Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 4.63 average. Display Modes
Old 10-05-2013, 07:37 PM   #401
Llink78
My Ride: 2002 330i
nice numbers on your 328! Who did your DME remap? canned tune or custom? Im looking for something for my 330i still
Llink78 is offline   Reply With Quote
Old 10-05-2013, 07:52 PM   #402
se93
My Ride: BMW 328ci AW MTECH2
E46 Dyno Thread
Nice numbers
Regards,
Mark Perez
se93 is offline   Reply With Quote
Old 10-10-2013, 02:08 PM   #403
Marek555
My Ride: E46 328i 174kW
Thanks, remap was done by local guy in Estonia. He downloaded stock DME software from my car, modded it and then loaded back to car.
Marek555 is offline   Reply With Quote
Old 10-21-2013, 09:07 AM   #404
SoloII///M
My Ride: Many
Originally Posted by SoloII///M View Post
Here's my plot from the dyno tuning session today. We did about four hours of WOT tuning on the dyno (35 runs) and another 4-5 of part-throttle to get the car running right. We were getting a lot of heat soak (I need to make a shield for my intake pipe). I suspect if we had let the car cool we would have seen higher peak numbers, but I don't really care about the absolute numbers.
Peaks of 230whp / 228 wtq
Mods:
M54B30, 0.030" over, ZHP cams, running Megasquirt and E85 (flex-fuel)
Technik V3 headers into Burns megaphone collector to 3" pipe, two mufflers and a dump before the diff
Decked head
Mild head port blending
M50 throttle body bored to 68mm
Long-tube 3.5" intake, filter in driver's brake duct
There is probably a little to be had between 2,500 and 3,000 RPM but the car is never used down there so we didn't bother spending a lot of time on it.
Looks like we had a boo-boo and the atmospheric correction factors didn't get loaded on any of these dyno runs so this plot is 5-6lb-ft low across the band. Hope to get an updated run sometime next year.
John
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 10-22-2013, 02:54 PM   #405
pokeybritches
My Ride: G-Power Z4M, VF Z4
Car/Engine: Z4 M54B30
Mods: VF Engineering supercharger kit (Vortech V3 SCi @ 6 psi); Supersprint headers, Y-pipe, race muffler; Sportline CS.16; 3.64 final drive
Dyno type: Dynojet
Peak numbers: 285whp/225wtq
G Power Z4M and VF Engineering Z4 3.0i
pokeybritches is offline   Reply With Quote
Old 10-28-2013, 10:42 AM   #406
Iceman00
Banned User
My Ride: E90 6MT
Powa!
Old 10-28-2013, 10:51 AM   #407
se93
Wos
Originally Posted by Iceman00 View Post
Powa!
Wow!!!!
Awesome
Must be a pleasure to ride
Regards,
Mark Perez
Old 12-16-2013, 08:39 PM   #408
robreZ
My Ride: 01' Z3 Coupe
Name:robrez (bimmerforums)
Car/Engine: E36/8 M54B30
Mods: Ebay headers, Technik Cams, Custom Tune, Dinan CAI and throttle body, SS exhaust, and TM pulleys
Dyno type: Dynojet
Peak numbers: 228WHP, 207WTQ
vs headers (no cams or tune)
Originally Posted by secono330ci View Post
This is interesting. I wonder the specs of the cams he used? ...264/248?
I don't know if this was ever cleared up, but I was using 272/268 cams at the time of dyno. I posted more info. in this thread.
robreZ is offline   Reply With Quote
Old 12-27-2013, 08:23 AM   #409
dcmsnd
My Ride: 325
Amazing how some 2,5L are giving 160whp while 2,8 are 180-190.
2,5L guys needs to check for engine condition (leaks ? plugs ? vanos ? )
Statistically, m54 should put more whp than m52 and 2,5 vs 2,8 = small difference. Im from europe and guys here are pulling 160whp without mods on 2,5 and 155-160 on 2,8 without mods.
