Thread Tools Search this Thread Rating: Thread Rating: 778 votes, 4.96 average. Display Modes
Old 11-15-2013, 05:34 PM   #241
kariml
My Ride: M3
This is a great list of resources, thank you
kariml is offline   Reply With Quote
Old 12-02-2013, 07:34 AM   #242
Chadsere
My Ride: 2000 BMW 318i
* E46 Information Thread - Parts/Mods/DIY *
Originally Posted by element View Post
Well I've been stockpiling this stuff so I thought I'd share. Content is something you have all probably come across but I'm serving it up in one location. It's not exactly everything you would want to know just a bunch of stuff I like to keep handy and a lot of stuff that people seem to ask about before searching.
Feel free to add, but keep down the clutter and the OT and ask questions elsewhere.....Then again, do what you want.
-D
Best places to buy mods
http://forum.e46fanatics.com/showthread.php?t=324495
HOW TO tell if its real leather. PIX
http://forum.e46fanatics.com/showthread.php?t=391726
Props to a great site
http://madrussian.net/
BMW DIY Lists
http://www.bimmerdiy.com/e46
http://www.pelicanparts.com/BMW/tech.../tech_main.htm
http://www.civil.ubc.ca/home/bohnen/adventures2.html
http://www.ultimate-bmw.com/bmw_know...aster_link.htm
BMW DIY PDF Files
http://www.openbmw.org/downloads/
Transmission and differential change
http://www.bmw325i.net/maint_tran_fluid.shtml
http://www.bmw325i.net/maint_rear_diff_fluid.shtml
Led Taillight Info
www.koperformance.com
http://forum.e46fanatics.com/showthr...ight=taillight
http://forum.e46fanatics.com/showthr...threadid=88439
http://forum.e46fanatics.com/showthr...hlight=led+diy
ablas
Jack Points
http://forum.e46fanatics.com/showthr...ght=jack+point
Garage Boy
http://www.garageboy.com
DIY Oil Extractor
http://forum.e46fanatics.com/showthread.php?t=254289
Control Arms
http://forum.e46fanatics.com/showthread.php?t=271637
http://www.e46fanatics.com/features/...php?news_id=40
Order Parts
http://www.bmaparts.com/
Bed Those Brakes
http://www.zeckhausen.com/bedding_in_brakes.htm
Sputtering...there are many more
http://www.bimmerfest.com/forums/sho...ght=sputtering
Reset Service Indicator
http://www.bimmerfest.com/forums/sho...vice+indicator
Window Regulator DIY
http://forum.e46fanatics.com/showthread.php?t=104035
http://forum.e46fanatics.com/showthr...ight=door+trim
Change your spark plugs
http://www.e46touring.com/installs/index.html
http://www.bimmerfest.com/forums/arc...p/t-65380.html
View in text e46fanatics/bimmerfest
http://forum.e46fanatics.com/archive...p/f-4-p-1.html
http://www.bimmerfest.com/forums/archive/index.php/
OBDII Fault Sensor Codes
http://forum.e46fanatics.com/archive.../t-303141.html
Handy suspension links from JPR
Thanks JPR!
Handy Links
Alignment Info
http://forum.e46fanatics.com/showthread.php?t=416660
ZHP Suspension Info
http://forum.e46fanatics.com/showthread.php?t=439450
My Suspension Upgrade
http://forum.e46fanatics.com/showthread.php?t=404376
Swaybar Info
http://forum.e46fanatics.com/showthread.php?t=398828
BMW Spring Info
http://forum.e46fanatics.com/showthread.php?t=397880
Brake Rotor Info
http://forum.e46fanatics.com/showthread.php?t=449052
Ski Bag retrofit or removal
http://forum.e46fanatics.com/showthr...ht=remove+seat
Ski bag PDF
http://www.bimmerfest.com/forums/sho...18#post1467818
Fix That Wheel
http://www.bmwtips.com/tipsntricks/w...uff-repair.htm
http://forums.audiworld.com/s4/msgs/949926.phtml
Subframe.....many more than this
http://forum.e46fanatics.com/showthr...light=subframe
What it looks like
http://forum.e46fanatics.com/showthr...ighlight=frame
Subframe on tape
http://forum.e46fanatics.com/showthr...subframe+video
Subframe Petition
http://forum.e46fanatics.com/showthr...19#post4034119
Wasserman, Comden & Casselman, L.L.P. is investigating claims concerning defects in BMW 3 series vehicles manufactured between 1999 and 2005.
http://www.wcclaw.com/CM/Cases/BMW-Subframe.asp
Used BMW parts, full part cars
www.bmrparts.com
Find part numbers
http://www.realoem.com/bmw/
Torque spec revised wheel lugs
http://forum.e46fanatics.com/showthread.php?t=91281
Flexible Coupling for Steering - possible wear item
http://forum.e46fanatics.com/showthread.php?t=470103
Spark Plug replacements
http://www.bimmer360.com/diysp.htm
Full Brake Package Turner Motorsports 330
http://www.turnermotorsport.com/html...E46330BRAKEPAK
Dealer wants what?!
