Sponsored by The Tire Rack
Old 01-21-2014, 12:11 AM   #1
blizzardz21
My Ride: '04 330Ci
Style 71 Reps Question
Hey, just wondering if anyone has ordered these reps from this site. They seem to be a staggered set in 18x8 and 18x9, both with offsets of 20 which might be pushing it for clearance. I calculated it and found the rears would stick out about an extra 1.6" compared to my current rims, not sure if that'll be a problem or not. I'm just curious about the quality of them and if I'd have any fitment issues.
http://www.stockwheelsolutions.com/w...achine-lip-18/
Thank you
Mods List: BimmerBrakes SS Headers; ECIS CAI; Rogue Engineering Pulleys
blizzardz21 is online now   Reply With Quote
Old 01-21-2014, 12:49 AM   #2
CJin2552
My Ride: 2001 BMW 325Ci
Thank you
I have the real ones without the deep dish on the rear. I also have a 10mm spacer installed on the rear and could pull it out a bit more, maybe up to a 25mm spacer, then fender rolling might would be needed. I'm not sure, I'm not a fitment genius. I'm not 100% sure if I have pictures that would help or not. I'm pretty sure they're both 18x8 or 18x8.5 because when I have them off for rotations, they are all the same size.
CJin2552 is offline   Reply With Quote
Old 01-21-2014, 01:07 AM   #3
blizzardz21
My Ride: '04 330Ci
Hmm... I can't quite tell either from your pics, it's a close one. I'm going to assume yours are all 18x8.5 with a 50 offset. With your 10mm spacer, these reps would still be about 1" farther out in the rear. If you went up to a 25mm spacer they're only about .5" farther than yours. I'm just worried about rubbing the fender. Thanks for your info.
Old 01-21-2014, 01:14 AM   #4
CJin2552
No problem. You may need to have the fenders rolled.