My friend have custom intake, ebay headers and custom exhaust and dynoed 220crank BUT 155whp. I can find dyno sheet if u want guys.
dcmsnd is offline   Reply With Quote
Old 12-27-2013, 10:33 AM   #410
pokeybritches
E46 Dyno Thread
150 whp is reasonable for a M54B25. Where are you pulling the 220 bhp number from? That's like a 30% drivetrain loss. It should be more like 189 bhp with the standard 18% loss.
Old 12-27-2013, 11:44 AM   #411
dcmsnd
My Ride: 325
220 on 328 with headers, KN intake and custom exhaust.
Here is dyno sheet. 219 crank but 156whp . 156whp should be on stock 325 at least (here in EU). And some guys here are getting 180whp+ on 328. How ??
http://www.bmwklub.sk/download/file....4541&mode=view
His dyno pull
Acceleration
Old 12-27-2013, 10:15 PM   #412
jdjg
My Ride: e39, m52tub30
E46 Dyno Thread
I got 235 WHP in my e39 530i (m54b30) with wrapped headers + custom made wrapped exhaust (1 pipe 2.5" SS) + cat less + Remus muffler + Magnaflow high flow resonator + tuning (EpicMotorsport) + UUC pulleys
jdjg is offline   Reply With Quote
Old 12-27-2013, 10:20 PM   #413
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by jdjg View Post
I got 235 WHP in my e39 530i (m54b30) with headers + custom made exhaust (1 pipe 2.5" SS) + tuning (EpicMotorsport) + pulleys
Can you post up the dyno graph ? Also what dyno was it, & what correction factor ?
Thanks.
SUMMIT POINT WV 1:24:229 SCCA
Old 12-28-2013, 12:50 AM   #414
jdjg
E46 Dyno Thread
Thanks.
DynoDynamics, correction factor about 28%.....
I know this because I did another dyno pass using DynoJet (after the DynoDynamics), my numbers was 235 whp.....
between DynoJet and DynoDynamics are about 13% of correction factor, so if you use DynoJet you "only" have about 15% of correction factor and if you use DynoDynics you have about 28% correction factor...
regards
Old 12-28-2013, 02:09 AM   #415
Davew
My Ride: 2004 330ci Msport
E46 Dyno Thread
Crank
Crank
At the wheels
Dyno dynamics dyno
330ci with ess ts2+, technic stage 3 head, factory decatted headers, factory sport exhaust, few other bits and pieces here and there.
Dyno was with bad vanos seals and secondary cats in place ( both now resolved), will be doing full exhaust including headers, couple of small changes, then back on the dyno
Davew is offline   Reply With Quote
Old 12-28-2013, 03:17 PM   #416
Rob43
Rob43's Avatar
Very nice Davew,
The first two graphs through me off a bit, until I realized they were "crank" figures. For me, the third graph is the one I scrutinized, 310.6 WHP on a DynoDynamics Dyno is excellent !
If you were on a Dynojet dyno (the U.S. standard) your WHP would be about 350 WHP.
Congrats & enjoy.
Old 12-28-2013, 04:12 PM   #417
Davew
E46 Dyno Thread
Very nice Davew,
Congrats & enjoy.
Thanks Rob43
Sorry for the confusion with the 3 sheets, i thought as there are only a few dyno dynamics figures listed, I would put all I had up for comparison. I really struggled finding a comparison after getting these myself, and thought they may be useful for others that can't access a dyno jet
Dave
Old 02-23-2014, 12:23 AM   #418
devinruss
My Ride: e46 330ci
What exactly is "dyno"? I'm here to learn just like most of the other people so I'm hoping you don't bash me too hard.
devinruss is offline   Reply With Quote
Old 02-23-2014, 01:45 AM   #419
Stinger9
My Ride: '04 330Ci
Not to worry; you get a free pass with only ten posts to your name!
Dyno is dynamometer. A machine to measure the horsepower of an engine.
These guys tune their engine for more power and then use the dyno to measure how successful they've been.
Old 02-23-2014, 01:47 AM   #420
devinruss
My Ride: e46 330ci
That was the most helpful anyone has been so far. Thanks!
dyno, dynoed
