The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 87 votes, 5.00 average. Display Modes
Old 06-17-2014, 01:37 PM   #321
anandoc
My Ride: 2004 330i
Sorry for the crappy cameraphone quality, but here is my E46 on 18s
anandoc
2004 330i auto | ZPP, ZCW | Schwarz 2 (668) | schwarz (N6SW)
aFe Stage-1 Pro DRY S intake | Morimoto FX-R 3.0 retrofit | ///M3 Seats (power, heat, bolster adj.) | ///M3 Strut Brace | ///M3 SMG Steering Wheel retrofit | OEM Alarm retrofit | GROM USB | Khoalty angel eyes
anandoc is offline   Reply With Quote
Old 06-17-2014, 01:57 PM   #322
MK153
My Ride: '01 330ci TiAg
Originally Posted by jaywood View Post
Mk153 - Thinking about getting that same setup. Do you happen to have anymore pictures?
Also, are you glad you went with the 9" rear, or do you wish you'd have gone 8" all around?
I wish I went 8" all around - the 9s in the back definitely rub.
You can find some more pics here: http://forum.e46fanatics.com/showthread.php?t=1035135
MK153 is offline   Reply With Quote
Old 06-17-2014, 03:56 PM   #323
MagnusHN
My Ride: BMW 03' 330i
Originally Posted by sjacoby112 View Post
Love those, what are your front specs?
Front specs are 9" et6
MagnusHN is offline   Reply With Quote
Old 06-18-2014, 03:30 PM   #324
JKid
My Ride: 2005 325xi
325xi on Eibach Pro Springs.
M3 Rears all around, 18x9.
2 finger gap all around.
JKid is offline   Reply With Quote
Old 06-18-2014, 10:29 PM   #325
bimminge46
My Ride: 323Ci, 89 325i ETA
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 06-19-2014, 05:02 PM   #326
E46inthe206
My Ride: 2003 BMW 330Ci
One piece lip is on. Next step is rear fender rolling and spacers all around.
E46inthe206 is offline   Reply With Quote
Old 06-21-2014, 10:43 AM   #327
FaisalFazeli
My Ride: BMW E46 SALOON/SEDAN
Send a message via ICQ to FaisalFazeli
front 235/40/18
rear 245/40/18
rear and front m sport springs
rear arched
ordered a set of lowering springs for front and back 40mm/40mm and was wondering if i should order fron 10mm spacers and rear 10mm spacers? Or will this make it rub the arches?
Help guys!
ID:	562721   Click image for larger version
FaisalFazeli is offline   Reply With Quote
Old 06-21-2014, 05:13 PM   #328
E46inthe206
You might need to roll your rears a little bit with 10mm spacers, especially if you'll be going lower. Take a look at my car, my fenders aren't rolled and I have about 4-5cm of room between the tire and fender in the rear. I'm running 245/35 with a 35 offset. But then again, coupes have a little more room than sedans.
Old 06-21-2014, 05:30 PM   #329
Ft1219
My Ride: BMW?
He shouldn't have to, I'm running 265/35/18 on a 9.5 inch rim with 35 offset and I don't rub. I'm also lowered on H&R cup kit with -3 camber. Functional camber is key.
Hellrot/ 3.64 LSD/ MTech II/ Schrick Cams/ Bimmerbrakes Headers/ Highline Tuning Exhaust/ Active Autowerke Software/ TMS Pulleys/ BMW SSK/ Powerflex bushings/ DNA Rear Adjustable Control Arms/ BBS LM Wheels/ Apex Studs/ Bilstein pss9 coils/ UUC Mounts/ Sparco Seats/ Macht Schnell Brackets/ Project kics Lug Nuts/ Pirelli P Zero
Ft1219 is offline   Reply With Quote
Old 06-22-2014, 06:52 AM   #330
SMUUUUUV
My Ride: 330 VERT-4.4 X5-S550
18 inch winters.....
18 inch summers.....
SMUUUUUV is offline   Reply With Quote
Old 06-22-2014, 10:24 AM   #331
E46inthe206
Are you at the same height as the pic in your sig? If so, that's too high to rub, even with 265's. I'm tucking half my sidewall, and I'm going to need to roll before getting spacers.
Old 06-22-2014, 03:26 PM   #332
Ft1219
My Ride: BMW?
This is my current height, sig is old.
Old 06-22-2014, 04:25 PM   #333
bimminge46
http://www.hark.com/clips/sqfrdbdxtz-mikey-likey
E30 in progress.
Old 06-23-2014, 04:07 PM   #334
FaisalFazeli
Wow! Thats nice. Is the 18s in winter the same wheels as mine? Whats the spec on them and how low is that? Springs? Also would want to know the name of these wheels
Old 06-24-2014, 12:28 AM   #335
E46inthe206
Attachment 562862
Yeah that's too high to rub.
Old 06-24-2014, 12:54 AM   #336
E46inthe206
Originally Posted by FaisalFazeli View Post
front 235/40/18
rear 245/40/18
rear arched
Help guys!
So it just depends on how low your setup will let you go.
Old 06-24-2014, 04:17 AM   #337
FaisalFazeli
Yeah.. 40mm?
Old 06-28-2014, 02:57 AM   #338
E46inthe206
Yeah.. 40mm?
I think you'll be fine, you may or may not need a slight roll if you get spacers though, keep that in mind.
What're the wheel specs?
Old 06-28-2014, 04:03 AM   #339
FaisalFazeli
Sorry the only info about them i have is 8.5.. Its 245/40/18 on tyres.. It doesnt rub! But the corner of the tyre does when theres people in the back.. So thinking if i should camber it?
Old 06-28-2014, 09:41 AM   #340
E46inthe206
It'll camber a little bit once you go lower.. you can adjust it later though when you get an alignment.
I can't see your car in person so I can't give you accurate advice I say if you already rub with people in the back then go ahead and roll your rear fenders and go lower.. Get 5mm spacers if you really want to get spacers, but I think you'll be good without them though.
set up, stance, tyres, wheels