E46 330 Brake Package
Part #: E46330BRAKEPAK
Applications: 2001 - 2005 330i/Ci/Xi (E46)
Complete brake package for E46 330i/ci/xi. Front and rear rotors, pads, sensors, retaining screws and fluid! This is everything you will need to complete a brake service on your 330. Metal Master pads come standard are a small upgrade from stock. The Axxis/PBR Ultimate pads are a big upgrade from the stock pads. Choose from stock rotors or cross-drilled rotors for daily driving or choose the slotted rotors and stainless lines for track use.
Price: $330.27
Sale Price: $309.95
Savings: $20.32
Full Brake Package Turner Motorsports 325/328
http://www.turnermotorsport.com/html...D=E46BRAKEPACK
E46 325/328 Brake Package
Part #: E46BRAKEPACK
Applications: 1999 - 2004 323iC, iT, 325/328i/Ci (E46)
Complete brake package for E46 323i Convertible, and 325i/Ci and 328i/Ci. Package includes front and rear rotors, pads, wear sensors, rotor retaining screws and a liter of brake fluid. You can also add stainless steel brake lines.
Price: $289.95
Inspection II Turner Kit DIY
http://www.turnermotorsport.com/html...&subcat_id=167
IMHO: what I'm planning to do is performing the maintenance in this kit and taking iit somewhere to get a coolant flush and a visual inspection.
E46 325/330i Inspection II Package
Part #: INSP2M54
Applications: 2001 - 2004 325/330i/Ci (E46)
Inspection II Package for E46 325/330i/Ci. Click for more info.
Includes: BMW Synthetic 5W30 engine oil (7 quarts), OEM oil filter, Ate Super Blue brake fluid, A/C microfilter, Bosch spark plugs, OEM air filter, Red Line transmission and differential oil (2 quarts of each), OEM fuel filter. Optional items for the Do-It-Yourselfer are the Peake Fault Code/Reset Tool and/or a Bentley Service Manual.
An Inspection II consists of replacing all of the above parts as well as giving your car a thorough look-over. Much of the work is simply checking various parts and systems on the car which usually leads to more work that should or needs to be done. The above list is what BMW recommends to be done during an Inspection II (or every 40,000 miles). A home mechanic will have limited ability to give a car a complete Inspection II service so we recommend bringing your car to an experience BMW mechanic and having them complete the inspection for you. Keeping up with the maintenance on your car is the smart thing to do. For one thing, it prevents costly repairs in the future. For another, your car performs better, making aftermarket upgrades more worthwhile. And a well-maintained car with complete service records can add substantially to a car's resale value. Make sure you also order the Peake Code/Reset Tool -- resetting those Inspection/Service lights on your dash is the best method of keeping track of service intervals. You can also read and reset engine error codes thereby saving yourself a trip to the dealer (and the charge for reading the codes).
Price: $251.41
Landshark Automotive Indy Mechanic
http://www.landsharkautomotive.com/index.html
24 South Ave, Natick, MA 01760
For those of us in the Ma area this place looks great. Haven't been personally yet but have had heard good things from friends. They have free pre-sale inspections, free pre-track even inspections. Great service prices.
For others there are great tech tips here, these guys are fanatics.
