Old 03-03-2013, 12:00 PM   #1
csa714
My Ride: 2004 330cic
Windshield Cowl (pressure nut) Help
Hi All -
I have the DIY for the removal and install of the part - but I am being foiled by the pressure nut holding the wiper arm. All of the DIY's I've seen say just play with the arm a bit and the pressure nut will come out - however i just read another that said a PULLER may be necessary.
Q1 - Is there a certain type of puller that is recommended?
Q2 - Are there any other ways - trying to work a small flathead around it for example (although I tried and it does not budge.
The DIY is fairly simple - I just need to get the @#%@% pressure nut out of there!
Thanks.
csa714 is offline   Reply With Quote
Old 03-03-2013, 12:05 PM   #2
stevenluczynski
My Ride: Is Steel Blue
press down on the wiper arm a couple of times, thats what worked for me
stevenluczynski is offline   Reply With Quote
Old 03-03-2013, 01:07 PM   #3
csa714
still stubborn as can be - if I have to get the tool - easy cheap autozone tool or other?
Old 03-03-2013, 01:16 PM   #4
stevenluczynski
you can rent it from auto zone. So you took the nut off and wiggled it and still wont come off?
Old 03-03-2013, 03:30 PM   #5
csa714
No, very very stubborn. Such an easy project....never is.Arrrghhh!
Old 03-03-2013, 03:55 PM   #6
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Just wiggle the ARM right to left. Everyone I have taken off loosen right up like that. After first time off they are much easier.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 07-16-2014, 06:58 AM   #7
thomthod_330
My Ride: 330ci convertible
I used a little screwdriver and hammer and worked around and kept wittling it up out of the hole. It was hammered in there!
thomthod_330 is offline   Reply With Quote
Old 07-16-2014, 10:37 PM   #8
hitbyastick
My Ride: 2002 325i
Spray some penetrating oil on it. Should come off with some gentle pressure/wiggling after that.
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 07-21-2014, 06:18 AM   #9
TitanSilverE46
My Ride: 2001 318i & 325i
A little WD40 (penetrating oil) is good.
Then I purchased a little puller sold as a battery terminal puller.
Worked a dream.
TitanSilverE46 is offline   Reply With Quote
Old 07-21-2014, 07:55 AM   #10
tcphoto
My Ride: E92 335 MT Coupe
I concur with TitanSilverE46, the battery terminal puller worked for me when I replaced my windshield cowl. I bought mine at O'Reilly's.
tcphoto is offline   Reply With Quote
