Old 05-09-2014, 01:31 AM   #1
xevman
My Ride: 2000 323i
e46 rust concern
Hey guys today i was inspecting my car and noticed a piece of mud that was stuck inside my door trim. I pulled it off and noticed that surface rust had started to form underneath the mud. Should i be concerned about it? i sprayed a good amount of wd40 on it to stop it from spreading but what should i do about it?
Here is a picture
xevman is offline   Reply With Quote
Old 05-09-2014, 03:51 AM   #2
jjp735i
My Ride: 05 545i & 03 325xi
Living in the northeast all my life I have to say, YES, be concerned. You need to grind it all off and get rid of it. Rust will never stop spreading once started.
Properly done, you can stop it. Sand, grind, use some good anti-rust and paint and seal. But get rid of it now before it's to late.
They do sell some good stuff that will turn it rock hard and black, but I don't remember the name of hand, but it works good and will not spread. Still, best way is to grind it off and treat it and paint.
Good luck.
jjp735i is offline   Reply With Quote
Old 05-09-2014, 06:38 AM   #3
jeepo23
My Ride: 2008 X3, 6 Speed
Good luck.
It's POR15.
Stuff works, if done properly, takes some work.
I got rust on my ride also, mainly on the door lips down below.. hopefully in the next month or so I'll tackle that and planned to use POR15.
** Removed **
jeepo23 is offline   Reply With Quote
Old 05-09-2014, 08:55 AM   #4
choxor
My Ride: JDM
That's the rust you see. The area needs to be ground out to determine how bad it really is. Take it to a body shop. Rust is a cancer.
Old 05-09-2014, 10:21 AM   #5
hitbyastick
My Ride: 2002 325i
Body shop is the best solution, but there is a product called Rust Bullet that is silver in color and very comparable to POR15 and some say better. If you DIY I recommend mechanical abrasion, naval jelly, then an epoxy sealer such as Rust Bullet or POR15.
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 05-10-2014, 01:12 PM   #6
shovelit
My Ride: 03 325xi and 04 330x
I just had some rust taken care of last week. Tiny blister on left rear 1/4 panel where the bumper cover meets it.
Body shop removed the bumper cover and found same thing on the right just not showing yet.
They did a FANTASTIC job and the price was more than fair.
shovelit is offline   Reply With Quote