02 Sensor Replacement
http://forum.e46fanatics.com/showthread.php?t=293116
http://forum.e46fanatics.com/archive.../t-313882.html
Sunroof TSB
http://forum.e46fanatics.com/showthread.php?t=388725
Final Stage Resistor
http://forum.e46fanatics.com/showthr...stage+resistor
Throttle Adaptation Procedure .PDF
http://www.bimmerfest.com/forums/sho...tle+adaptation
E-Brake Adjustment
http://forum.e46fanatics.com/showthread.php?t=342878
BMW E46 - BimmerWiki
http://www.bimmerfest.com/wiki/index.php/BMW_E46
differential/gear ratios
http://www.bokchoys.com/differential/index.htm
Unofficial E46 Home Page
http://www.unofficialbmw.com/e46.html
e46 Alignment Knowledge:
Front & Rear Alignment Specs - Bentley Manual
TIS Alignment Ballasting Specs
TIS Alignment Ballasting Specs Vert
http://forum.e46fanatics.com/showthread.php?t=451518
http://www.unofficialbmw.com/all/sus...ment_info.html
Tierod info
http://forum.e46fanatics.com/showthread.php?t=409571
Prefacelift 323i & 328i (Sedan) Manual
https://oc.bmwusa.com/publications/O...ual-3Sedan.pdf
Expansion tank replacement lessons
http://forum.e46fanatics.com/showthr...expansion+tank
Coilover DIY
Has info and pics for sway bars tie rods and stry=uts. many thanks 5speedsteve
http://forum.e46fanatics.com/showthr...ghlight=tierod
Another one
http://www.bimmerfest.com/forums/sho...d.php?t=194689
Bluetooth installation (w/ shark fin installation and phone snap-in):
http://www.bigpatsfans.com/bt/bluetooth.htm
Interesting auto repair and diagnosis tips
http://www.aa1car.com/
Retrofit of RAZR snap-in into an e46 eject box:
http://www.bigpatsfans.com/razr/razr.htm
Facelift an e46 sedan:
http://www.bigpatsfans.com/facelift/facelift.htm
Compass / Auto-dim mirror retorfit:
http://www.bigpatsfans.com/mirror/compass.htm
Idle Control Valve Cleaning
http://forums.bimmerforums.com/forum...d.php?t=454501
All about Brakes
http://www.stoptech.com/tech_info/te...e_papers.shtml
Bleeding, Warping, Bedding
Water Pump Replacement
http://tuningemotion.com/forum/showthread.php?t=2471
Another awesome ETK clone:
http://bmwfans-LINK-BLOCKED-
Camshaft Sensor
http://forum.e46fanatics.com/archive.../t-314768.html
http://forum.e46fanatics.com/search....archid=2187999
http://forum.e46fanatics.com/showthread.php?t=165718
Control Arm DIY
http://www.e46fanatics.com/forum/sho...d.php?t=364978
The What and Why
http://www.e46fanatics.com/features/...php?news_id=67
The How with Pics
http://forum.e46fanatics.com/showthr...t=control+arms
Wheel Fitment/Wheel offset
The best thing to do to find out if a certain size wheel fits would be to contact gary@tirerack who has helped me and is a wealth of shoe knowledge on this site. I don't know much about anything when it comes to fitment so I take everything I read about it on the net with utmost suspicion.
Some ramblings from round the net.
325CI
http://www.mchoi.com/go/325ci/my325ci_mods.shtml
Wheel Specs
PCD: 5x120mm (bolt pattern), Offset: ET40mm , Center bore: 72.5mm
PCD: 5x120mm, Offset: ET38mm (??), Center bore: 72.5mm
330CI
http://forum.e46fanatics.com/showthr...t=wheel+offset
M3
http://m3.madrussian.net/faq.shtml
What is the stock offset for OEM wheels?
For OEM 18's the offset is 47mm Front & 26mm Rear, for OEM 19's the offset is 41mm Front & 27 Rear
The (Self Proclaimed) ultimate wheel/tire fitment thread
http://forums.bimmerforums.com/forum...d.php?t=313615
Harmon Kardon Rattles/fixes
http://www.cardomain.com/ride/262483/2
Contol Arm Replacement DIY
http://forum.e46fanatics.com/showthr...ontrol+arm+diy
Broken Sunshade
http://forum.e46fanatics.com/showthr...t=sunroof+clip
Camshaft Sensor DIY's
Some broken links up top.
http://forum.e46fanatics.com/showthr...ghlight=sensor
http://forum.e46fanatics.com/showthr...sensor+exhaust
Fuel Filter DIY
http://forum.e46fanatics.com/showthread.php?t=265683
Tire Pressure
http://www.bimmerfest.com/forums/showthread.php?t=9852
Window Tint Laws by State
http://www.tintcenter.com/laws/
Car/Key memory options
http://www.**************/tech/glossa...keycfg_01.html
My330CI
http://64.177.26.92/welcome.shtml
MY330I
http://www.my330i.com/
Easter Eggs
http://forum.e46fanatics.com/showthr...ht=easter+eggs
Ultimate-BMW
A Bunch of Goodies; Some dead links though.
