HPF E46 turbo Grassroots Support - Page 7 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-13-2013, 06:37 PM   #121
E46 4m3
My Ride: 2003 M3
Does anyone know where i can buy molex pins that the aem uses. I want to wire in my 2step that is pre programmed on pin b40.
E46 4m3 is online now   Reply With Quote
Old 12-13-2013, 11:38 AM   #122
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
They are AMP pins....I previously thought they were molex and was my mistake. I'm looking at sourcing them and will let u know... There r literally thousands of types
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 12-13-2013, 11:08 PM   #123
being3
Modded ///Member
being3's Avatar
Working with another HPF fanatic here r the pins and connectors.
Old 01-05-2014, 03:43 PM   #124
being3
Modded ///Member
being3's Avatar
I'm working on something new with DME for HPF Cars.
I'm working on disabling the error codes in the DME that r specific to HPF AEM V1 Generation 1 & 2 cars. That way we can benefit from:
- Eliminate Dash led and when a real code comes up we can rely on dash led to indicate any other problem.
- allow GT1 / Autologic tools to run test routines without faulting because of error codes
- pass regular visual and scan based safety inspections which most require no engine led to pass (not including emissions test)
- remove all the factory 02 sensors to clean up and simplify the wiring and eliminate potential shorts etc...
I'll also have the dyno mode activated for 8000rpm, sport button recall last memory, shift lights for manual trans, speed limiter set to 200mph, sport button comfort and sport tables revamped for more aggressiveness.
Also able to modify DME for SMG to manual conversions.
I have modified my DME accordingly but need to test it... Cars apart for more mods at present so it will be a little while. I'll post back with results when verified. Pretty sure it's going to be a go
Old 06-16-2014, 09:49 AM   #125
being3
Modded ///Member
being3's Avatar
Jumperbox shorting problems
[ame="
Old 05-13-2017, 05:17 AM   #126
red375
My Ride: //HPF E46 M3 stg2
Anyone had the following problem before for HPF stage 2?
On WOT engine cuts at 6k RPM like its in limp mode..
A/F ratio seems ok its between 13.5 to 14
Vacuum seems ok its between 18 to 20
Fuel pressure at idle is 3 BAR
Map sensor is new
Any thoughts ?
13 Tiguan R-line 4motion- Black
05 //HPF E46 M3 stg2- Carbon Black
95 Trans Am- Red
red375 is offline   Reply With Quote
Old 05-13-2017, 08:42 AM   #127
being3
Modded ///Member
being3's Avatar
Is the afr 13-14 at 6k?
Old 05-13-2017, 01:00 PM   #128
red375
It's at idle , I didn't notice it at 6k.
Is is it bad coils or spark plugs?
95 Trans Am- Red
Old 05-13-2017, 01:05 PM   #129
being3
Modded ///Member
being3's Avatar
Most likly. What's the gap
On the plugs?
Old 05-13-2017, 01:42 PM   #130
red375
I installed them new 2 months ago
Bought NGK set
https://www.ecstuning.com/b-ngk-parts/spark-plugs-set-of-six/dcpr9eixkt/
Old 05-13-2017, 08:05 PM   #131
being3
Modded ///Member
being3's Avatar
Bought NGK set
https://www.ecstuning.com/b-ngk-part...ix/dcpr9eixkt/
Ixu24 gapped at 24 ... not sure about the plugs or the gap u r using.
Old 05-14-2017, 01:03 PM   #132
red375
Thanks, so the Ixu24 would work great on HPF stage 2?
95 Trans Am- Red
Old 06-12-2017, 01:30 PM   #133
red375
I changed the coils and plugs and still have the same problem any thoughts ?
95 Trans Am- Red
Old 06-13-2017, 12:25 AM   #134
being3
Modded ///Member
being3's Avatar
Is ur AEM unlocked ?
Old 06-17-2017, 06:10 AM   #135
red375
Solved the problem the fuel pump filter was dirty.
95 Trans Am- Red
