Australia
Old 04-13-2014, 09:58 PM   #1
Alexander13
My Ride: 328ci
Differential help!
Hi guys,
I need a bit of help regarding diffs. From what I understand the following should be correct:
320/323/325/328 Are the same
330ci are different to the rest
M3 is different to the rest
318? This is what I'm not sure on. They look like any other smaller 6cyl e46. Can anyone comment?
Purely needing just the info to sorce diff gears haha
Thanks in advance, Alex.
Alexander13 is offline   Reply With Quote
Old 04-13-2014, 11:52 PM   #2
Davew
My Ride: 2004 330ci Msport
http://www.bokchoys.com/differential/GearRatios_E46.htm
Have a read on this site, I know it has a lot of info, not sure it will have the info your after, been a while since I visited this site.
Davew is offline   Reply With Quote
Old 04-20-2014, 06:50 PM   #3
Davconelectric
My Ride: Mainly cars
No idea, but wouldn't mind knowing what and where you get your gears from
Davconelectric is offline   Reply With Quote
Old 04-20-2014, 08:01 PM   #4
Alexander13
My Ride: 328ci
I'm assuming e30/36/46 will be very very similar but I have to just get a set and check over them. If this is the case. E30/36/46/34/39 will be all the same
Old 04-20-2014, 09:01 PM   #5
BrisM3
My Ride: 1990 E30 318is
What I can tell you having sourced a new diff and gears for my E30 is that there are 3 size casings - small, medium and large.
The size of the case is dictated by the diameter of the ring gear.
Large = 210mm
Medium = 188mm
Small = 168mm
The medium case diffs were used in for example the 6 cyl E30 cars.
E46 is a large case diff and is different to all the other diffs in relation to how it bolts to the rear subframe - at two points instead of one.
Hope this is of some assistance.
Tim.
BrisM3 is offline   Reply With Quote
Old 04-20-2014, 09:08 PM   #6
Alexander13
My Ride: 328ci
Thank Tim! I had to the the same in both my e30 and e36 just e46 seem to be funny. I've got a 318i diff with 3.9:1 at my availability if I need it, so I might see if those gears are the same as the 328. I know 330 are bigger and so are m3. Working of that I would only assume that the 330 is 188mm and the m3 is 210mm
Old 04-20-2014, 09:46 PM   #7
BrisM3
E46 M3 is 210mm ring gear diameter. Large case diff - different input flange and mounting points etc.
BMW kept diffs pretty consistent from the late 70s to the mid 2000s
Old 04-20-2014, 11:39 PM   #8
t651
My Ride: BMW
Originally Posted by BrisM3 View Post
Large = 210mm
Medium = 188mm
Small = 168mm
In recent times BMW have added to that with the 188k, 215 and 215k diffs.
188k comes in two flavours <= 3.07 and >= 3.15
All non M e46 six cylinders should have 188k diffs.
t651 is offline   Reply With Quote
Old 04-20-2014, 11:52 PM   #9
t651
My Ride: BMW
Comprehensive list found here:
http://forum.e46fanatics.com/showthread.php?t=999994
BMW certainly are making things complicated for us!
As for gearsets you're probably best looking into e46 non M, e39 6 cylinders, e90 non M, e60 6 cylinders.
Good luck!
Old 04-21-2014, 05:55 PM   #10
Alexander13
My Ride: 328ci
So e30/34/36/39/46 6cyls are all the same for gears. I'll be getting a e34 diff in the next coming weeks to try and do the swap. I will be running a OS giken center. This shouldn't matter I would think.
Old 04-21-2014, 08:17 PM   #11
BrisM3
I think you're spot on with that.
Old 04-21-2014, 08:51 PM   #12
t651
My Ride: BMW
No 188 and 188k are physically different.
e34 (non v8 and non M) are 188 so it won't fit.
Old 04-21-2014, 10:13 PM   #13
Alexander13
My Ride: 328ci
It's just the centres are different? All I end is the hearing, shouldn't the gears be the same just centre to the carrier?
Old 04-21-2014, 11:04 PM   #14
t651
My Ride: BMW
CWP is also different.
http://forum.e46fanatics.com/showpos...31&postcount=5
