Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 02-10-2014, 10:42 PM   #761
CK325
My Ride: 323Ci, 325xi
Originally Posted by ade555 View Post
I'm trying to get this to work on 05 plate UK car and just don't work I tried with resistors ect. and with out, nothing, what am I doing wrong?
SV 09-05 630
Can you help?
Well, what have you done so far? What kind of wires are you using, etc. would be a good start.
CK325 is offline   Reply With Quote
Old 02-11-2014, 12:50 AM   #762
monsterdaene
I don't know if this has been answered already but will this type of mod work on a 2001 330ci with navigation? It also had a cd changer in the trunk.
monsterdaene is offline   Reply With Quote
Old 02-13-2014, 01:56 AM   #763
Krainis
My Ride: E46 330D '02 Touring
Send a message via ICQ to Krainis
Hello guys. I have this model unit (PH7090):
Maybe someone know, how to check manufacture date and SW version? Please, very very need help!
Krainis is offline   Reply With Quote
Old 02-17-2014, 10:46 AM   #764
Sergzam
My Ride: Snow pckg e46 325i
thanks op used this one two cars already and it was perfect diy
Sergzam is offline   Reply With Quote
Old 02-20-2014, 03:48 PM   #765
mikeetastic
My Ride: lots of 3
anyone has a link for the DIY to make the charging work?
mikeetastic is offline   Reply With Quote
Old 02-21-2014, 12:31 AM   #766
CK325
it's somewhere a few pages back
Old 02-21-2014, 01:41 AM   #767
1`
Banned User
My Ride: 330i
I did it, no splicing.
1) insert aftermarket stereo
2) insert headphone jack M to F and run down around back installing aux port through sunglasses holder
done!
1` is offline   Reply With Quote
Old 02-25-2014, 07:54 AM   #768
RaiShteliS
My Ride: 46
Hello, i have problem, my radio sv is 49-03 540, sn 31287564, made in 12-2003. I do everythink like in diy but it do not work, can someone help?
RaiShteliS is offline   Reply With Quote
Old 02-25-2014, 08:34 AM   #769
Levei
My Ride: BMW E46 328i
Has anyone done this on this unit:
http://www.realoem.com/bmw/showparts...90&hg=65&fg=05
If anyone has, was it just like any other diy aux input or is it even possible?
Levei is offline   Reply With Quote
Old 02-25-2014, 08:34 AM   #770
Sergzam
Is this six cable hooked into the audio device?
Old 02-25-2014, 08:43 AM   #771
Levei
I am not sure this helps, its the only picture I got with a google image search (I know its not good)
But are you talking about this connector on the back of the unit?
Old 04-22-2014, 01:55 PM   #772
jfrankE21
My Ride: E46 Safari Bimmer
I could do this DIY, but I don't have the time to put it all together right now, and I'm trying to do my Parrot/Connects/Aux installation all at once.
I sent a message to the eBay seller for this link:
http://www.ebay.com/itm/Car-Aux-in-A...dae78c&vxp=mtr
to inquire whether or not the device (iPod/iPhone) would charge properly with this cable. The listing shows images of a small box inline, which should be the location of the resistors/capacitors, but I want to be certain before I order something. I haven't heard anything from the seller yet. Has anyone tried this cable from eBay?_nr_
jfrankE21 is offline   Reply With Quote
Old 09-22-2014, 01:29 AM   #773
damageinc
My Ride: 04 330i zhp
I just tried to make this cable and I got really bad audio quality. Weak distorted bass and static like mids.
I use .22uf 16v capacitors and 3 100k ohm resistors soldered to give me almost exactly 300k ohms (I checked with a meter)
Wired it up with capacitors on both left and right channels, and the resistor bridging both left and right.
I made a second cable with no resistors or capacitors and the audio quality is way better.
has anyone else had this problem?
damageinc is offline   Reply With Quote
Old 05-16-2015, 03:14 AM   #774
smokee214
My Ride: 1999 328i
bmw business cd
I just found a November 2002 bmw business cd Hu at the salvage yard for 40 bucks. Works perfect too. Waiting on aux kit to get here in the mail
smokee214 is offline   Reply With Quote
Old 07-21-2015, 03:43 AM   #775
d325xi
My Ride: 2002 BMW 325xi
Originally Posted by maze416 View Post
i'm trying to do the same for my friends 2005 E83 X3 and its not working, aux shows up on the display for a few seconds than it goes away, its basically the same bussiness Head Unit and the fact that it pops up and plays for a few seconds and stops is really pissing me off.
any ideas????
Did you ever find a fux for that, mine is doing the same thing. I order the retro fit from ecstuning.
d325xi is offline   Reply With Quote
Old 07-21-2015, 02:47 PM   #776
BMOne
My Ride: 325CI 03
Does the aux mode show up (or get detected) after the aux cable is plugged into the back of the unit?
I have a business CD unit with a mode button that I can use to change to CD Stacker.
2003 e46
BMOne is offline   Reply With Quote
Old 07-21-2015, 04:32 PM   #777
kd7iwp
My Ride: 2001 325i
Interesting that many of you are installing capacitors and such in your wires. I just upgraded my 2001 HU to one from a 2003 and I had a wire with headphones jacks at both end. I cut one end off and soldered it into an old hard drive ribbon cable and plugged it in the radio and aux-in is working great.
kd7iwp is offline   Reply With Quote
Old 09-24-2015, 07:25 PM   #778
rvaughnp
My Ride: 04' 325iC, 03' X5
Thanks much for the DIY. I have an Sirius ezy go onyx radio connected through the input and wanted to post the process in case anyone else came across this issue.
First, installed a cable off ebay. Was able to get sound out of iPhone that was pretty good about a 20% lose of sound compared to radio. Hooked up Sirius and had about 80% lose and a bad hiss in the back ground. I thought it might also be the electrical issue after researching on this post.
descided to get the resistor and capisitors. Built according to the pdf diagram and installed. and then used my wifes car as the power source.
Hooked up the iPhone and same, same. About a 20% lose of sound compared to the radio. Sirius had same sound level as the iPhone but still had hiss. Decided to look through the "toogles" on the sirius radio and found a "Auto select" on or off that was off. I turned it on and tada... sound is good through Sirius.
I will eventually put in the Blitzsafe and XM tuner to have controlls through the car. Then the bluetooth option. Anyway... Thanks again to OP for putting this up and all the posted that posted relevant information. It was a lot of reading , but very helpful.
rvaughnp is offline   Reply With Quote
Old 09-24-2015, 07:50 PM   #779
stmotorsports
My Ride: 2005 330Ci
I still want to know if anyone has found an "always on" solution that doesn't kill the bass response?
stmotorsports is offline   Reply With Quote
Old 09-24-2015, 07:57 PM   #780
rvaughnp
unless you can get the sound through the additional "cd" side... I don't see a way as far as a cable.
There is always the aftermarket components like blitz safe and others.
bmw aux in, diy aux input, input cable
