Old 10-03-2013, 09:52 AM   #1
SPDSKTR
My Ride: E46 ZHP TS2+ Coupe
I believe I've found a viable option for LED headlights. But it's expensive...
http://www.jwspeaker.com/other/new-9...tor-headlights
I know there are several options for HID projector retrofits, but going the route of LED would be unique.
The specs claim they put out... brace yourselves... 17,500 maximum candela (1 candela = 1 lumen, from my understanding). SEVENTEEN THOUSAND. A typical D2S bulb throws out ~3,500. Since these units are fairly large (a bit larger than FX-R projectors), I believe they would work quite nicely in the E46 headlight assemblies (with a bit of elbow grease, hacking, cutting, and JB Weld).
The downside? The price. I've found the low beams for $216 a piece and the high beams for $262 a piece. With that said, you're looking at roughly $1,000 for all four assemblies (assuming you want high beam LEDs as well).
Light output from the Model 8700's seems to be pretty good (there are videos on YouTube), so I can only imagine these would be significantly better.
Just figured I'd toss 'em out there!
NOTE: I am not affiliated with JW Speaker in any way. I always thought it would be awesome to have LED headlights.
Originally Posted by Brucifer325 View Post
Thread sucks so bad they moved it to the Feedback Forum.
SPDSKTR is offline   Reply With Quote
Old 10-05-2013, 09:15 AM   #2
JS330
My Ride: '01 330Ci 3 Pedals
this would be pretty cool
Originally Posted by DeclanM3 View Post
I hope he isn't using Pirelli condoms..
JS330 is offline   Reply With Quote
Old 10-05-2013, 06:18 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Something like this I would have to see in person.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 10-05-2013, 06:37 PM   #4
JQuick5156
My Ride: 2004 330 Coupe
Go for it and if it works you opened an entire new way to go instead of hid retrofit.
JQuick5156 is offline   Reply With Quote
Old 10-07-2013, 10:29 AM   #5
SPDSKTR
If I had $1,000 to spend on a full LED upgrade, I would. I think it would look sweet in my E30.
I am now accepting donations.
Old 10-08-2013, 05:17 PM   #6
awesomechinz
My Ride: 1999 BMW 323i sedan
This looks like it would be fun... I'll offer up my passat if you want to test prior to hacking up your e46 lights!!!!
awesomechinz is offline   Reply With Quote
Old 10-10-2013, 12:31 PM   #7
SPDSKTR
Are you paying for the lights and shipping me the headlight assemblies?
Old 10-10-2013, 03:55 PM   #8
LD330XI
My Ride: '09 335i
Re: I believe I've found a viable option for LED headlights. But it's expensive...
I was looking into this kind of thing earlier before I did my quad d2s retrofit. I found hella makes a bi-led projector. But it was about $2000 for four projectors back then.
http://www.hella.com/MicroSite/soe/e...eadlights.html
LD330XI is offline   Reply With Quote
Old 10-10-2013, 05:38 PM   #9
awesomechinz
I'll consider it... But these things also keep me on the road for my commute to and from school so probably not :/
