Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 08-08-2009, 11:01 PM   #21
Devas
My Ride: 2011 E90 M3
But it doesn't say E46, jsut says E46 CSL, so im assuming that it only fits what it states.
Devas is offline   Reply With Quote
Old 08-09-2009, 01:28 AM   #22
gaery85
My Ride: 2002 BMW 318i
Originally Posted by hi its me alec View Post
Steel wool or mild sandpaper will do the trick. If it's hard to get in there with your fingers, wrap some sandpaper around the end of a pencil and tape it together, then you can be more precise with it. It just happens when corrosion builds up between the metals and disrupts the electrical current.
Agree with this 100%, but in my case, I just use flat screwdriver & just scratch the whole green areas, works well!
gaery85 is offline   Reply With Quote
Old 08-09-2009, 12:13 PM   #23
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Originally Posted by Devas View Post
Do you have the housing just regular 2005 E46 Sedans? Cause it says it only fits CSL
We can source them for the regular E46 no problem.
Old 08-09-2009, 03:10 PM   #24
Devas
When you do can you please PM me? or let me know some how?
Old 08-09-2009, 03:18 PM   #25
keepinitsimple
Banned
My Ride: 325ci
Ya this reminds me that I have to buy a whole new assembly. haha, yet another project
keepinitsimple is offline   Reply With Quote
Old 10-21-2009, 06:34 PM   #26
aerodmb
My Ride: 2001 BMW 330ci
Where do I go to paint a part like the one below? I'm in Charlotte, NC.
Part # 51 13 8 244 714 Trunk Lid Grip with Key Button (for my 2001 330ci)
aerodmb is offline   Reply With Quote
Old 11-06-2012, 02:43 PM   #27
yonmoor
My Ride: Handbasket
Originally Posted by bigfatvr6prik View Post
Had the exact same issue, ended up getting the new one from Tischer and got it painted from another 50$ (if you get it painted make sure you get it matched as color will be off after 5 years of beating the OE paint has taken). You need part # 13 (not #1 as you stated).
In my case while trying to clean the contacts, they were so brittle, that one bulb holder literally broke into pieces while i tried electrical contact cleaner with a small brush.
Originally Posted by piesfinder View Post
You have to replace the entire trunk handle part....and paint it. I think the part costs about $75ish. I got it painted for $20.
Just out of curiosity, why are you guys painting the new piece instead of just using the existing one over?
yonmoor is offline   Reply With Quote
Old 11-06-2012, 10:07 PM   #28
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
Happened to me. Just take the ghetto route. Remove the trunk lid handle, and try to sand them a bit, just to get the rust off. it'll work for the time being, but it is much easier to get new contacts/ handle.
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
Old 11-10-2012, 07:43 PM   #29
Gepetto
My Ride: 2004 325i
Is this a difficult job to do yourself? Both my plate bulbs are out and the housing is rusted, and the key button doesn't work either.
Gepetto is offline   Reply With Quote
Old 10-13-2013, 01:17 AM   #30
Slick-Vic
My Ride: 2003 BMW M3 Tiag
Anyone have a solution for this? I dont want to buy the whole trunk lid just because from the wire to the metal prongs are rusted threw. Looks like I will have to cut off the curroded wire and test for power. Driver side bulb has 4 wires, passenger side has 3, it doesnt make sense to me how the wiring goes? Need some help. Hard to find the metal clips that are soldered onto the wire. the smallest ones I can find are still too big. Is there a led kit available for me to connect right from the wires and replace that whole rusted casing?
CF TMS cold air intake/UUC Rasp-x section I/StopTech stage II brake kit slotted rotors, SS brake lines/3 pc. AC Schnitzer rear spoiler/CF rear diffuser/Iforged Aeros 19x8.5x10/Smoked corners/Smoked EE LED tails/Matte Black kidney grills/Matte Black gills/Painted reflectors
Slick-Vic is offline   Reply With Quote
Old 10-13-2013, 01:25 AM   #31
Slick-Vic
Help me fix this problem!!!! Last thing I need to do to pass inpsection. I had a headlight out, turns out to be a ignitor seeing i had my headlights in pieces I finally got around to installing some angel eyes : ) Any ideas on fixing my rear licence plate bulbs?
Old 10-13-2013, 01:28 AM   #32
Gepetto
My Ride: 2004 325i
Hey Sick-Vic, the only real solution is to get a new trunk lid lip (the piece that contains the plate lights and the button for opening the trunk when the doors are open). You can get it at a fair price at a bunch of online dealers (I used BMW South Atlanta). And, it's a fairly easy install (less than 1 hour) and you should be able to reuse the wires that are inside the trunk lid - those never rust out. Once you're done, it'll be as good as new. There's a post somewhere on the forum of someone doing it with pictures and other advice. But, it's fairly simple procedure.
