E46 Xi Forum
Old 11-09-2013, 08:29 PM   #1
ladueit
My Ride: 03' 325 xi, 5 speed
First time BMW owner, No Start full electric power
Hello all,
I've had my '03 325xi for 3 months or so. I really like it, thought I could handle it but now I have this no start issue that is beyond me.
The first sign of a problem was six weeks ago. I was starting the car and noticed it to longer to start, was slow to turn over at first. Started we went to the store. When I went to leave, we got nothing from turning the key. The parking lot was on a hill so I tried roll starting it backwards. It didn't work but just as I was about to call for help. It started right up.
I honestly forgot about the whole thing until Monday of this week. Boom. No start again. Acts like it has full battery power, dash acts normal. But no click, no buzz, no nothing when you hit the key coming from the engine compartment. I live of a hill so I roll started it a couple days ago. Other than smelling highly of gas it was fine. But still won't start.
What I've tried:
Jump start, giggling of various wires, some black fuse box under the hood which held a small black box that has 5 small fuses. All fuses appeared good.
What I think may cause:
Bad starter (usually makes noise)
Bad battery (tried to jump start)
Bad EWS (have no idea)
Bad key ( I only have one master and the valet key, which I can't find)
Bad switch on clutch
Man that list is terrible.
I appreciate any help.
Enjoy your weekend.
ladueit is offline   Reply With Quote
Old 11-09-2013, 09:23 PM   #2
zander271
My Ride: 6spd ZHP/5sp XI
Can you hear the fuel pump prime when the key is turned to position 2?
Typically if I don't hear that and I can't roll start the car it is the fuel pump that died.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 11-09-2013, 09:36 PM   #3
ladueit
Re: First time BMW owner, No Start full electric power
Roll starting is fine. Can hear the pump
Alaska, Ducks, BMW
Old 11-09-2013, 10:29 PM   #4
Eddie_
My Ride: 2005 330xi
Sounds Like the starter same thing happened to me might wanna take it to BMW stealership on E 5th I had to go there a few times when I lived in Muldoon
Eddie_ is offline   Reply With Quote
Old 11-10-2013, 08:55 PM   #5
ladueit
Guess that's the plan. Hopefully the bill is no more than $850. I can't really afford that. Without a garage and our first snow fall it's not a DIY project
Alaska, Ducks, BMW
Old 11-10-2013, 08:55 PM   #6
ladueit
Can you damage the car roll starting in the cold?
Alaska, Ducks, BMW
Old 11-10-2013, 11:08 PM   #7
jmo69
My Ride: 03 325xi 98 328is
Roll starting shouldn't hurt the car, I had the starter replaced in my e36 at an indie shop last winter and it ran me about $300 IIRC for a reman. Bosch.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 11-11-2013, 01:54 AM   #8
ladueit
Damn i called acurate import and they quoted 850
Alaska, Ducks, BMW
Old 11-17-2013, 07:02 PM   #9
Nugetchew
My Ride: 03' 325xi
i had to get it done few weeks after i bought my car dont take it to the dealer. I remember their quote being double what i paid at bmw specialist. i think i paid 600 with a bosch replacement; still a bit high but i had to get it done fast. i suggest taking a look at how old your battery is too..i just replaced mine and it was mfd in 2011. it cost me 265 taxes in at the dealer and that was with a discount.
Nugetchew is offline   Reply With Quote
Old 11-17-2013, 08:41 PM   #10
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Unlike many car staters that sort of tell you when they are going bad, the staters in this car will just "give up the ghost" without much prior warning. You can purchase a new Bosch on Amazon for much less than the same starter will cost you from a dealer and most other BMW Parts companies and it will be brand new and with the same warranty. Having saved a bundle on the price of the starter, you can take the car and starter to either a BMW Dealership or a trusted Independent BMW Repair station and have it installed. If they want to re-place the starter by removing the Intake Manifold, go else where, that is the most expensive way (also the way the Bentley Repair Manual and BMW Manual tell you to do. THe quickest way is to do it from underneath the car by slightly dropping the sub-frame (supported of course) so that you can reach up and disconnect the wires and the starter, the starter will just have enough clearance to be removed and the new one slide in place. In a shop, it reduces the time from 8 hours to less than 4. Automatic Transmissions take a little more time than Manual Transmissions (ask me how I know since I have one of each type).
tomoyer is offline   Reply With Quote
Old 11-18-2013, 08:47 PM   #11
7xWDC-MSC
My Ride: 2005 325xi
Originally Posted by ladueit View Post
Hello all,
What I've tried:
Enjoy your weekend.
That tells me the solenoid was giving out, sounds like a new starter is in order. Are you handy. Can you DIY this?
Rubs the roundel on its skin or else it gets the hose again.
7xWDC-MSC is offline   Reply With Quote
Old 11-20-2013, 06:14 PM   #12
ladueit
It's done. The starter was the problem. Thanks for everyone help. I took it to the shop and got an OE starter installed
Alaska, Ducks, BMW