http://www.ultimate-bmw.com/bmw_knowledgebase/index.htm
OEM BMW Wheels All Styles
http://www.bmwwheels.com/
BMW Battery
from Autozone
Battery 49D is the exact replacement(size, amps & looks) to OEM battery for $59
LL Approved Oil
5.2 Names of approved Longlife-01 oils:
Tradename-------------Viscosity----------Manufacturer/Supplier
ADDINOL Super power MV 0537 SAE 5W-30 Addinol Lube Oil GmbH
Agip Formula LL B 01 SAE 0W-30 ENI S.p.A.Refining and Marketing Division
Agip Sint 2000 Evolution SAE 5W-40 ENI S.p.A.Refining and Marketing Division
Agip TECSINT SL SAE 5W-40 ENI S.p.A.Refining and Marketing Division
Aral SuperTronic SAE 5W-30 Aral
AXCL S-Class Motor Oil SAE 0W-30 AXCL Gulf FZE
BP Visco 7000 SAE 0W-40 BP Oil International
BP Visco 7000 Special SAE 0W-30 BP Oil International
BP Visco 7000 Turbo Diesel SAE 0W-40 BP Oil International
SBS 5.0 "Longlife-01" BMW AG - TIS 26.12.2004 21:36
Castrol Formula SLX LL01 SAE 0W-30 Castrol Limited
Castrol Formula SLX Turbo Diesel SAE 0W-30 Castrol Limited
Castrol Formula RS Power and Protection SAE 0W-40 Castrol Limited
Castrol Syntec SAE 0W-30 Castrol Limited
Castrol Super Racing 0W-40 SAE 0W-40 Castrol Limited
Castrol TXT Softec LL01 SAE 5W-30 Castrol Limited
Cepsa Star Mega Synthetic SAE 0W-30 Cepsa Lubricantes S.A.
Elf Excellium LDX SAE 0W-30 Total
Formula Shell Ultra AB SAE 5W-30 Shell International Petroleum Company
Gulf Formula TLX SAE 0W-30 Total
Havoline Synthetic BM SAE 0W-30 Texaco
Igol Process Compact P SAE 5W-30 Igol France S.A.
Jet Top Level SAE 0W-40 ConocoPhillips GmbH
Labo RC SAE 0W-30 ***hs Labo Auto S.A.
Liqui Moly Longlife High Tech SAE 5W-30 Liqui Moly
megol Motoren***246;l New Generation SAE 5W-30 Meguin GmbH
Mobil 1 SAE 0W-40 ExxonMobil
Mobil 1 Turbo Diesel SAE 0W-40 ExxonMobil
Motorex Profile B-XL SAE 0W-30 Bucher AG
Motorex Select SP-X SAE 5W-30 Bucher AG
Motul Specific LL-01 SAE 5W-30 Motul S.A:
OMV full syn plus SAE 5W-30 OMV AG
Pennzoil European Formula Ultra SAE 5W-30 Pennzoil Quaker State
Pentospeed 0W-30 VS* SAE 0W-30 Deutsche Pentosin-Werke
Petronas Syntium 3000 LL SAE 5W-30 Petronas
Q8 Formula Special SAE 0W-30 Kuwait Petroleum
Quaker State European Formula Ultra SAE 5W-30 Pennzoil Quaker State
Satoil LazerWay B SAE 5W-30 Svenska Statoil AB
Shell Helix Ultra AB SAE 5W-30 Shell International Petroleum Company
Titan Supersyn SL SAE 0W-30 ***hs Petrolub AG
Valvoline SynPower MXL SAE 0W-30 Valvoline
Veedol Powertron LL01 SAE 5W-30 Veedol International
Veedol Syntron SAE 0W-30 Veedol International
Wintershall VIVA 1 Longlife SAE 5W-30 SRS Schmierstoff Vertrieb GmbH
Yacco VX 1600 SAE 5W-30 Yacco S.A.S.
Chadsere is offline   Reply With Quote
Old 02-23-2014, 06:49 PM   #243
gobas3
ID:	547571Click image for larger version
Hi, this is my e46 installed a taiwan m3 bodykit, would the csl type apron for m3 fits with this bumper? I really like to install does lip on my car.. Thanks
gobas3 is offline   Reply With Quote
Old 02-28-2014, 11:38 AM   #244
berto412
My Ride: 2001 BMW 325ci
2001 BMW 325ci
i JUST BOUGHT A 325CI AND THERES A FEW MINOR PROBLEMS THAT I NEEDED TO GET DONE. WHICH WAS BUY AN O2 CENSOR AND TUNE UP. Recently i got an oil change for it and right after i got the service done i put supreme gas. Well the next day i put $30 of supreme gas at a different gas station and when i turned on the car, the check engine light came on. So i let it sit for a few minutes then tried driving off but the car stopped and turned off and keeps doing it. I got the car to drive home but still the same problem. It even sounds funny and wobbles a little when i start the car. Now it wont let me go past 20mph. It isnt overheating. I just decided to not use the car until i have it checked out. Does it sound like it was just bad gas? someone please help
berto412 is offline   Reply With Quote
Old 03-01-2014, 09:32 AM   #245
mp333
My Ride: 2003 325XI
Must be something else. Check OBD codes.
