E46 Convertible
Old 07-17-2014, 08:57 AM   #1
iDc
My Ride: E46 M3
Removing convertible completely?
Hi.
Has anyone removed their convertible top completely and used only a hardtop?
How much does the motor/soft top combination weigh?
To my understanding, convertible has some extra frame reinforcement, so I imagine the soft top and motor assembly only weighing about 150 lbs.
iDc is offline   Reply With Quote
Old 07-17-2014, 08:58 AM   #2
iDc
My Ride: E46 M3
I forgot to add that I am only asking because I didn't know only hardtops were allowed for HPDE. I have a corvette I can use but wanted to track the M3.
Old 07-17-2014, 12:02 PM   #3
taylor192
My Ride: 2003.5 M3
Search, it's been discussed. The soft top is the mounting point for the hard top, so you cannot remove one and install the other without fabricating brackets.
Old 07-17-2014, 12:19 PM   #4
unevolved
My Ride: 2003 325i
A "hardtop" will not provide any additional safety for an HPDE. Some groups may allow it, but common sense should still dictate you install a good aftermarket roll bar. Any hardtop I've ever seen would crumple like a soda can if a car was dropped on top of it.
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 07-18-2014, 01:08 AM   #5
beeemerdude
Banned User
My Ride: Cabrio. Stick.
track a convertible. ?? dumb idea is dumb. (I don't know how to be any more politically correct than that.)
beeemerdude is offline   Reply With Quote
Old 07-18-2014, 01:18 AM   #6
iDc
My Ride: E46 M3
Understood. I actually looked at most of the roll bar set up but I don't want to have a roll bar on my street driven car.
beemerdude, I don't think its dumb. Look at all the miatas at the tracks.
Guess my z06 will be used again for my next track day
Old 07-18-2014, 02:43 AM   #7
taylor192
My Ride: 2003.5 M3
Dumb comment. Anyone that's been to a track knows Miatas are common, and perform well.
Old 07-18-2014, 08:33 AM   #8
unevolved
My Ride: 2003 325i
Not saying you're wrong, but what's your reasoning for that? A 4-point roll bar behind the occupants isn't unsafe like driving around with a 6- or 8-point cage would be.
Old 07-19-2014, 02:04 AM   #9
iDc
My Ride: E46 M3
My reason- on the tracks I'll have racing harness (4 point, 6 point, 8 point, 1000 point, I'd have harness on) on the street, harnesses are a pain in the arse. But some roll bar options seems to be away from the head .
Old 07-19-2014, 10:14 AM   #10
unevolved
My Ride: 2003 325i
Oh ok, that's a personal preference?
Old 07-19-2014, 01:43 PM   #11
iDc
My Ride: E46 M3
Sort of, yes. Mainly because of stories i have heard of roll bar plus head injuries during accidents or crash
Old 07-19-2014, 02:09 PM   #12
dwtaylorpdx
My Ride: 2005 330xi
Good friend of mine and his passenger died from head injuries when he was crossing a side hill at about 5 mph and rolled 3 times down the hill.
Non padded roll bar in a jeep.
Another friend had a MGB with a roll bar and got rear ended, he survived but his skull sets off metal detectors at the airport now.. Another un-padded rollbar.
Miata's are kind of the exception, if you use a 4 point hoop its behind you far enough that the seat has to collapse for you to hit it.. Which can happen if you back it in to the wall hard enough..
Another hazard when tracking street cars is the seat frame, most are tubular steal which can break and jab you in an impact. AL or composite seat buckets are the way to go for on track.
Be safe..
Dave Taylor
Pacific North West
dwtaylorpdx is offline   Reply With Quote
Old 07-19-2014, 05:01 PM   #13
beeemerdude
Banned User
re: above post. I accept your belated apology.
Old 07-19-2014, 05:35 PM   #14
unevolved
My Ride: 2003 325i
Yeah, I don't know why proper SFI padding isn't required for track days. But that's not a convertible thing, that's a roll bar thing.
That's an interesting thought on the seats, kind of goes against conventional wisdom that a street seat will collapse and help prevent injury as your three-point belt allows you to slide sideways... But that's more about properly pairing seats and harnesses.
Old 07-19-2014, 05:57 PM   #15
dknightd
My Ride: 2002 330 cic
I don't know the rules for the racing/training you want to do.
Does a removable hardtop even count? I suspect it would have to be real hard top,
and/or roll bar. I might be wrong, but I don't think the removable hardtop
really adds any safety to the bmw vert. It is mostly a decoration/comfort thing.
For safety you are relying on the strong window frame, and the pop up roll bars.
What do miata's have to do to play in the things you want to try?
If you want to track you M3, which sounds like a lot of fun, you really have to consider
two things. What makes you feel safe, and, what do the rules require.
If the removable hard top makes both you and them happy, then give it a go.
If it makes you happy, then worry about making custom mounts to allow you
to remove the softtop to save weight. Before I did that I'd buy a new car
for racing. It seems a shame not to be able drop the top on a convertible.
I do wonder what a Miata has to do to qualify.
dknightd is offline   Reply With Quote
Old 07-19-2014, 06:57 PM   #16
taylor192
My Ride: 2003.5 M3
Nope, still dumb. Stories of rolling a jeep aren't applicable to a low sports car.
Old 07-19-2014, 06:59 PM   #17
taylor192
My Ride: 2003.5 M3
Exactly.
Plus, on the track you'll have a helmet.
Old 07-20-2014, 01:34 PM   #18
unevolved
My Ride: 2003 325i
For any DEs I'm aware of, Miatas have to have a rollbar or hardtop. It doesn't make sense, but there you go.
