Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Pacific Northwest
Pacific Northwest
AK HI ID OR WA
Old 11-13-2013, 04:31 AM   #1
10bmw10
My Ride: 2003.5 M3
Question Greetings - Question
Hello everyone, I didn't know where to post my two questions and figured local would be the easiest...
My Driver side HID bulb flickers on and off, I'm assuming its my Ballast? How would one go with replacing that? could I buy a 50$ HID kit and use that ballast?
Where should I buy BBS LM Reps from?
10bmw10 is offline   Reply With Quote
Old 11-13-2013, 12:36 PM   #2
Grendelsbane
My Ride: M3
Mine did that several months ago, my mechanic changed the igniter and all was good.
2004 Silver M3 / SMG / Koni Yellow shocks and struts / Vogtlands lowering springs / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / Laser Interceptors / Clear Bumper Reflectors / Mishimoto Aluminum Radiator / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune
Grendelsbane is offline   Reply With Quote
Old 11-16-2013, 02:16 AM   #3
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Flickering can also be the lamp. Trade lamps side for side and see if the problem follows the lamp or stays with the ballast/ignitor.
/// MODS
Old 11-27-2013, 06:00 PM   #4
seattle330
My Ride: '05 330i ZHP
When did you last replace the bulbs? If you've got pink eye in the live bulb, it's probably the bulbs that need replacing. You can either get the OE Philips 85122 or upgrade to the Osram Xenarc 66420 CBI which are brighter.
seattle330 is offline   Reply With Quote
Old 12-02-2013, 01:48 PM   #5
Dazza335iC
My Ride: '02 330Ci, '92 345iC
I have exactly the same issue in my passenger side low beam. Since the ballast runs about $350 from the dealer (employee pricing) I'm looking to do anything but replace that haha.
Dazza335iC is offline   Reply With Quote
Old 12-03-2013, 07:51 PM   #6
jM2.me
My Ride: BMW
If you have a bad ballast and don't want to blow over $300 on a new one then look into morimoto 3Five.
I love those ballasts.
jM2.me is offline   Reply With Quote
