Eibach Pro Springs, Koni FSD Struts & Shocks, Meyele HD Front Control Arms and Bushings,
Platano20 is offline   Reply With Quote
Old 12-29-2013, 08:00 PM   #71
(510)330ci
My Ride: 330ci
Re: *** Official E46 Lighting Guide ***
I need help installing the hid bulb on my car idk how to get it to stay in
Sent from my SCH-I535 using BimmerApp mobile app
(510)330ci is offline   Reply With Quote
Old 08-16-2014, 07:41 PM   #72
shellback
My Ride: BMW with rear wiper
couldn't find any specific info on the following possible install:
Are euro Bosch headlights compatible with US E46's?
I might get a set from a UK 2000 E46 but not sure if wiring will be compatible on my 2000 touring.
shellback is offline   Reply With Quote
Old 08-16-2014, 07:42 PM   #73
shellback
Old 08-17-2014, 11:08 AM   #74
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
The thing about that is if it comes from a UK car the headlights will shine in what is considered backwards to US standards. That is, the cutoff pattern will be flipped because its for a right-hand drive country.
See the image here:
https://www.google.com/search?hl=en&...ml%3B700%3B275
And here:
http://i1291.photobucket.com/albums/...ps3b6c883e.jpg
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 12-12-2014, 04:20 PM   #75
Solidjake
Zero. Leaks.
Solidjake's Avatar
Info vid: E46 headlights explained
Made a very quick simple vid explaining the E46 headlights minus facelift coupe, any questions/comments lmk. I know I missed explaining non-bixenon headlights; they don't have the shutter open when you push forward on the stalk.
Old 12-12-2014, 05:02 PM   #76
Patton323I
My Ride: R1100GS E46 E53
Sweet!
Patton323I is offline   Reply With Quote
Old 12-12-2014, 05:46 PM   #77
mleindek
My Ride: 2009 X5
Great video!
mleindek is offline   Reply With Quote
Old 12-12-2014, 06:54 PM   #78
RichG
My Ride: BMW
thanks Jake for this info vid.
RichG is offline   Reply With Quote
Old 12-13-2014, 01:41 AM   #79
Ceric
My Ride: 2005 BMW 325i
I have a question regarding the angel eyes. Are there any eyes out there that sit flush with the inner halogen reflector bowl, producing no visible gap? It doesn't matter if they are LED or CCFL, as long as they sit flush.
I've illustrated the gap I am talking about in this picture:
Ceric is offline   Reply With Quote
Old 12-13-2014, 04:10 AM   #80
eneka
My Ride: 2003 325i
my $50 Khoalty ones do. It's a bit tricky to fit them because of the auto leveling.
eneka is offline   Reply With Quote
