Thread Tools Search this Thread Rating: Thread Rating: 37 votes, 4.89 average. Display Modes
Old 12-01-2013, 07:49 PM   #301
BDUB328I
My Ride: bmw 328i S54 sedan (
Awesome work, can't wait to here your info on wiring
Originally Posted by Twin_Turbo_S54 View Post
Closed loop lambda control to improve fuel consumption.
This made me LOL
BDUB328I is offline   Reply With Quote
Old 12-01-2013, 09:18 PM   #302
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
All Wheel Drive E46 M3
Appreciate u sharing with us enthusiasts. I'm also excited about the wiring as well. Mert do u think the 4 wheel drive could be a reproducible option?
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 12-02-2013, 10:09 AM   #303
BDUB328I
anything is reproducible, but if you have been following this thread you know that many of the parts have been custom made (so a lot $ would be needed) more than the average enthusiast wants to put into his/her BMW.
most people would rather spend their money on a Porsche or Lambo...not Mert!!! BMW FTW
Old 12-02-2013, 02:54 PM   #304
Twin_Turbo_S54
My Ride: M3
First of all, E46 M3 coupe will not accomodate the X system. It can be worked out, at the end of the day road holding of M3 Coupe may be worse.
You need a E46 sedan to start with. As BDUB328I wrote XM3 Project costs and is not a proven system yet. I am a M3 fanatic, keep my 997 TT stock but rather work on M3s.
My next Project is a F32 XM3. 2014 model year, coupe 4 series, S54 B35 twin turbo, all Wheel drive etc....
It may even be a 5.0L twin turbo on a 4 series X drive coupe.... Just need to dial in the XM3...
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 12-02-2013, 10:33 PM   #305
atrak
My Ride: 01' em three
Re: All Wheel Drive E46 M3
So at its core it's actually a 33x not an m3?
-BimmerApp-
atrak is offline   Reply With Quote
Old 12-03-2013, 04:44 AM   #306
Twin_Turbo_S54
My Ride: M3
-BimmerApp-
Bare chasis is a 330ix.
Old 12-03-2013, 12:49 PM   #307
atrak
Okay so in theory it's not quite m3 on a track setting but it's going to blow the doors off most modded m's everywhere else
-BimmerApp-
Old 12-05-2013, 02:38 PM   #308
7to3_enthusiast
My Ride: '02 AW 6spd M3
Okay so in theory it's not quite m3 on a track setting but it's going to blow the doors off ALL modded m's everywhere else
-BimmerApp-
Fixed
94 VR R2 Rx7 SOLD
02 AW/IR M3 MaxPSI 2(.5) PT 6870, 3.5" custom exhaust
14 CW 1.8T Beetle - Wife's dream car
02 4.6is X5 - The Work Horse
04 LSB M3 SOLD
7to3_enthusiast is offline   Reply With Quote
Old 12-10-2013, 09:35 AM   #309
Twin_Turbo_S54
My Ride: M3
XM3 started to launch.
Launch control @ 4000 rpm & @ 4500 rpm have beeen tested.
Boost is 8-10 psi, can be raised up to 15-22 psi easily.
After the boost build part of lauch control has been dialed in we then took off in 1st gear.
@ 4000 rpm
@ 4500 rpm
No videos of the take off as it was exciting to dial in the overall system.
With a torque distribution of % 20 to front axles and % 80 to rear axles, XM3 launched very well. It was 3 degrees celcius and road surface was slippery but XM3 managed to launch with decent amount of Wheel spin.
At the end of the day, all Wheel drive system worked good, launch control worked good, I have to work hard and practice.
Old 12-10-2013, 06:01 PM   #310
BDUB328I
sounds like it wont be long until we have some new records
i can only imagine launching at 4500 rpm and 10+psi is pretty violent
Old 12-10-2013, 07:00 PM   #311
7to3_enthusiast
Amazing how quite that things is at idle. You'd never know sitting next to it at a light what that is capable of.
94 VR R2 Rx7 SOLD
04 LSB M3 SOLD
Old 02-08-2014, 04:43 PM   #312
Twin_Turbo_S54
My Ride: M3
Been working on E36 M3 Euro Twin Turbo and E46 M3 Twin Turbo All Wheel Drive.
Both M3s wiring harnesses, rewiring from scratch, in house, with proper material.
this is MIL spec connector....
Enough with ID injectors, got my Bosch 1000 cc Injectors from Racecomponentsinc in Florida, these 1000 cc are the same Bosch pieces used by ID, but Racecomponents sells them at a much better price. Why pay more for the same part?
Both M3s have 1000 cc primaries + 2200 cc secondaries per cylinder
Old 02-08-2014, 04:50 PM   #313
Twin_Turbo_S54
My Ride: M3
ICD dash/logging device by Pectel / Cosworth is installed....
Not just a dash but allows 10 extra analogue sensors, digital inputs...
ICD connected to S50 B32 TT + Cosworth GPS Sensor.
Will be able to analyze 1/4 mile and 60-130 mph runs with the help of GPS sensor conncted into Pectel. I.e you can see height, slope, boost, tps, rpm, acceleration g force all in the same software. Add to that Cosworth's 3 axis g sensor....
Old 02-08-2014, 04:57 PM   #314
Twin_Turbo_S54
My Ride: M3
225 Amp custom alternator installed, no more voltag drop under full throttle
DSS axles for E36 S50 B32, custom made.
S50 B32 fresh built. 11,5 compression. Billet main caps...
S50 B32 custom valves....
Still looking fresh after 16 years, individual paint, 60-130 mph has been 4,49 s 3 years ago. goal is to run 3,49 s 60-130 in RWD mode soon.
XM3's all Wheel drive control system bench tested with Pectel...
Progress goes on
Old 02-08-2014, 09:53 PM   #315
nek0
My Ride: e85 turbo m3
I love to see you finally picked up a camara! Good works keep us informed!!
nek0 is offline   Reply With Quote
Old 02-08-2014, 10:43 PM   #316
being3
Modded ///Member
being3's Avatar
Nice work.... pushing the envelope... :
Old 02-08-2014, 10:48 PM   #317
being3
Modded ///Member
being3's Avatar
Mert... If u don't mind I would like to see how u integrated the duel fuel / injector setup into the throttle bodies on S54....
Old 02-09-2014, 01:58 AM   #318
Cipri
My Ride: E46 M3 2002
Great work Mert!
Sent from my GT-I9505 using BimmerApp mobile app
Cipri is offline   Reply With Quote
Old 02-09-2014, 02:45 AM   #319
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Holy crap ! Mert got a camera! Thanks for the photos Mert!
Old 02-09-2014, 02:49 AM   #320
basar13
My Ride: Z4M, R8, 525xd, STI
Thats it ! Nice pics. E36 needs a proper wheels asap. Other than that everything looks good.
basar13 is offline   Reply With Quote