E46 & E90 Rocks
mp333 is offline   Reply With Quote
Old 03-01-2014, 10:01 AM   #246
Kayss
My Ride: Bmw 328i 1999
Can someone help me find the silver exterior trim at the base of my windows for the right side of the car. I have a bmw 328i 1999
Sent from my SGH-I337M using BimmerApp mobile app
Kayss is offline   Reply With Quote
Old 03-04-2014, 12:03 PM   #247
berto412
Can someone tell me about my 2001 BMW 325ci? I want to know all about it such as common problems....
Old 03-04-2014, 01:17 PM   #248
fubai5407
Same as any other e46, do some research.
fubai5407 is offline   Reply With Quote
Old 03-16-2014, 05:16 PM   #249
hellorohan
On my bmw e46 320i 2003 model, I am wanting to put 18" rims and then put low springs on, does anyone know if I will have any clearance issues ?
hellorohan is offline   Reply With Quote
Old 03-21-2014, 11:12 PM   #250
Hidden1
My Ride: 04 BMW 325i
The CCV aka CVV, control arm bushings, VANOS, high pressure in cooling system, long life fluids (they need to be changed), run flat tires and no spares. I hope this helps.
Hidden1 Sent from BimmerApp
Hidden1 is offline   Reply With Quote
Old 03-21-2014, 11:15 PM   #251
Hidden1
Go to realoem.com and put in last 7 digits of your VIN. Switch to picture view and find part you need there then highlight the part number, right click search google and you should get some hits.
Old 03-21-2014, 11:40 PM   #252
Kayss
I appreciate it, thank you.
Old 03-25-2014, 10:54 PM   #253
320idriver
My Ride: 2003 320i
I've been driving the e46 for a year now and I think it's time to get serious..I know it's funny because it's a 320i and not 330i..do plan to put in dinan cold air intake and new headers(not yet known).a new set of e90 rims (m-sports).and have it stances and have some bodywork done...CSL trunk/w CSL body..then 4 tip the straight pipes(ellisman).. The color is pacific blue....any help or ideas?
320idriver is offline   Reply With Quote
Old 03-26-2014, 04:57 AM   #254
Brendan 330i
Hi guys I'm just wondering what's a suitable transmission oil for my my 330i e46! They recommend zf oil but shortly with all the oil company's out there there is something suitable! Let me know what you use! Thanks Brendan
Brendan 330i is offline   Reply With Quote
Old 03-26-2014, 11:09 AM   #255
Sedan Hussein
My Ride: e46
Redline would be my choice. How many miles?
Sedan Hussein is offline   Reply With Quote
Old 04-13-2014, 01:09 PM   #256
Rsteen12
My Ride: 2000 323Ci
Anyone have a really good angel eye wiring guide ?
Rsteen12 is offline   Reply With Quote
Old 04-13-2014, 05:06 PM   #257
bimmerican21
My Ride: 2002 BMW 325Ci
My driver door doesn't unlock with the remote but it locks with it. But it works either way with the physical key. Would this fix my remote unlocking problem?
bimmerican21 is offline   Reply With Quote
Old 04-13-2014, 05:29 PM   #258
orb
orb's Avatar
My Ride: 325Ci
No. You need either an actuator (most likely) or the GM5 repaired. Need more details.
orb is offline   Reply With Quote
Old 04-28-2014, 04:58 AM   #259
Elvin_PR_328i
My Ride: 328i sedan
Hi guys my rear view mirror just fell of the front glass do you guys recommend I should get it fix in a glass car shop or should I do this myself ? I've heard the glue pep boy sells in a kit does not works properly
Elvin_PR_328i is offline   Reply With Quote
Old 06-11-2014, 03:39 PM   #260
shaddy007
Hi guys any help I am new to the forum and own a 320d m sport...its jaddering and and some times it doesn't...it pulls really well and is good on fuel...but it's just the jadder and engaging to the second that feel a bit too mechanical than smooth.
shaddy007 is offline   Reply With Quote
