General Off-Topic
Old 10-12-2013, 11:37 AM   #21
Xcelratr
My Ride: 04 330Ci ZHP
Esp on the freeway, if you have to jam on the brakes, as soon as you judge the distance in front, next step is to check your rearview mirror. A handful of times over the years, I've managed to avoid being hit from behind by doing so.
People that fail to secure their cargo well enough =
People that stop on a freeway anywhere but the shoulder to pick up the crap they dropped =
We will not tolerate intolerance.
Xcelratr is offline   Reply With Quote
Old 10-12-2013, 11:45 AM   #22
NFRs2000nyc
My Ride: S2000+Wrangler
I hope you got the email of the two cars involved in the accident so you can email them the video which they can use to prove that the package guy caused the accident.
NFRs2000nyc is offline   Reply With Quote
Old 10-12-2013, 11:51 AM   #23
Xcelratr
In all fairness, package guy is only partially responsible.
If OP was able to stop in time without even getting into ABS, then anyone following him should have been able to, as well. If the Civic had been following at a safer distance or paying more attention, s/he wouldn't have had to swerve into the carpool lane.
Old 10-12-2013, 11:58 AM   #24
NFRs2000nyc
While I agree, the truck caused the situation. Even when following at a reasonable distance, the car in back may not be able to avoid a collision. The OP is driving in a BMW, with exceptional brakes and can stop MUCH faster than a civic (imagine a dump truck was behind the BMW). Factor in reaction time of 1-2 seconds before the civic realized the BMW went pedal to the floor, and there is no way that was going to be avoided. Hell, the BMW was only able to not hit the pickup because of his brakes. If the OP was in something else, he definitely would have hit.
So, I agree with you that the civic made bad choices (driving too closely, unsafely switching lanes) the cause of the accident/situation was the truck stopping in the middle of a highway. The insurance companies would have no problem going after the pickup driver.
Old 10-12-2013, 12:10 PM   #25
dwtaylorpdx
My Ride: 2005 330xi
"Technology will not allow the violation of any of the laws of physics"
Dave
dwtaylorpdx is offline   Reply With Quote
Old 10-12-2013, 12:12 PM   #26
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Damn, close call man.
+1 on having a dashcam. I have the 400G-HD as well
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 10-12-2013, 12:13 PM   #27
Xcelratr
Originally Posted by haurelio View Post
You were very lucky, did they put you on hold??
Probably a transfer. Some 911 centers now answer with "do you need police, fire or ambulance?" and based on the first 5 seconds of info, transfer the call to a second operator to get more detailed info.
I agree that the dumbass in the blue truck is the first domino, esp if OP is correct that the box fell out of his bed and he stopped on a free flowing freeway to pick it up.
But the definition of "reasonable distance" is always going to be something like "far enough back to avoid an accident if the vehicle in front comes to a sudden stop". So if the Civic couldn't stop when OP used 75% braking, that's not a reasonable distance.
The silver Nissan pickup in front of OP stopped and it doesn't appear to use max braking to do it. OP stopped without using max braking. The Civic's failure to do so likely means the driver was following too closely, not paying attention, or both.
Old 10-12-2013, 12:26 PM   #28
Sentaruu
My Ride: Xterra
from what I've seen it's usually both.
Sentaruu is offline   Reply With Quote
Old 10-12-2013, 01:09 PM   #29
cntrvrsy
My Ride: ///M3
Driver in the blue pick-up is an idiot and shouldn't have been in the left lane with all that loose crap in the bed.
cntrvrsy is online now   Reply With Quote
Old 10-12-2013, 01:21 PM   #30
ross1998
My Ride: 2006 G35 Coupe
Keep your distance on the highway!
