Old 09-01-2013, 12:41 PM   #1
masterpug
My Ride: 2001 325i
Gas leak
So...close to year ago i fill up tank on my e46 2001 325i sedan...goto store...
Come out adn find gasoline POURING out over rear axle...like a hose was running....
Lose half a tank....come to find i can fill it halfway no prob..maybe 2/3 but hit 3/4 and it would pour out.
Ive been told to look at tank would require dropping it to look at top part etc...and to drop tank means dropping exhaust...which means $$$$
fast forward to 3 days ago...wife take s my car...and FILLS TANK...she never fills her car even when lite on but....anyway...didn't leak?!?!?!
Any ideas? car has no ( obvious ) rust on it...almost down to half a tank now no leak...
thanx
masterpug is offline   Reply With Quote
Old 09-14-2013, 06:30 PM   #2
masterpug
My Ride: 2001 325i
so anyone have anything similar happen to them?
Old 09-16-2013, 08:05 PM   #3
lszlszx
My Ride: 1.8T, XC70
Have you done a visual inspection? Some of the fuel hoses, or connections might be loose at that 1/2, 3/4 level around the tank.
It can't leak from the top, that doesn't make sense, the shop must have said that to make $$$.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 09-16-2013, 09:45 PM   #4
Sansho
My Ride: 2001 325i
You didn't say, however, that can happen when the fuel pump is replaced, and the rubber seal is installed wrong, so it doesn't seal. Have that done recently?
Sansho is offline   Reply With Quote
Old 10-29-2013, 04:22 AM   #5
jfp2999
My Ride: 325ci
i agree
yeah I agree take off rear seat and passenger side is what oyu want to check. take off that cover and this is for sure where it is leaking/. need to seal the fuel pump housing right may even be completel y loose
jfp2999 is offline   Reply With Quote
