Sponsored by The Tire Rack
Old 07-13-2014, 06:16 PM   #1
serdar255
My Ride: '01 325ci / '90 325i
Exclamation Fitting 275 Square tires on my Non-M coupe
This past years I've logged a lot of autox hours and track time. I want to know what it would take for me to run 275 square tires on my non M coupe.
Currently I am running 255/35/18 Pilot Super Sports on my 18x8.5 et40 Enkei RPF1s and I feel that I still have a bit of room to play. Is it possible that I can fit 275s on an 18x9 (Dforce LTW5) or 18x9.5 (Apex ARC-8) with nothing more than a fender roll/cut? If not what would be required?
Thanks!
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 07-13-2014, 07:19 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Unfortunately you're in uncharted territory, I can't remember anyone running that size on a Non M. Hopefully I'm wrong & someone will speak up.
If you can make them fit, I have two other concerns:
1) Your current overall diameter is 25", this new size will be 25.6"; are you planning on a gear change ? because you'll need one.
2) Even though Tire Rack shows them as the same weight, I can assure you that the bigger tire weighs more, probably a 1/2 to 2/3 lbs more.
I'd try and figure out your current Exact tire & wheel weight, then compare it to your new proposed tire & wheel weight.
Sometimes the Cons equal or outweigh the Pros, meaning in this case it might not workout the way you think it will.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 07-13-2014, 09:38 PM   #3
serdar255
Good luck,
Rob43
I appreciate the insight.
By the looks of it the tire and wheel will be the same weight that i have currently because the tire is 2 lbs more but the wheel is about 2 lbs less.
As far as a gear change I was looking into a limited slip and with that I'd be willing to change ratio.
Old 07-13-2014, 10:08 PM   #4
Rob43
Rob43's Avatar
That's all good, but I want you to think about overall tire & wheel weight a different way.
1) If All (100%) of the un-sprung weight was located right around the wheel bearings, that would be the very best case scenario.
2) On the other hand, if All (100%) of the un-sprung weight was located on the tread surface that would be the worse case scenario.
In your case, your new setup is closer to scenario #2. It's good that the overall weight will remain the same, but it is a performance "Con" because you're now shifting that weight out to the tread surface.
EDIT: Don't make the mistake of buying a Helical LSD, you need a Clutch Pack.
Things to consider,
Rob43
Old 07-13-2014, 11:06 PM   #5
serdar255
Things to consider,
Rob43
Never thought of that... I appreciate the info and still have a lot to learn. So keep it coming!
Old 07-14-2014, 02:06 PM   #6
Minnoe07
My Ride: 2004 BMW 330Ci
I run r888's in 255/35/18 which are 10.236 inches in width.
A 275/35/18 super sport is only 10" wide according to tirerack website.
I use arc-8 18" wheels with no spacers. Rears were rolled for fitment and running -2.0 camber. No issues with front wheel fitment but I run -3.0 camber up front.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 07-17-2014, 06:15 PM   #7
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Seems like a hell of a lot of rubber for a little wheel. I have 255 on my rear 10.5 wheel. About 8 hours of rolling and grinding/cambering just to make it rub a little less. A 275 won't look great on a 9 in my opinion. Not to mention your car has absolutely no use for a 275 section. We have 235 horsepower. 255 tire is plenty. If you want better grip, don't get wider. Get a better tire.
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is online now   Reply With Quote
Old 07-17-2014, 07:06 PM   #8
Mlust
My Ride: ///M3, Audi S5
tire size and spacer question. clearance issue
edited...meant to make a thread.
Mlust is offline   Reply With Quote
Old 07-17-2014, 07:20 PM   #9
CarbonZHP
CarbonZHP's Avatar
Thread jack. And roll the fenders. You'll be fine
Modification Thread
Old 07-17-2014, 07:56 PM   #10
Minnoe07
255 is recommended for an 8.5 in wide tire and comes that way from BMW.
255 on a 10.5 is a bit of a stretch.
Old 07-17-2014, 08:31 PM   #11
CarbonZHP
CarbonZHP's Avatar
I know it is. Rubbed extrmely with a 265
Modification Thread
Old 07-18-2014, 12:36 AM   #12
SoCaLe39
My Ride: 06 M5 & 03 325i
Personally I'd just pickup a good, lightweight set of 17" wheels with track tires (255 square setup) and call it done. I doubt the 275 width would be worth the hassle or additional weight.
SoCaLe39 is offline   Reply With Quote
Old 07-18-2014, 12:37 AM   #13
CarbonZHP
CarbonZHP's Avatar
Well said
Modification Thread
