Old 04-09-2014, 05:07 PM   #1
Mike2114
My Ride: 99 328i
Unhappy No start
Hi this is my first BMW so I'm new to this. I have a no start on my 99 328i. Wasn't getting spark. I moved the orange wire that grounds onto the valve cover and it started. Then it shut off again a little bit later and won't start back up. Any ideas?
Mike2114 is offline   Reply With Quote
Old 04-09-2014, 08:29 PM   #2
lszlszx
My Ride: 1.8T, XC70
How did you check for spark?
Does the starter crank?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-09-2014, 08:33 PM   #3
Mike2114
My Ride: 99 328i
Cranks fine. Took a coil plug out and spark plug. Grounded both. No spark. Just a wet spark plug after trying to start it. The orange wire that grounds to the valve cover was what I moved around and it started then it shut off again and hasn't started since
Old 04-09-2014, 08:40 PM   #4
lszlszx
My Ride: 1.8T, XC70
Try to connect an extra ground wire between the engine and chassis, just to rule out bad ground.
Old 04-09-2014, 08:50 PM   #5
Mike2114
My Ride: 99 328i
So will that help? Cause the orange wire that is grounded has a resistor built into it too
Old 04-09-2014, 09:05 PM   #6
lszlszx
My Ride: 1.8T, XC70
I thought you were talking about a simple ground wire.
Can you post a picture of it?
Old 04-09-2014, 09:54 PM   #7
Mike2114
My Ride: 99 328i
I can tomorrow morning
Old 04-09-2014, 10:21 PM   #8
lszlszx
My Ride: 1.8T, XC70
OK, check out my no start thread, fuses are another thing I would look into.
Old 04-10-2014, 10:19 AM   #9
Mike2114
My Ride: 99 328i
Unhappy
Ok I took a couple pics. It's the orange wire in both pics and you can see there is a resistor on the wire.
Old 04-10-2014, 04:50 PM   #10
lszlszx
My Ride: 1.8T, XC70
I'm not sure what wire that is. Any progress?
Old 04-10-2014, 04:53 PM   #11
Mike2114
My Ride: 99 328i
No. I tried other places and just cranks. Have new coils I'm gonna install and see if maybe they went bad. Weird if all went out at the same time.
Old 04-10-2014, 04:54 PM   #12
Mike2114
My Ride: 99 328i
And the wire is on the ignition coil wire harness itself too
Old 04-10-2014, 04:56 PM   #13
lszlszx
My Ride: 1.8T, XC70
What's the history of the car?
Did you buy it not running, or it just died?
Old 04-10-2014, 05:09 PM   #14
Mike2114
My Ride: 99 328i
It had a engine swap done. Same engine as original just lower miles. Was having intermittent shutoff no starts. Then went away and now won't start
Old 04-10-2014, 05:18 PM   #15
lszlszx
My Ride: 1.8T, XC70
I see. Is the check engine light on when you turn the key?
Old 04-10-2014, 05:21 PM   #16
Mike2114
My Ride: 99 328i
No codes. All fuses are good
Old 04-10-2014, 05:32 PM   #17
lszlszx
My Ride: 1.8T, XC70
See if there is power at the coil harness. At pin 15 there should be battery power with the ignition on.
Old 04-10-2014, 07:17 PM   #18
Mike2114
My Ride: 99 328i
There is power at the harness. And at the oranger wire that is off the harness too
Old 04-10-2014, 07:47 PM   #19
lszlszx
My Ride: 1.8T, XC70
Pin 1 on the coil harness is the DME signal wire. Pull one of the rubber boots back.
Connect a test light to the back of the pin and have someone crank the engine.
The light should flash.
Old 04-10-2014, 08:11 PM   #20
Mike2114
My Ride: 99 328i
I get a test ligt on on one of the connectors off the coil plug in. And when it cranks it's the only one that lights up also
coils, dead, injectors, start
