Old 10-08-2013, 12:06 PM   #1
Fkn330i
My Ride: 2001 330i
(Project) black 330i
Thought I'd start a thread to document the progress of my 2001 M-sport (zsp) 330i. Bought the car with just over 107k miles on it, appeared to need nothing immediately although I planned on some maintenance items.
Goals for this year :
coilover setup
get rid of amber lights
get rid of wood trim
short shifter mod
lightweight flywheel & new clutch
window tint
will post photos soon. The last week or so I've spent buffing and polishing so theres compound in all the nooks and crannies on the car to clean out before i can get some clean photos. Also did vapor barrier repair already and figuring out a fast blinker right after i complete this paragraph!
Fkn330i is offline   Reply With Quote
Old 10-08-2013, 02:07 PM   #2
Fkn330i
My Ride: 2001 330i
hope IMG tagging works on this forum. this is the day i brought it home
Old 10-08-2013, 02:11 PM   #3
Fkn330i
My Ride: 2001 330i
panasonic rechargeable battery had to be soldered in and reglued the fob.
held it together until the glue dried
Old 10-08-2013, 02:12 PM   #4
Fkn330i
My Ride: 2001 330i
vapor barrier repaired both drivers side doors, someone had seriously ****ed the front.
Old 10-08-2013, 02:12 PM   #5
Fkn330i
My Ride: 2001 330i
how nice the water beads up after a fresh buffing
Old 10-10-2013, 05:09 PM   #6
toze777
My Ride: 320D ( E46)
body what u going to replace the
1) amber lights and wood trim with ?
toze777 is offline   Reply With Quote
Old 10-12-2013, 09:54 AM   #7
Fkn330i
My Ride: 2001 330i
Plan on brushed aluminum wrap on the trim. Smoked lenses for the ambers up front and rcr for the tails
Old 10-17-2013, 10:09 AM   #8
Fkn330i
My Ride: 2001 330i
Ordered carbon fiber vinyl yesterday, see how it goes
Old 10-17-2013, 11:29 AM   #9
NoGuru
My Ride: 2002 330ci
Should look nice, good luck.
NoGuru is offline   Reply With Quote
Old 10-17-2013, 12:47 PM   #10
Fkn330i
My Ride: 2001 330i
boom
Old 10-19-2013, 02:14 PM   #11
jskin1510
My Ride: 08 335xi
I def like where you're headed so far with the one. funny I did the same exact things the first month I had the car. Painted the grills black within first few days but couple of the clips were broke so I bought a set of black ones. started on the interior trim doing a couple pieces at a time and I chose silver carbon fiber on black interior. TiAg exterior. had clear corners they were ok but I like smoked better on Silver. Tint was probably done the 2nd month i had it. Also had my wheels off my e36 to swap on right away so that helped. Then a few more things here and there of course. On black I like the look of red/smoked/red if you haven't purchased already. either will look good. just my $.02. Nice car and good luck. I miss having a black BMW.
jskin1510 is offline   Reply With Quote
Old 10-21-2013, 07:51 AM   #12
Fkn330i
My Ride: 2001 330i
well I havent pulled the carpet up yet but I think I still have a leak. #%$@!
in other news, where is the best place to find new vapor barriers?
Old 10-22-2013, 06:51 PM   #13
Fkn330i
My Ride: 2001 330i
Old 10-23-2013, 09:29 AM   #14
Fkn330i
My Ride: 2001 330i
Key fob repair $8
Welded exhaust hanger $0
Blacked out all trim $14
Carbon fiber vinyl wrap $11
maybe I should order suspension now?
maybe I should wash my car now.
Old 10-24-2013, 08:58 PM   #15
Fkn330i
My Ride: 2001 330i
Super dirty wheels but I rinsed the rest off.
Old 11-04-2013, 07:49 AM   #16
Fkn330i
My Ride: 2001 330i
I ordered a drivers door vapor barrier, thinking the extreme tears in it had to be the cause of my trouble. Then I found the real cause.
Water is filling the abs/dme compartment in the engine bay, coming through the wiring harness, along the front door sill and depositing mainly in the back seat floor well. **** my life. So I'll be cleaning drains today...
Old 12-09-2013, 12:54 PM   #17
Fkn330i
My Ride: 2001 330i
New rear meats. 255/40r17 lil bit wider ill bit taller sidewall matches the front better. No abs problems, no trac problems. I shut trac off all winter anyhow. Also no rubbing. Will see how it looks once I get some spacers and lowering kit.
Old 12-23-2013, 12:43 PM   #18
tlester
My Ride: 2001 330i
Looking good. Following.
tlester is offline   Reply With Quote
