///M3 Forum
Old 10-17-2013, 08:51 AM   #1
Cayne23
My Ride: 2002 m3 convertible
Rotors?
Looking for front brake rotors. I want blanks. I dont like drilled or slotted. Any suggestions? I dont need high performance either. Advance auto has wearever for 42.99. Bav auto has their brand, coated like the oem's for 59.95 each, no warranty.
Cayne23 is offline   Reply With Quote
Old 10-17-2013, 11:31 AM   #2
Cayne23
Re: Rotors?
Oops I meant 69.95 each from bav auto. Any suggestions
Old 10-17-2013, 11:51 AM   #3
Alan
Alan's Avatar
My Ride: 2006 M3
Why not OEM blanks?
Alan is offline   Reply With Quote
Old 10-17-2013, 12:33 PM   #4
Cayne23
Re: Rotors?
Bav auto has then for 129.95 each. Thats too much right now.
Old 10-17-2013, 12:39 PM   #5
Cayne23
Re: Rotors?
Also I will say this. Looking through my rim down at the pads, it looks like tge pads arent fully seated against the rotor. And I can see on the rotor that a wear mark is only close to the center. About 1 inch wide. Like the complete pad usnt hitting the rotor
Old 10-17-2013, 01:42 PM   #6
Alan
Alan's Avatar
My Ride: 2006 M3
Bed them.
Old 10-17-2013, 02:05 PM   #7
Cayne23
Re: Rotors?
I did bed them correctly. One thing I've noticed from looking at the diy's, trying ti see if I messed something up. I took off the entire caliper, undid the 2- 16mm bolts. Then I seperated the carrier. Wiped off the guide pins and lightly greased them with hi temp disc brake grease. I see other ppl just pulled off the rubber caps and unscrewed the guide pins, wiped them off no greasing. I wonder if my pads are sticking in the slots. Have driven 200 miles since install
Old 10-17-2013, 02:23 PM   #8
choxor
My Ride: JDM
Exactly what grease did you use on the guide pins.
Old 10-17-2013, 03:07 PM   #9
Cayne23
Re: Rotors?
Hi temp disc brake grease. Comes in an orange tub
Old 10-17-2013, 03:10 PM   #10
Cayne23
Re: Rotors?
Uh oh, homer moment, lol. I actually think its high temperature disc brake bearing grease
Old 10-17-2013, 03:10 PM   #11
Cayne23
Re: Rotors?
Dark grey in color
Old 10-17-2013, 04:58 PM   #12
Alan
Alan's Avatar
My Ride: 2006 M3
I believe the correct stuff is high temp ceramic brake parts lubricant.
Old 10-17-2013, 05:21 PM   #13
Cayne23
Re: Rotors?
Yes. I have used this stuff in the past. Im going to take everything apart and redo on saturday
