///M3 Forum
Old 10-09-2013, 08:36 PM   #1
M3 boyzky
My Ride: 2006 M3
Clown nose not flashing after battery disconnect.
I replaced my steering wheel trim the other day and disconnected the negative terminal off the battery post. I noticed afterwards that the clown nose isn't flashing anymore when I lock the car by remote. I don't have an alarm, but the PO had it programmed to flash when locking. Is this something that needs to be reprogrammed every time the battery is disconnected? I don't think so, but I could be 100% wrong. Just wondering why it happened. Any ideas?
M3 boyzky is offline   Reply With Quote
Old 10-10-2013, 08:21 PM   #2
M3 boyzky
My Ride: 2006 M3
Bump! Any ideas?
Old 10-15-2013, 05:48 PM   #3
stolidog
My Ride: 2004 M3 6spd
Have you driven the car since then? I noticed that my car doesn't seem to work right after a the battery has been disconnected until i finally start it up.
stolidog is offline   Reply With Quote
Old 10-15-2013, 08:09 PM   #4
M3 boyzky
My Ride: 2006 M3
It's been almost a week now since I disconnected / reconnected the battery and it's still not flashing. I've been constantly keeping an eye on it all this time, but still not doing it. Does this mean I have to go to the dealer to get it reprogrammed? Will this be an issue again next time I disconnect the battery? What has bee your experience?
Old 10-16-2013, 10:24 AM   #5
stolidog
My experience is that everything is ok after reconnecting the battery and restarting the car.
Random thought, how old is your battery and/or have you had it checked recently? I say that because when my battery started to go, weird things started to happen with the electrics.
Old 10-16-2013, 01:45 PM   #6
M3 boyzky
My Ride: 2006 M3
You got a point with the there with the battery, stolidog. I really don't know how long has the battery been on the car 'cause it was already there when I bought the car more than a year ago. Perhaps I should have it check first. Thanks! :-)