Here in Seattle it's almost impossible to keep a safe distance, anytime you make a safe distance on I-5 here other cars see it as an opportunity to go in your lane.
ross1998 is offline   Reply With Quote
Old 10-12-2013, 01:28 PM   #31
Darkside213
My Ride: Daily Charger, 01 M3
Although I agree that if the blue truck did indeed drop a box on the fwy, then it did cause the accident, then if I were to take the report, I'd put the civic at fault actually. Per the vehicle code, a person must drive at a reasonable speed in regards to traffic or roadway conditions...in this case, a stopped truck on the highway. Because of this, as many of you have mentioned, you're supposed to give yourself enough space cushion etc in case something like this happens. The civic driver did not do so, swerved into the HOV lane and got creamed. It sucks, but the video does not prove beyond a reasonable doubt that the truck did drop something. However, I'd do everything in my power to write the report as though the blue truck caused the accident and putting the primary collision factor as "other than driver."
"I didn't understand women when I was growing up. God rewarded me with three girls. That's how I came to the conclusion that God is not only female, but a teenager."
Vouch for: nitro3421
Vouches from: nitro3421
Darkside213 is offline   Reply With Quote
Old 10-12-2013, 02:14 PM   #32
Ghostie
My Ride: What else?
You should get the pick-up's license plate from the video and give it the folks involved in the accident. He caused it, and I'm sure their insurance companies will go after him (and rightfully so)
I'm all for keeping a good following distance, but at highway speeds, sh!t can happen pretty quickly when an unexpected variable is thrown in the mix (Flying box)
Ghostie is offline   Reply With Quote
Old 10-12-2013, 03:07 PM   #33
Krizzy TanG
My Ride: E90 and F30 diesel
I have a fist rule to keep half a tacho distance. It's pretty common over here as a rule (not that a lot of People do it, but I do). 130 kph, I keep about 65 meters between me and the car in front (easy to measure since lightpost are 50m apart). 90kph, I keep about 45 m etc. (Europe here, metric system)
http://forum.e46fanatics.com/picture.php?albumid=530&pictureid=11372
Krizzy TanG is offline   Reply With Quote
Old 10-12-2013, 03:38 PM   #34
Freddog
My Ride: 08bmw3series 2ltr
Thumbs Up
Nice driving lads ,I noticed that O p was the only one usein his rear V. Mirrors ,but he only done that because of the R ,t ,a . If you keep A proper distance according to your rate of travel ,your chances of geting home safe are Good ,as long as you keep an eye in yourR V mirrors for the idiot driving to close to. You ,and the one that is trying to Undertake you .the place you are at most risk is a couple of miles from home when you relax . In 2.5 million miles I have found that is the Case ..A's you young cop,s & lawyers. Know the only winners in an r t a case is the lawyer. Safe. Driving.
Freddog is offline   Reply With Quote
Old 10-12-2013, 03:40 PM   #35
eneka
My Ride: 2003 325i
yup, transferred me to the CHP
eneka is offline   Reply With Quote
Old 10-12-2013, 03:48 PM   #36
Freddog
Thumbs Up
People that stop on a freeway anywhere but the shoulder to pick up thAte crap they dropped =
. At last some one using their mirrors .
Old 10-12-2013, 06:08 PM   #37
RidinBimmerz
RidinBimmerz's Avatar
My Ride: Porsche 997 S
Originally Posted by GasKing View Post
Move bitch get out the way. If you see me on the highway get the **** out of my way.
I'm DUI hardly ever caught sober, you bout to get RAN THE FUCCK OVAAA
997S X-51 Pack, PCCB, Full Cocoa leather and MUCH more
RidinBimmerz is offline   Reply With Quote
Old 10-12-2013, 06:41 PM   #38
Xcelratr
I formally request that some day you put the primary collision factor for some accident as "cuz Xcelratr from E46OT said so", please. I look forward to that thread. It will be a great day, with much rejoicing, and fine meats and cheeses.
Old 10-12-2013, 07:06 PM   #39
alphawhiskey
My Ride: Foxtrot
Which dash cam is that?
alphawhiskey is offline   Reply With Quote
Old 10-12-2013, 07:10 PM   #40
Solidjake
Zero. Leaks.
Solidjake's Avatar
Blackvue DR400G-HD
It's not sold anymore because it's outdated by the DR500GW-HD or another brand and model is the Itronics ITB-100HD
