Replace springs when installing Koni sport shocks? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-20-2013, 08:26 PM   #1
k_h_d
My Ride: 330i ZHP, MINI JCW
I bought a 2004 330i w/ ZHP. It has 63,000 miles and I am going to install Koni yellow sport shocks sometime this winter. I may autocross the car a little and prefer to run in stock (or now street) class. That means I have to stay with stock springs.
Would my current ZHP springs be fine or should I replace those when I put on new shocks?
k_h_d is offline   Reply With Quote
Old 11-20-2013, 08:28 PM   #2
bimmernate
My Ride: 2003 330i ZHP
your current springs are most likely fine, just inspect that there are no cracked/breaks and you are good to go.
2003 330i ZHP 6MT
Performance: Koni Sport Struts/Shocks, Eibach Pro-Kit, 17x9 Apex ARC-8, TMS F&R Sway bars, M3 RTABs w/ Vorshlag Limiters, M3 Strut Brace
Aesthetics/Functionality: TFX Projector retrofit by lightwerkz, 20% Tint, OEM Aux Input, Clear corners, LED taillights, M3 Steering wheel, Black kidney grills, mobius dash cam
bimmernate is offline   Reply With Quote
Old 11-20-2013, 08:30 PM   #3
tock172
My Ride: '12 135i Dinan S2
Reusing your current springs is fine. Unless they are rusted, collapsed, or broken towards the bottom (it happens on some E46s) then they are just fine. However if you're upgrading your dampers to those nice Koni single adjustable units, you might want to consider a set of Eibach or H&R springs. Dinan actually makes a package deal with Koni dampers and Dinan springs.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 11-20-2013, 08:30 PM   #4
Encryption76
My Ride: 2000 328i
Send a message via MSN to Encryption76
Does the car sit level? If you bounce the back/front do both sides bounce pretty even? If yes then your springs are probably ok.
Encryption76 is offline   Reply With Quote
Old 11-20-2013, 08:34 PM   #5
k_h_d
I would but then the car is no longer in the street class for auto crossing. Last year i was very competetive regionally with my MINI and I am debating if I am going to run the MINI next year or move to the BMW. They are both in the same class actually.
Any comments on Koni FSD vs the sport shocks?
Old 11-20-2013, 08:35 PM   #6
k_h_d
The car sits level and rides fine I am just looking for a little stiffer shock. I was not sure if a 9 year old spring would have lost any effectiveness. There is very little if any rust at all.
Old 11-20-2013, 08:54 PM   #7
tock172
I understand completely. The modifications I did to my 330i also bumped me into the 6 Cylinder modified class when I used to be in 6 cylinder stock class - whole different ballgame.
From what I've heard and read, FSDs are very good dampers, but they're expensive and some people claim they make the ride almost too 'supple.' If I were in your shoes, I would either stick with the Koni single ajustable yellow sport dampers or look into Bilstein sport dampers.
Old 11-20-2013, 09:45 PM   #8
Zell
Zell's Avatar
My Ride: so turbo wow
No reason to replace springs unless they're broken. The rear springs are the biggest culprits. Look very far down into the cup, if you find that the lower spring is broken then you'll need a new one. It might be difficult to see, so compare sides. Look especially for rust on the end. This is a pretty tell-tale sign that it broke at some point.
