E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 02-25-2014, 02:53 PM   #21
gamefacenyc
Account Under Review
My Ride: bmw/others
car is of the road in my garage so id figured this is the best time to fix it. top works manually/no leaks/motorpump has full oil in it and turns on when car battery is re connected but the car does nothing when the the top up/down buttons are pressed..
gamefacenyc is offline   Reply With Quote
Old 02-25-2014, 03:01 PM   #22
gamefacenyc
My Ride: bmw/others
Originally Posted by taylor192 View Post
Did you visibly check them? or electrically test them?
If you didn't electrically test them, go do it. Wires can break internally, or at different bends. The first bend above the drivers seat is the most common bend, yet not the only bend the wires break.
Alternatively get the codes get by a shop. A blinking light means a code is stored, it is unlikely to be a fuse. If you want to check fuses, the fuse panel has a guide indicating all the fuses for the top.
thanks on the help,
i visibly checked the whole car/ took the whole trunk panels and left rear panels off.
anyhow i forgot to mention that my rear defrost is not working {just here a click sound when pressed} and saw from the other ad that it could be one of the 3 electromag sensors? anyone has a pic of them/location?
Old 02-25-2014, 03:49 PM   #23
taylor192
My Ride: 2003.5 M3
Originally Posted by gamefacenyc View Post
thanks on the help,
Visibly checking is NOT enough. Perform the electrical troubleshooting in the sticky, or take it to a shop to get the codes read, or keep guessing at what the problem is and throw parts at it.
It "could" be anything. This is why you need to read the codes or do some electrical troubleshooting. Anything else is just a guess.
Old 02-25-2014, 04:08 PM   #24
gamefacenyc
My Ride: bmw/others
yeah just replied back to you on the other post. thanks on the help
Old 02-25-2014, 06:57 PM   #25
Kay D Boss
My top does the same thing. 1800$ diagnosis at clear lake bmw and they couldn't figure it out. Good luck!
Kay D Boss is offline   Reply With Quote
Old 06-03-2014, 02:30 PM   #26
jgriffi1
My Ride: 2002 M3 convertible
Thank you, Thank you, Thank you!!! Had the same issue and found your DIY and fixed the problem in 15 minutes. The green wire had broken in mine. Spliced in a new wire and it's good as new (ha!).
jgriffi1 is offline   Reply With Quote
Old 06-11-2014, 05:22 PM   #27
ajullie2
My Ride: BMW 330CiSport 2004
Thank you for this post. I've been trouble shooting my '04 330 hood for the last 2 evenings, it was opening normally and then stopping at the point the lid should have opened. I started looking thru for issues, checked hydraulic fluid level, checked latch mechanism (under rear seats) and could not find any issue. I tried to close the roof tonight and it wouldn't (where it would previously), I.e. the problem had got a little worse. It occurred to me that the battery level may have dropped and was now preventing full closing. I started the engine, blipped (get alternator kicked in) and roof would close. To my surprise, the damn thing would now fully open and close (with the engine running and alternator kicked in). I suspect battery is on the way out, and will look to replace. Voltage without alternator was around 12v, with alternator around 14v. This post was really useful. Thank you.
ajullie2 is offline   Reply With Quote
Old 06-27-2014, 12:59 AM   #28
fletch00
My Ride: 2004 330Ci
Spliced broken wire - SOLVED!!
Thanks so much ! This thread (and great pics) solved my issue:
http://forum.e46fanatics.com/showthread.php?t=790169
I just did this repair in 1hr on my 2004 330Ci and the top is again fully functional.
Yesterday the top stopped closing - going about 3/4 of the way then stopping.
Funny story: While slicing open the black braided wire bundle and prying the bundle out of the fasteners on either side of the "pinch point" I managed to slice the tip of my finger - it was bleeding a good rate
But then I remembered the first aid kit in the trunk - so I manually lower the top one handed and wrap up the wound to continue.
I found one of the 4 smaller gauge wires completely severed and the others frayed with copper exposed! (now I know why it stopped 3/4 - exactly when those wires extend)
I use the (perfectly suited and SAFE surgical scissors from the first aid kit to snip the braiding to get ready to splice a 3 inch piece of wire scavenged from an old AC adapter into the severed wire and use the trimmed band-aids from the first aid kit to wrap all the repairs and frayed wires.
I manually fold the top down then start the car and press the close button - closed all the way - SUCCESS!
Thanks again!
Lesson for me: When trying amateur repairs the best tools may be found in a first aid kit !!
fletch00 is offline   Reply With Quote
Old 07-09-2014, 07:13 AM   #29
rsimon
My Ride: E46 Convertible
Just a THANK YOU!
Hey, reading your story and following the troubleshooting helped me to find this broken cable issue on my E46 325Ci! Thank you, and greetings from Hungary!
Robert
rsimon is offline   Reply With Quote
Old 07-20-2014, 05:15 PM   #30
BimmerTex
My Ride: '07 550i, '05 325Ci
Same problem...
Thanks fmzip, Taylor, and others. Same symptoms as others...and reluctantly decided to check for wire issues. The braid looked fine, but...
