Thread Tools Search this Thread Rating: Thread Rating: 54 votes, 4.80 average. Display Modes
Old 11-27-2013, 04:50 PM   #401
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by RyanTosi View Post
Just read through this entire thread and all I have to say is wow. This motivates me to want to save up and do this to my 330!
Glad you enjoyed it. As for as saving up, this build has been very expensive...to the point of questioning my sanity. You could buy an E92 M3 for less....
Originally Posted by BoostedZHP View Post
OH NO Adam
It will be resolved in time.
Originally Posted by MC330CI View Post
Good to see her on the ground Adam.
Puts a smile on my face every time I look at it. Looking forward to driving it next spring...and working on it over the winter in my new shop.
Originally Posted by unevolved View Post
I love this kind of build quality. Good to see you're still powering through it.
Thank you.
Old 11-27-2013, 05:48 PM   #402
Commanderwiggin
My Ride: 900rwhp Turbo M3
...and you said nothing?
What a jerk!
Well I didn't know in the preliminaries lol just the ones you just posted
But looks like you're making some solid headway! Can't wait to see the whole garage finished and that car rolling with the new charge and wg setup!
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 11-27-2013, 05:53 PM   #403
HBizzo88
My Ride: 2002 bmw 330ci
Technique Tuning Stage 1 Turbo on an automatic
I have the same kit on my 330ci manual.
HBizzo88 is offline   Reply With Quote
Old 11-27-2013, 06:48 PM   #404
mdrobnak
My Ride: 04 330i SMG TT STG1
Good to see things are materializing, Adam. Mine's running, but the next stages are going at about the same pace. :-/ I hope things work in your favor moving forward.
-Matt
mdrobnak is offline   Reply With Quote
Old 12-06-2013, 07:27 PM   #405
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
It's home.
Old 12-06-2013, 07:39 PM   #406
mdrobnak
Nice.
If it's like any other garage, that will fill up shortly.
-Matt
Old 12-07-2013, 05:26 AM   #407
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Originally Posted by mdrobnak View Post
Nice.
-Matt
This is the 2nd garage at home...we already have that problem else-ware...
Old 12-07-2013, 06:08 AM   #408
indoafro
My Ride: 325ci
really curious about oil cooler setup, where did u get that lil cooler setup ?
indoafro is offline   Reply With Quote
Old 12-08-2013, 06:08 AM   #409
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Both the Engine and Transmission coolers are from BAT.
http://www.batinc.net/coolers.htm
They are 235 series / 25 row.
Old 12-10-2013, 02:10 PM   #410
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Nice.
-Matt
Well that didn't last long...
Old 12-10-2013, 02:15 PM   #411
mdrobnak
Impressive. 4 Days.
At least you're organized.
-Matt
Old 12-10-2013, 02:17 PM   #412
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 12-10-2013, 02:21 PM   #413
Commanderwiggin
Lol
Old 12-10-2013, 04:43 PM   #414
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Hard to believe I spent over 7 years in here:
Old 12-22-2013, 11:15 AM   #415
Herrubermensch
My Ride: E39 M5 and E46 M3
Adam, thank you for directing me to this thread. Exactly what I look for as entertainment and education on a Sunday morning (or any morning for that matter!).
As you know, I'm deep into an M190 installation on my E39 M5 and was contemplating integrating an HFS-6 controller that I used on my previous setup with the M190. Your thread has made me realize that is likely gratuitous--that everything I need to run 100% meth injection is already well within the M190's abilities. Certainly, the M190 can provide IDC and boost-referenced control of the Aquamist pump (I have a Howerton setup as well that Jeff and I configured for the tire-goo cubby in the E39 M5) as well as direct fail safes. I can't see any reason not to delete the HFS-6 controller altogether and control the HFS-6 valve with the Motec. Is this the route you are pursuing or something different?
In any event, a truly delightful thread. More power to you. It is precisely endeavors such as yours that make this hobby so compelling and enjoyable.
--Peter
Herrubermensch is offline   Reply With Quote
Old 12-22-2013, 11:40 AM   #416
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
--Peter
Peter,
Yes, I believe the M1 series can easily take over for the HFS-6 controller.
What I'm planning to do is run 2 channels of fluid injection: Pre-turbo, and pre-manifold.
The pre-turbo channel will be controlled by a 4D table with compressor speed and MAF defining the X/Y axis, and the 4th parameter being a corrector for ambient air temp.
The pre-manifold channel will be controlled by a 4D table with MAF and IAT defining the X/Y axis, and the 4th parameter being a corrector tied to EGT.
Flow sensors would be tied to each channel to aid in tuning, and for safety measures. There of course would be a level switch on the tank, and I've also been considering running a closed loop PWM output based on fluid pressure to drive the pump. However to start with, I think I'd just run the pump wide open.
If you are interested in this, we probably could work together on "Build" files. Although I'm unsure what my development timeline is going to be like....
I also have Boost Control, Transmission Control, and Nitrous control modules planned. But to start with I think I need to get a CAN sniffer up and running; there is a lot of a really good stuff that the OEM hardware does that I'd like to keep and tie into the Motec via CAN.
Old 12-22-2013, 12:06 PM   #417
Herrubermensch
Peter,
Thanks, Adam. Are you retaining the control valve mechanism from the HFS-6 or creating a control valve from scratch? Would be delighted to work together on the M1 build files. Let me solicit some input from Neel Vasavada on that and get back to you. I probably won't be finalizing my setup in that regard for a number of months, though my goal is to have it done and up and running for shakedown by the end of April.
--Peter
Old 12-22-2013, 01:11 PM   #418
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
--Peter
Sorry yes...the Aquamist Control valves are used, with a PWM frequency of 30hz.
I also have WON valves that can be pulsed up to 50hz and flow a bit more....but I think they are overkill for this application.
Old 01-04-2014, 05:50 AM   #419
zaharias
My Ride: M3 E46 6MT 3/2005
Thumbs Up
Amazing work and skills man!!
Well done!!
I wanna see videos of the car running/accelerating..!!!
zaharias is offline   Reply With Quote
Old 01-04-2014, 11:47 AM   #420
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Hello Motec