Old 10-13-2013, 11:11 AM   #33
Slick-Vic
Hey Gepetto,
If you see in my first picture the metal prongs that come from the wires 2 out of the 4 are rusted threw. Plus the plate lights that you are referring too, one of them is rusted thrrew as well. Even if I replace the trunk lid I still have to fix the wiring to plug it into the piece that contains the plate lights.
Old 08-11-2014, 06:48 PM   #34
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Originally Posted by Slick-Vic View Post
Hey Gepetto,
Is there a way to separate the light holders from the painted trim (like the ECSTuning picture below) ? I noticed the replacement kits have all the parts separated but on my car it seems to be glued together. I don't want to pay extra to paint a new trim if I can just separate them and reuse my current trim.
Originally Posted by Edison@JleviSW View Post
Might as well upgrade to LEDs if you are going to replace the housings. I recommend the Xenon White LED License Plate Light Housings we carry which are a complete replacement with built in LEDs.
On pre-2006 cars his does not fix the issue by the way. I tried two kits and no workie. The kits still need the rusted contacts to not be rusted and old to work.
delmarco is offline   Reply With Quote
Old 08-11-2014, 07:12 PM   #35
Gepetto
My Ride: 2004 325i
I know you can get that trunk lip all in one piece - you have to ask for it specifically. As far as the wiring, if the wires inside the trunk are rusted, I don't know what to say on that. The wires in the trunk lip will be new, but if everything else is rusted then it might be a more difficult job.
Old 08-15-2014, 07:15 PM   #36
delmarco
First to answer my own question: The original factory trim is one piece that seems permanently glued together. So even if you buy the replacement trims in separate pieces you CANNOT swap in the the new light holders onto your original painted trim. You have to use the new trim cover AND get that painted. Which isn't cheap ($50 to $300) when done right.
Now onto how I fixed the issue and my praise to SNA77 and everyone in this thread that saved me a lot of money:
When my plate lamps went out my inside of the light housing looked just like SNA77's when I removed the lamp covers.
I was ready to pay $150 to get the new trim (w/paint) but decided to try my luck with a brush, nail file, and a $4 can of Electrical Contact Cleaner spray.
After few minutes of spraying, filing, brushing, spraying and drying out the contacts everything was new and working again. I even cleaned out the rear fog lamp contacts so now everything is working back there!
Thanks guys!
Old 08-24-2014, 09:13 PM   #37
ELCID86
My Ride: 2004 330i (ZHP) x2
License plate light out - rusted carrier
Nice work. Just so you the cover can be removed. There are 6 tabs and some adhesive holding it together. Use a heat gun and non marring pry tool. Start on either end.
iPad and BimmerApp
Shawn in VA (USA).
- Shawn's 2004 IR/Alc. w/6MT ZHP (1/351 built)- http://bit.ly/1nhx4gk
- 2004 OB/Sand w/6MT ZHP (1/25 built)- (sold)
- 2004 OB/NB w/AT ZHP- (sold)
ELCID86 is offline   Reply With Quote
Old 08-24-2014, 09:15 PM   #38
ELCID86
Sorry I deleted all but one picture off my phone.
iPhone and BimmerApp
Shawn in VA (USA).
Old 08-29-2014, 11:05 PM   #39
Nelson
Nelson's Avatar
My Ride: Alpin weiß ///M
On a side note, I see that you drilled a hole for the rear-view camera, you may want to seal that from the inside... that might also expose elements into the light bay.
///M
| eBay mod'ing sUUCks
Nelson is offline   Reply With Quote
Old 04-16-2015, 02:03 AM   #40
Feitner
My Ride: 2002 325xi
Question
Okay I ran into the problem and when i had purchased my 325xi there were no covers so the bulbs were getting eaten away during the winter. About 3 weeks ago when i was hanging out with some of my friends i went to go show them the sub i just put in and i see smoke? thinking it was the exhaust and the cold air i thought nothing of it until i went to open the trunk and there was an electrical fire from the right bulb and it just kept burning until i didnt hear it sizzling anymore. Car still runs fine and no electrical issues but was wondering if thats something where i have to go and get a whole new latch assembly or just a headlight mount for it. I Plan on taking it apart in the next few days hopefully to see the damage done. Someone please help
Feitner is offline   Reply With Quote
