Old 05-26-2014, 08:40 PM   #1
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
DIY Vid angel eyes kill switch
Quick dirty vid on how to do very simple wiring to kill your angel eyes when the key is in position 2 or when the car is on. With this wiring setup it will NOT turn them off if you have the trigger wire connected to the interior lights for fade on/off. Did the work rather quickly with my friend jacob220
Tools:
- Philips screwdriver
- Electrical tape
- Wire cutter
- Wire stripper
- Crimper
- Electrical connectors
- Speaker cable or similar cable 12-18 gauge
Be sure to DISCONNECT positive wire for the angel eye harness from the positive terminal under the hood BEFORE doing the wiring.
1. Cut positive cable between fuze and relay and strip ends
2. Route speaker wire into the cabin to where you want your switch to be and strip all four ends. Two ends by the drug bin strip and connect to the stripped ends of the positive wire from the angel eyes harness. The other two ends connect 14-16 wire gauge connectors that will go to the back of the toggle switch
3. Plug in wires to the switch and mount where you want it to be
4. Electrical tape all connections/waterproof and enjoy
Please wait for vid to finish uploading, I'm off to bed
Will move to lighting section after some exposure here. Thanks!
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 05-27-2014, 11:58 PM   #2
nissan00b
My Ride: 323 Ci
Nice video, I'm in the middle of doing the same thing myself. Looking forward to seeing the wiring solution for making the switch work with the remote function too.
nissan00b is offline   Reply With Quote
Old 05-28-2014, 12:02 AM   #3
JapanRot325ci
My Ride: 04 E46
im dying at the coolant bottle and oil bottle in your drug bin
great tutorial though. too bad i have mine hooked up to the interior
JapanRot325ci is offline   Reply With Quote
Old 05-28-2014, 12:17 AM   #4
1`
Banned User
My Ride: 330i
This is great buddy, thank you!
I could also use this method to install my dimmer switch
1` is offline   Reply With Quote
Old 05-28-2014, 12:22 AM   #5
1`
Banned User
My Ride: 330i
Originally Posted by JapanRot325ci View Post
im dying at the coolant bottle and oil bottle in your drug bin(
what's supposed to go there? can you put anything in there?
Old 07-03-2014, 04:46 PM   #6
myslow46
My Ride: e46
I'm following this guide but I'm afraid my switch will give, well since it's between the fuse and the relay, the fuse will go first.
I bought a 30 amp max switch with an LED. On the back it has an earth, load and supply terminals.
nvm
myslow46 is offline   Reply With Quote
Old 11-03-2014, 11:23 PM   #7
Dbills
My Ride: 99' 328i
If anyone is looking for a nice clean way to install the switches you can check out my thread here: http://forum.e46fanatics.com/showthread.php?t=1016151
Dbills is offline   Reply With Quote
Old 11-28-2014, 01:56 AM   #8
JapanRot325ci
My Ride: 04 E46
anyway to do it so that my outer rings only turns off and my inner one stays lite when i flick the button?
Old 11-29-2014, 06:28 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
A lot more complex because the rings are powered by the circuit board going to them. You'd have to run individual wires to those two rings and somehow wire it to work like I have. Honestly no idea, but tough.
Old 11-29-2014, 07:47 PM   #10
Gus330vrum
My Ride: 330ci
Jake what cell phone holder is that? Can you link me too it..
Gus330vrum is offline   Reply With Quote
Old 12-17-2014, 05:13 PM   #11
inline6bm
My Ride: 2002 325xi
Just ordered my angel angel eyes coming soon
inline6bm is offline   Reply With Quote
Old 12-18-2014, 06:27 AM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
Whoops sorry for the late reply. It's by iGrip from Germany. Amazon and ebay have them in various models
Awesome!
Old 12-25-2014, 02:05 AM   #13
Tchleung
My Ride: 02 M3
If I were to do this, I would instead having a long constant 12V power wire coming through the cabin and back. I would do this with ONE single wire from the relay ground. Bring the ground into the cabin switch, then a short ground from switch to inside car somewhere. Less wiring, less worries of live wires in car. Also doing so, when you have the switch off, this will 100% disable the angel eyes in both run mode and fad in/out.
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
456whp/312wtq @ 8psi, No #'s yet at 9psi
4.10 / Headers / ESS VT2-550+
Tchleung is offline   Reply With Quote
Old 03-02-2015, 12:42 PM   #14
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Bumping this. I like your idea as well. Ive been doing a ton of wiring switches into the ash tray for the demon eyes. You think running the ground through the switch and into the cigarette lighter would work?
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 03-02-2015, 01:24 PM   #15
Solidjake
Zero. Leaks.
Solidjake's Avatar
You can always run the ground wire to the shifter area (if you have an auto there is a torx bolt there or if you have a manual you can still put a bolt there as a ground)
Old 03-02-2015, 01:30 PM   #16
CarbonZHP
CarbonZHP's Avatar
Yeah that would be possible. Also Jake, do you know if there is a 12V constant somewhere inside the car? Like the center console or the glove box? Havent been able to find one
Modification Thread
Old 03-02-2015, 01:51 PM   #17
Solidjake
Zero. Leaks.
Solidjake's Avatar
Constant even for when the car is off? I'm curious about that as well.
Old 03-02-2015, 02:02 PM   #18
CarbonZHP
CarbonZHP's Avatar
Correct. As well as the kill switch, I've also been looking into a constant on switch for angel eyes. At meets when I want them to stay on I've been cracking the door and thats not the best solution.
Modification Thread
Old 03-02-2015, 02:09 PM   #19
Solidjake
Zero. Leaks.
Solidjake's Avatar
If I find out which wire is always hot I'll let you know. Not really sure which one it can be except maybe one to the radio or straight off the battery.
Old 03-02-2015, 02:15 PM   #20
CarbonZHP
CarbonZHP's Avatar
Straight battery was my thought. My thought though was that the angel eyes have two triggers. The ECU wire and the footwell light wire. If I were to connect one of these triggers to a constant 12V with a switch, closing the switch would send 12V to whichever source I chose. Obviously staying away from the ECU wire, I wonder if Id be able to send 12V to the footwell light without killing it. If necessary I have a 12V to 3.3V converter already
Modification Thread
