Thread Tools Search this Thread Rating: Thread Rating: 474 votes, 4.95 average. Display Modes
Old 02-24-2014, 10:21 PM   #781
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Originally Posted by Luis4810 View Post
Will rear m3 vmr csl fit 2001 325ci the wheels are 18s the rear tires are 18x9.5
This thread is for OEM M3 parts.
To answer your question, yes they will fit. Depending on the offset (which you didn't provide) you might have to size the tires down substantially in order to avoid rubbing. The offset tells you how far the wheels stick out.
hi its me alec is offline   Reply With Quote
Old 02-25-2014, 03:02 PM   #782
tuscan1205
My Ride: 325CI
This is somewhat related to OEM m3 parts. This I question I asked in another thread that didn't get answered. I really don't feel like making a new thread for this, so here's my question.
I might be buying a new to me steering wheel. My wheel has had a tear at the 12 o'clock position for some time and its starting to get to me. Does anyone know if the M-tech wheel off of a e39 530i will work with my 325ci?
Here is the part number for the 530 Wheel:
32342282025
Here is the part number for the M3 wheel that looks identical:
32342282020
Thanks for the help.
'02 Orient Blue 325Ci
tuscan1205 is online now   Reply With Quote
Old 02-25-2014, 03:02 PM   #783
tuscan1205
My Ride: 325CI
double post. because iPhone.
Old 02-25-2014, 11:11 PM   #784
hi its me alec
Yes, I don't see why it wouldn't fit. e60 steering wheels and e36 steering wheels both bolt up to e46, so this one should too. They also share the round air bag, which can be swapped between X5, e39, e46, etc. So yeah, just using deductive reasoning on what I DO know for sure, it will fit 100%.
Old 02-25-2014, 11:33 PM   #785
tuscan1205
My Ride: 325CI
Awesome! Thanks for the help.
Old 03-02-2014, 06:00 PM   #786
e46Moods
I have a 2000 328ci and not too long ago the rear subframe broke, which apparently is common in e46s.. Anyways I was wondering if I could just get an e46 m3 rear subframe and bolt it right up without any fabrication?
e46Moods is offline   Reply With Quote
Old 03-02-2014, 06:02 PM   #787
e46Moods
Old 03-02-2014, 06:12 PM   #788
jM2.me
My Ride: BMW
The subframe should bolt right up, but you will need a custom driveshaft.
Note, the E46 have problems with subframe mounting points ripping and cracking. To fix and reinforce that, you will have to weld subframe reinforcement kit, or have the shop make one themselves.
Volcano Red M3 Bumpers, Fenders, Quarter panels 19" 8.5ET35 225/35 | 9.5ET35 255/30 Custom Quad Exhaust Good old M54
jM2.me is offline   Reply With Quote
Old 03-02-2014, 06:16 PM   #789
e46Moods
I see and I've looked into the reinforcement kits on Turner Motorsports, do they really work that well on a subframe that's been damaged for a few weeks? Or should I go ahead and cop me a new one, they're relatively cheap! Thanks for the help bud!
Old 03-11-2014, 05:24 AM   #790
-lynel-
My Ride: 2000 BMW 323i
so i read through the 1st 31 pages before i gave up
this has kind of been covered but M3 brakes on a non M. Ive seen the couple comments that say i need custom carriers but if the m3 brakes come with the m3 caliper carriers will this work with the m3 disc? im reading that this WONT work as the answer seems to obvious not to be mentioned. So this means the nonM hubs are different? I cant seem to find an answer on this.
Anyone know? i have the op to buy cheap m3 rotors, carriers and calipers in good condition
-lynel- is offline   Reply With Quote
Old 03-11-2014, 05:40 PM   #791
zaharias
My Ride: M3 E46 6MT 3/2005
Its better to go with 330 brakes.. straight fit..
You will need lots of front axle M3 parts to do a proper job..
zaharias is offline   Reply With Quote
Old 03-11-2014, 05:42 PM   #792
Parvaz
My Ride: 2004 bmw 330 ci
Hi guys . any one knows if 2004 m3 side mirror fits 2004 330ci ..?! I mean does it fit right in or I have to changed or modify something..!!? Thank for help...! Appreciated very much........!!!!
Parvaz is offline   Reply With Quote
Old 03-12-2014, 01:35 AM   #793
-lynel-
thanks for the reply....looking more and more likely ill get a parts 330ci haha
Old 03-20-2014, 07:24 AM   #794
TS_bimmer
My Ride: BMW 320d Pack M
Originally Posted by MAXixt View Post
If someone want to swap M3 diff on usual e46 ,here is all you need
1)Diff
2)subframe
3)stabilisator bar
4)rewald output flanges
5)make drive shaft shorter (rear part)
Thanks MAXixt,
very useful for me
TS_bimmer is offline   Reply With Quote
Old 03-23-2014, 03:28 PM   #795
Alex323Ci
My Ride: M3 & 323Ci (sold)
Lightbulb
Originally Posted by hi its me alec View Post
Gauges/Instrument Cluster:
Difficulty: ?/10
DIY: ?
Part Number: INSTRUMENTS COMBINATION UNCODED MPH 62117837972 $504.43
This has not been successfully done yet. People have plugged these in, and here are the results:
WORKS 100%:
- MPH
- RPM
- OnBoard Computer Functions
- Lights
- Indicators
- Engine Temp.
- Gas Info
DOES NOT WORK:
- Oil Temp. Needle
- RPM Warmup Lights
- Little orange ODO Tamper Light comes on...which is bad
This is a DIRECT PLUG AND PLAY, but will not work 100%. You be the judge...
with time it appears after many years to have been figured out how to do this. Post 30 in this thread gives a lot of info for those interested. will take some coding skills and a bit of work.
http://forum.e46fanatics.com/showthr...=953333&page=2
Old 03-25-2014, 01:01 AM   #796
hi its me alec
Nice! Glad to see that was finally figured out. Sounds like the coding isn't TOO hard if you know what you're looking for, and are looking through the correct software
Old 04-17-2014, 04:16 PM   #797
LadyJackie
My Ride: Schwarz 2 E46 330i
Send a message via Yahoo to LadyJackie
Alex,
You sir, are amazing.
meow
LadyJackie is offline   Reply With Quote
Old 04-17-2014, 05:23 PM   #798
SoCalZman
My Ride: 05 BMW 330i ZHP 6MT
I see in here that the M3 rear strut mounts will fit (without any other M3 parts, I am assuming. No one mentioned anything else). my question is, is it really a worthwhile upgrade? Is it just that they will last longer than our stock RSMs or is there more to it?
2005 BMW 330i ZHP 6 speed
Stock: Nav, leather, PDC
Added by me: OEM Alarm, OEM heated seats, OEM aux kit, OEM Bluetooth, intravee, M3 strut brace, BMW Performance Intake, Nappa leather arm rest, updated LCM (triple blink, euro hazards, trifecta lighting, 3 stage brakes), temp gauge mod
SoCalZman is offline   Reply With Quote
Old 05-04-2014, 12:32 AM   #799
Hamada12
* How To Fit OEM M3 Parts On A Non-M *
I have 2001 bmw 325i
I would like to fit m3 lights and turn signals but am not sure if they fit
Could someone tell me if they fit.
-2001 isn't the face lifted eddition
Thanks in advance
Hamada12 is offline   Reply With Quote
Old 05-04-2014, 12:46 AM   #800
E40SICK
My Ride: 2001 330ci
you have a sedan?? thats a easy no... sedan fronts are different than coupes regardless of trim
E40SICK is offline   Reply With Quote
