Muffler Delete for 330i - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-09-2009, 11:15 AM   #1
aspi944
My Ride: e46 330i
Send a message via Yahoo to aspi944
Arrow Muffler Delete for 330i
Hi Guys,
This what i know about muffler delete.
1. Need to cut of the rear muffler (?? or may be the only muffler)
2. weld two straight pipes all the way out to the exhaust
Now this what i need help on
1. where to get nice looking straight pipes specifically designed for muffler delete and should suits the bimmer looks...
2. how much time/money its takes
3. suggestion on good indy shop in NYC/LI area
Any suggestion would appreciate...
aspi944 is offline   Reply With Quote
Old 12-09-2009, 12:26 PM   #2
n2Bimmer
My Ride: Loves Corners
You need to cut the muffler, Weld two glass packs or pipes and weld tips on the end. I got this done at a muffler shop for 120, not including the tips
Old 12-09-2009, 12:28 PM   #3
aspi944
My Ride: e46 330i
thanks man ..but where did you got that pipes and tips?
Sponsored Links
Advertisement
Old 12-09-2009, 01:42 PM   #4
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Any reputable/competent shop should have piping and the great ones will know exactly how to bend it properly and will use high quality piping. As for the tips, you can get them on ebay, from magnaflow.com , from a local muffler shop, etc... there are tons of place man. I got mine from Lu (OSS) down in Miami so dont have a specific shop but there are tons where you can get them...
Bottom line, try magnaflow.com (under tips), buy some, take it to a good shop that does muffler (not general auto) work and you'll be fine and likely spend under 200..
Here's how my 328 sounds.. not identical to the note your 330 will make but will give you a decent idea should you simply remove the muffler and run straight pipes with tips on at the end (i still have both resonators in place and am on a stock airbox and stock headers).
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 12-09-2009, 03:48 PM   #5
aspi944
My Ride: e46 330i
cool guys...i will do it...but one last question?
what size of pipes i need?
is there any specific brands?
i will by tips from magnaflow though...
Old 12-09-2009, 03:51 PM   #6
alwaysbored786
My Ride: M3
the pipes will be 2.25" so your tips should have a 2.25" inlet, and w/e outlet you want. As for the pipes, if your gonna go to a shop, they should already have pipes that will do the job, doesn't matter how they look, b/c they are under the car....no 1 see's them. But the tips....now thats where some money should be spent.
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline   Reply With Quote
Old 12-09-2009, 03:53 PM   #7
aspi944
My Ride: e46 330i
thanks man...i will do that...
Old 12-30-2009, 11:18 PM   #8
DarkJoker
My Ride: 01 330ci
i had mine done for $160
including tips and pipes and labor
DarkJoker is offline   Reply With Quote
Old 12-30-2009, 11:18 PM   #9
DarkJoker
My Ride: 01 330ci
Old 12-30-2009, 11:30 PM   #10
RAFF112
My Ride: 325ci M3 cbr 600rr
Originally Posted by DarkJoker View Post
VCSL Front 18/13 Spacers Full Borla V2 K&N drop-in w/custom tube LED Interior air horn BMW performance shift Knob Seibon Hood LED DRL Dynavin Depo corners RE rear camber arms and Vogtland Springs.
Originally Posted by hayabusa55 View Post
I used to think love exists. Turns out it's a manifestation of insecurities and boredom.
RAFF112 is offline   Reply With Quote
Old 12-30-2009, 11:30 PM   #11
RAFF112
Old 01-02-2010, 04:54 AM   #12
tylerc
My Ride: 330ci
I have a welder and did it for free. Then y-d it to a single magnaflow :p
its honestly a bit quiet now, wasn't to horribly loud with stock exhaust minus rear muffler
tylerc is offline   Reply With Quote
Old 01-05-2010, 09:25 PM   #13
lllSupra
My Ride: E46 330i
DONT DO IT IF YOU HAVE A 330I!!!, you will lose major torque and get horrible drone at highway speeds if your muffler has a vacuum line. YOU NEED BACK PRESSURE i did this to my car then got it dynoed and i lost 15rwhp and 20lbs of torque from stock!!!
lllSupra is offline   Reply With Quote
Old 01-07-2010, 01:07 AM   #14
tylerc
My Ride: 330ci
do you have the dyno that we can see?
you do need to cap off the vacuum line however I didn't notice the same loss you describe. Please post the before after dynos!
Old 04-30-2014, 05:13 PM   #15
_RoB_
My Ride: 2002 330i e46
I have a 2002 330i that I recently cut the muffler off of. I'm now running just the stock pipes that end under the rear driver side seat without a muffler. (Until I have the $250 to get the straight pipes from cats back) but do I really have to plug that vacuum line that was going into the butterfly? You think that would really make a difference?
_RoB_ is offline   Reply With Quote
Old 04-30-2014, 05:14 PM   #16
bry330i
My Ride: 2002 330i
inception thread
bry330i is offline   Reply With Quote
Old 04-30-2014, 05:16 PM   #17
_RoB_
Originally Posted by bry330i View Post
inception thread
Huh
300i, delete, exhaust, indy shop, muffler
