Sponsored by BimmerWorld
Old 10-06-2013, 11:22 AM   #1
Popeye213
My Ride: 325i
Steering creek
When I turn the wheel both ways it creaks. I have. 2002 BMW 325i. If I put the car on jack stands with the wheels off the ground. And turn the wheel there is no creeking. The powersteering fluid res is low. No fluid on stick but there is some at the bottom.
Any ideas?
Popeye213 is offline   Reply With Quote
Old 10-06-2013, 11:28 AM   #2
Tangent_
My Ride: '01 330i, '11 Z435i
Re: Steering creek
First idea is to fill the proper amount of atf into the reservoir so you don't kill your ps pump. If you don't do that, any creak you have will soon be joined by the moaning sound of a bad pump.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 10-06-2013, 11:40 AM   #3
Swater330i
My Ride: 2003 BMW 330i 5MT
Steering creek
Sometimes when I find out my fluids are low I just decide to fix the problem by refilling the fluids.
Use ATF fluid not power steering fluid.
Originally Posted by phenom323ci View Post
I am going to install M3 fender grill on my 323ci.
Originally Posted by futureSubie View Post
IMO, the euro clear corners looks too aftermarket/ricey.
Originally Posted by Davconelectric View Post
This 323 would most likely handle and drive better than a stock e46 m3.
Swater330i is offline   Reply With Quote
Old 10-06-2013, 02:29 PM   #4
lucase46
My Ride: 2004 325i
He said creaking noise not whining
Im guessing it will from a bushing
lucase46 is offline   Reply With Quote
Old 10-06-2013, 02:49 PM   #5
Tangent_
Re: Steering creek
Possibly depending on his definition of creaking... But in any case the low fluid level is definitely a problem.
