///M3 Forum
Old 12-18-2013, 08:06 AM   #1
Cayne23
My Ride: 2002 m3 convertible
Just a question
Ok so I noticed my temp gauge is barely in the operating range. Fluctuates a little, goes more into operating range. Xhk the obc, temp is from 79c- 72c. I know this could indicate a stuck open thermostat. My question is, could air being in the system also do this? I replaced my alternator a month or so ago, and I had to disconnect the hard line that goes through the side of the fan shroud, to get the shroud off. A little bit of antifreeze leaked out of that line. Air could have, probably did, get in the line. I wonder if this is causing the thermostat to stay open. Any thoughts would be appreciated. Thanks
Cayne23 is offline   Reply With Quote
Old 12-18-2013, 08:11 AM   #2
tks
My Ride: slower than yours
Just a question
Bleed it.
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 12-18-2013, 09:37 AM   #3
Cayne23
Re: Just a question
Yea thats on my to do list for today. The engine warms up quickly. Blows warn air in just a couple of minutes of starting. Hot air comes out soon after. Im just wondering if air is f'in it up a bit
Old 12-18-2013, 11:58 AM   #4
joeysm3
My Ride: ///M3 02
Re: Just a question
Bleed it. If its thermostat you get cel from it. Goodluck
joeysm3 is offline   Reply With Quote
Old 12-18-2013, 12:08 PM   #5
Cayne23
Re: Just a question
Thanx. Yea, no ses light. No lights at all.
Old 12-18-2013, 12:48 PM   #6
Cayne23
Re: Just a question
I have to use bmw antifreeze, correct?
Old 12-18-2013, 01:01 PM   #7
joeysm3
My Ride: ///M3 02
Re: Just a question
Yes also mixed with distilled water
Old 12-18-2013, 09:10 PM   #8
Alroy
My Ride: 2003 M3 SMG CWPkg.
As joeysm3 said, a faulty thermostat would shoot a SES light.
Alroy is offline   Reply With Quote
Old 12-24-2013, 11:24 PM   #9
Cayne23
Re: Just a question
Ok so I opened the bleeder screw and it started to leak coolant, so I closed it. I filled the reservoir up to full. Started the car, with the reservoir cap off. Little bubbles started to come from somewhere. It ran for a couple of minutes then I put the cap on. I went for a drive. The temp maxed out at 79. Would drop to 73 while I was driving, accelerating hard. I think my thermostat is stuck open
Old 12-24-2013, 11:27 PM   #10
Cayne23
Re: Just a question
Oh and it was only 38***176; today
