Old 02-28-2014, 08:42 AM   #1
Swagel
My Ride: E46--eg hatch
Clutch recommendation?
I have a 325ci 2001 the clutch is already slipping and since im new to bmers i was wondering what clutch (brand) you guys recommend
Swagel is offline   Reply With Quote
Old 05-09-2014, 10:03 AM   #2
Swagel
Anyone?
Old 05-10-2014, 12:25 AM   #3
Blocked Out
My Ride: Imola 330i M-Sport
Original clutch will can should last well over 200k miles if driven properly.
Buy originAl replacement clutch. Make sure you have extra money in case you need a new flywheel. Our dualmass flywheels are designed to last through 2 clutches GIVEN you replace the clutch on time, meaning you dont drive for 30k miles with a slipping clutch.
Only way to tell if your current flywheel will accept a second clutch is to drop the trans and visually inspect it. If there are no scars ,hot spots,or burn marks then you can reuse it.
Remember , you can NOT resurface OE flywheels. If its burnt, throw it out
Original BMW Teile ///
Original BMW Parts for Sale - DISA, MAF, SAP, Coils, MS43 much more PM ME
IMG_1725
