Old 11-28-2010, 03:24 PM   #221
BeMyWhip
My Ride: 01 BMW 330ci
Originally Posted by NerdCore View Post
So lame.....
yeah lame, but you can get a nice gear ratio for about 1/3 the price of an lsd set-up from an M3... less work too!
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 11-28-2010, 03:51 PM   #222
Alex323Ci
My Ride: M3 & 323Ci (sold)
yes but the traction and handling is no where near a LSD set-up
Old 11-28-2010, 07:38 PM   #223
NerdCore
My Ride: 02 325i
Exactly my point. But a better ratio AND an LSD is win.
2002 BMW 325ish - Soon to be slammed, blackened, blown, and still daily driven
Click4Facebook
NerdCore is offline   Reply With Quote
Old 12-18-2010, 08:43 PM   #224
omarmarji
Banned User
My Ride: E36 332i
so what should i install in my 330ci 5spd? whats the best setup?
omarmarji is offline   Reply With Quote
Old 12-19-2010, 10:19 AM   #225
bmwTuner1
My Ride: Bmw, 330ci
What do you plan to use your car for?
Photobucket
bmwTuner1 is offline   Reply With Quote
Old 07-21-2011, 10:13 PM   #226
///BMW5
My Ride: 330ci
i wish the videos still worked
///BMW5 is offline   Reply With Quote
Old 07-30-2011, 10:27 PM   #227
jmanfredonia
jmanfredonia's Avatar
My Ride: 325i
bump this thread is great,but did anyone swap to 3.91 in a 325i? is it worth it cause im actually considering it
E46 325i with 70,200 miles for sale: http://forum.e46fanatics.com/showthread.php?t=993988
jmanfredonia is offline   Reply With Quote
Old 07-31-2011, 01:20 AM   #228
southpaw
My Ride: E36 M3 and E36 318ti
Originally Posted by kpeng View Post
Nah, I'm too poor for a supercharger, lol.
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 08-29-2011, 04:07 PM   #229
ex46static
My Ride: 2000 328ci
OK. That post was very informative! I am looking into the X3 diff then. My car is a 5 speed manual(soon to be a 6 speed). Here is my question.
WILL A 330(6 SPEED TRANS.) BOLT UP TO A 328CI. IF SO, I WILL CONVERT TO THE 6 SPEED. WILL THE 330 6SPEED TRANS BE A "PLUG N' PLAY"?
HERE IS MY IDEAL SETUP... PLEASE ADVISE IF I WILL RUN INTO PROBLEMS DOING THIS SETUP.
MY CAR 2000 328Ci
THE CONVERSION I WANT TO DO:
-330 6 SPEED MANUAL TRANS. CONVERSION
-X3 DIFF (ASSUMING ITS A 3.91)
WILL THIS REQUIRE ANY SPECIAL PARTS OR PART "RIGGING"
ex46static is offline   Reply With Quote
Old 10-24-2011, 10:36 AM   #230
kpeng
Banned User
My Ride: E46 330 and E30 325
bumping to inject a little intelligence into the forum, and take a break from crappy plasti-dip cars and neon wheels.
kpeng is offline   Reply With Quote
Old 12-01-2011, 06:25 PM   #231
huskerick
My Ride: 325i/C6/928/951
just had this completed last month in my 02 325i - absolutely worth it!
paid $300 for the diff and had it installed while I was having the subframe reinforcement welded in. also, put in new bushings at the same time.
huskerick is offline   Reply With Quote
Old 09-21-2012, 10:48 AM   #232
mrtsunami20
My Ride: 2004 325ci
does the x3 3.91 manuel diff bolt directly into a 2004 bmw 325ci
mrtsunami20 is offline   Reply With Quote
Old 10-15-2012, 09:21 AM   #233
kpeng
Banned User
yes
Old 12-09-2012, 03:27 AM   #234
daniel_f.
My Ride: 330iC
yes
I guess it was you on youtube with the the facelift supercharged 330CiA and the 3.91 diff, which leads me to my question: which software did u use at your TCU and did you ever tried speeds above 149mph?
Old 02-14-2013, 11:08 AM   #235
kpeng
Banned User
No TCU software. Car pretty much tops out at 145
Old 08-29-2013, 12:59 PM   #236
DLag
My Ride: is slow.
when buying a drive shaft, does it matter if the donor car had a GM or ZF auto trans?
DLag is offline   Reply With Quote
Old 02-28-2014, 06:12 AM   #237
splash26
My Ride: 2003 325ci coupe
hi guys awsome swap,from what x3 is the diff? and will the 3.64 diff fit?
splash26 is offline   Reply With Quote
Old 02-28-2014, 07:24 AM   #238
Chacewig
My Ride: '04 325i
It will, but you should only put that in a manual
Sent from my C6606 using BimmerApp mobile app
Chacewig is offline   Reply With Quote
Old 02-28-2014, 07:32 AM   #239
splash26
ya its for my 325ci manual
i got e46 323 3.46 diff off ebay in the mean time but there it says for auto gearbox but surely it will still just bolt in? or am i wrong?
Old 07-29-2014, 03:53 PM   #240
therealpbgamer
My Ride: 2002 330ci
Has anyone done this swap on their 330 and swapped the input flanges instead of the driveshafts?
I have this diff ready to install on my 330 if i can swap the input flange, just need some conformation that it will be long enough and bolt up
EDIT- Also does this 3.91 diff not have a drain plug?? I seemed to only locate one fill plug.
therealpbgamer is offline   Reply With Quote
