Old 05-11-2004, 08:44 PM   #1
musicvibe
My Ride: 325i
Unhappy Engine (e46) will not start, please help.
My first problem is the moonroof not closing. Whenever I press the close button it closes then retracts as if something is blocking it but I've checked and nothing. So right now, the moonroof is open and I tried parking the car in the garage but the engine won't start, rather it's just two loud clicks. Maybe it's because the moonroof is still open? I don't know what to do.
musicvibe is offline   Reply With Quote
Old 05-11-2004, 09:09 PM   #2
CaveDweller
My Ride: '04 325 CiC
How's the battery doing? Does the stereo work?
CaveDweller is offline   Reply With Quote
Old 05-11-2004, 09:14 PM   #3
musicvibe
My Ride: 325i
the battery is perfect as well as the stereo. any suggestions would be of great help. thanks for your reply.
Old 05-11-2004, 09:20 PM   #4
323iT
My Ride: AG 323i
Send a message via AIM to 323iT
hmm i thought your batter is dead...
323iT is offline   Reply With Quote
Old 05-11-2004, 09:22 PM   #5
ky!
My Ride: awhiteysedan
auto? check if its in drive
ky! is offline   Reply With Quote
Old 05-11-2004, 09:25 PM   #6
CaveDweller
I only asked about the stereo because a low battery will degrade its sound quality. It seriously sounds like a power issue and the first place to start is the battery.
Old 05-11-2004, 10:10 PM   #7
Derek_325Ci
My Ride: 2004 325Ci
If it is a 2004 there is a recall. I have a 325 coupe so I dont know if the recall includes sedans as well. The recall has something to do with the battery going dead so if your car is a 2004 there is a good chance this is whats causing it.
Derek_325Ci is offline   Reply With Quote
Old 05-11-2004, 10:24 PM   #8
musicvibe
My Ride: 325i
i wish! but it's an '01. the stereo, the lights and everything else works perfect including the power windows. it's just the sunroof and the engine being a pain even though there is power, should i still use a jumper cable?
Old 05-12-2004, 12:34 AM   #9
braymond141
My Ride: 96 M3, 02 M3, 01 M5
Jump it. Everything worked perfect in my 330 when the battery died, cept it wouldn't start.
-Brett
braymond141 is offline   Reply With Quote
Old 05-12-2004, 12:43 AM   #10
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Jump it....everything else uses a fraction of the power compared to the starter.
The sun roof will probably require a new cassette.
Tim
tim330i is offline   Reply With Quote
Old 05-12-2004, 04:38 PM   #11
musicvibe
My Ride: 325i
Ok, we finally closed the sunroof manually and yeah we did jump it and it started. i'm just going to go to a bmw dealership and have them look at my sunroof because i'm afraid to touch that button and open it myself. thank you guys for your help!
Old 05-12-2004, 04:43 PM   #12
CptPinoy
My Ride: 2002 SG M3
Question for you guys
I have a manual car and sometimes it does this. The car wont start but stereo and everything else is fine. I do depress the clutch all the way down prior to turning the key. The engine just wont start. It would do this randomly. Would this be a battery problem?
FYI, I did take it to the dealers and they gave me the famous "we cant duplicate it" comment. Any help is appreciated.
CptPinoy is offline   Reply With Quote
Old 05-12-2004, 05:02 PM   #13
323ciGuy
My Ride: A BMW
Send a message via AIM to 323ciGuy
1) Sun Roof: The same thing happened to me. I would have to help it out manually (guide it along). Brought it back to the dealership and they put a new motor in. Now it works fine. (covered under warranty)
2) Engine won't start: How often do you rotate your keys? If that battery goes dead in your key, I don't think your car will start because of the chip. I was told by BMW to rotate them every year so they can keep a charge by the ignition. But this could be SO many different things, just trying to cover the most obvious.
323ciGuy is offline   Reply With Quote
