///M3 Forum
Old 04-01-2014, 05:09 PM   #1
Devilinpoop
My Ride: e46 M3 6MT
Clutch and flywheel overhaul
Hey,
My rear main seal has been leaking for a little while, so I decided to replace everything that I can in one shot.
I drive 2005 m3 cupe, with manual stransmission, the car has 104K miles.
I am planning on replacing the following:
Clutch with pressure plate.
Flywheel
Rear Main Seal
Shifter linkages
Motor and Trans mounts
Engine oil
Tran's fluid
Breakfluid flush
What else would be easy to replace while the trans is out?
Everything is oem, the car is a daily driver, I don't want to put any lightweight flywheel or extra gripy clutch that needs a new one every 100 yards.
Devilinpoop is offline   Reply With Quote
Old 04-01-2014, 09:39 PM   #2
Teslazerok
My Ride: 2003 M3 6SPD
Differential fluid if it hasn't been done.
Check your guibo and center support bearing while you're in there.
Originally Posted by svtmike
Your TL is an eminently replaceable mass production inaninimate object that doesn't give a sh*t about you.
Teslazerok is offline   Reply With Quote
Old 04-01-2014, 09:53 PM   #3
Devilinpoop
My Ride: e46 M3 6MT
Diff fluid has been replaced 4000 miles ago.
will do the guibo and the support bearing, thanks.
Old 04-16-2014, 10:28 AM   #4
PITT M3 RR
My Ride: E46 M3
Repack the drive shaft cv and get the 330i cover seal
UUC SSK / AFE STG1 Intake / AKG Red Motor mounts / AKG Red Tranny mounts / AKG Red Subframe bushings / AKG Red Differential bushings / AKG Red RTABS / TMS Subframe reinforcement / Custom in trunk subframe structural brace / Bilstein PSS10's / Ground control camber plates / Turner RSM
PITT M3 RR is offline   Reply With Quote
clutch, flywheel, rms., trans
