F/I Non-Ms post your numbers - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-12-2014, 02:39 PM   #61
NaZty NaZe One!
My Ride: 02' 330ci "Ebony"
Send a message via AIM to NaZty NaZe One!
Non-M non F/I
hi guys i recently got a dyno run and wanted to show my numbers. I plan to do an ecu tune soon and wanted some input on my current numbers. i currently have installed:
1.k&N short ram intake
2. Custom 2.5 in dual straight pipe exhaust w/ x pipe
3. racing dynamics exhaust
4. dinan throttle body
5. ebay headers
i was told some underdrive pulleys might help release some power. i also have nitrous but have not installed it yet, I plan to keep it low at 50-75.
Photobucket
NaZty NaZe One! is offline   Reply With Quote
Old 04-12-2014, 04:08 PM   #62
Rob43
Suspension Guru
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
That looks good.....
Also, if you need any help with your nitrous install (or parts), just shoot me a PM.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 04-13-2014, 05:17 AM   #63
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
5. ebay headers
http://www.fixpicture.org/medias/139...CI12042014.jpg
Hi,
I could not open the link, I would like to see your numbers too.
Cheers
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 04-14-2014, 01:12 PM   #64
NaZty NaZe One!
Rob43
will do. i should be installing the system soon. i bought it years ago from kpeng but never had a chance to install it.
Photobucket
Old 04-14-2014, 08:13 PM   #65
cosmos328Ci
5. ebay headers
Nice work, it will be good to see how your mods go with an ECU tune to match.
Good luck.
Old 05-21-2014, 02:01 AM   #66
cosmos328Ci
Today: 357 Hp / 450 ft/lb - Dyno Dynamics
M54B30 on E85 - Still got the Meth/Water Injection to go. (could not get the controller to work ) So no meth yet, it's all hooked up and ready to go though.
Old 09-26-2014, 02:11 AM   #67
cosmos328Ci
Mainline Dyno. 370.7 HP, 681.5 Nm
Today I did a before and after OEM Air box V Cone filter in engine bay.
OEM air box has 3" hole in bottom.
OEM air box 337.4 Hp and 643.4 Nm
Cone filter in engine bay 370.7 HP, 681.5 Nm
(276.4 kW & 502.6 lbft)
Gain:
Hp 33.3 (24.8 kW)
Nm 38.1 (28.1 ftlb)
Name:	HP and Tq. Mainline Dyno. WP_20140926_11_28_07_Pro.jpg
ID:	575165   Click image for larger version
Old 01-20-2017, 10:58 PM   #68
cosmos328Ci
398.5 whp and 676.4 Nm on Mainline Dyno.
2015.
Name:	New Exhaust Dyno as of Fri 28 Aug 15.jpg
Old 01-20-2017, 11:28 PM   #69
Davew
My Ride: 2004 330ci Msport
Originally Posted by cosmos328Ci View Post
What's planned for 2017
Davew is offline   Reply With Quote
Old 01-21-2017, 12:37 AM   #70
cosmos328Ci
Hi Davew,
First off the rank:
I'm currently working on my spare engine:
1. GSR Four-bolt shaft (oil pump),
2. ATI Dampner - larger Dia than OEM (hence the move from 60mm pulley to 74.15mm pulley, thanks to you ), and
3. Shrick 272/256 cams.
This hopefully should bump me over the 400 whp, LOL.
Second off the rank:
Modify and re-inforce rear sub frame mounting.
That should do me for a couple of tears.