I cut open the braid right at the exact same spot. To my delight I found the green/white wire cut all the way through. (will post a pic if I can) I'm not sure how it worked at all - must have been making minimal contact for some portion of the cycle.
Anyway, a nice splice with shrink tubing, and electrical tape and its works well again.
Thanks again...I never would have done this myself without the guidance and pics.
BimmerTex is offline   Reply With Quote
Old 08-06-2014, 06:37 AM   #31
Thess
My Ride: 2003 320 Cic
Hello gents,
Last Sunday, for the first time I had issues with my soft top.
This is how far it would go: https://www.dropbox.com/s/dhabzq4zyd...2020.52.49.jpg
After few tries I managed to get to this point (back of the top raised a bit as well but not much): https://www.dropbox.com/s/2o9woo741d...2020.46.38.jpg
Here's my hydro pump: https://www.dropbox.com/s/mpoxtenszb...2020.58.27.jpg <--- question about that is, which circle marks the top up plug? Is it the red one?
I read the errors from CVM:
1. http://imageshack.com/f/f0gwciYsp
2. http://imageshack.com/f/p7asQwUHp
Wire harness at the critical point looks intact, should it be my next step to cut it and check inside?
The mechanism does make a sound like its struggling with the roof - and it takes longer than usual (even to raise it a lil' bit).
I have got Aral Vitamol fluid for the pump just in case...
I'm not sure how to manually lower the top...
Any advise?
Thanks!
Thess is offline   Reply With Quote
Old 08-06-2014, 01:05 PM   #32
taylor192
My Ride: 2003.5 M3
Originally Posted by Thess View Post
Hello gents,
Any advise?
Thanks!
Your next step should be to read the electrical troubleshooting sticky in more detail.
Error 18 and 19 indicate a wire is broken. Follow the sticky to electrically test the CVM plug, you do NOT need to cut open wires to do this. Visual checking is NOT enough.
Your pump level looks fine, it should only be within the circle with the top fully open, and below the circle with the top closed.
RTFM to manipulate the soft top manually, or search this forum.
Old 08-07-2014, 01:51 PM   #33
Thess
Thanks taylor192.
Did as you suggested. Here's what I found.
After lowering the top manually, fluid level in hydraulic tank is in the middle of the circle - what means its alright.
Stripped rear left side of the car for CVM.
So all the pairs are showing continuity... But there's a problem with triplets.
I couldn't get any two of the triplets to show continuity - tried all the combinations.
Any suggestions for the next step?
Old 08-07-2014, 02:11 PM   #34
taylor192
My Ride: 2003.5 M3
Thanks taylor192.
Option 1: Keep poking around
Test continuity from the plug to the wire past the bend where the wires typically break. Start with the wires that are colour coded with the triplets you couldn't test.
If your leads are not long enough to test from plug to bend, get some wire to devise an extension.
Hopefully you are testing continuity with the roof in the bad position. You might get false positives with the roof in other positions.
Option 2: Brute force
Cut every wire before/after the "first bend" and splice in new wire. I couldn't be bothered with trying to trace which wire was broken, so I just spliced them all. You will want to solder and heatshrink the splices, there are too many wires to use butt connectors, they won't fit.
If one broke, likely others are not far behind. Consider it preventative maintenance.
Old 07-05-2015, 11:34 PM   #35
klixtokw
My Ride: bmw 325 ci
Originally Posted by fmzip View Post
I did that.....
they stickied another thread instead but no one reads that one either:
http://forum.e46fanatics.com/showthread.php?t=854059
Where is the consolidated thread with all top problems you did?
klixtokw is offline   Reply With Quote
Old 07-06-2015, 03:49 AM   #36
Thess
BTW, eventually I have sorted out my roof issue and...
...it was a faulty hydraulic pump. (got used one off eBay > replaced > problem solved!)
Old 07-06-2015, 12:02 PM   #37
klixtokw
My Ride: bmw 325 ci
You did not indicate where is the thread you did with all the top problems?
Do you have any pics or a video of how you changed the hydro? Or where you got the knowledge to do this?
Old 08-24-2016, 06:36 PM   #38
owl1979
My Ride: Mini Cooper
Hi Everyone. New to the E46/M3 arena with a 2003 that I picked up a few weeks ago. The convertible top worked for a few tries and now no longer works. It opens to about 3/4 of the way down, so my symptoms sound similar to what I hear going on in this forum.
Does anyone have a DIY or pictures of what to look for and where on the soft top as well as the best position to put the top to access all of the different harnesses and modules? (The pictures in post #1 are not showing for me.)
owl1979 is offline   Reply With Quote
Old 08-24-2016, 07:07 PM   #39
taylor192
My Ride: 2003.5 M3
Review the READ ME threads, in particular the Start Here READ ME.
Old 08-25-2016, 02:15 AM   #40
owl1979
Thanks for the reply. Read the Read Me articles but did not see the answer regarding missing pictures from Post #1.
I found several other threads earlier today about the convertible top, but none had good, clear pictures of the OPs scenario, which sounds most similar to what I have. I'll just use the Convertible Top Info document to find what I need.
