Thread Tools Search this Thread Rating: Thread Rating: 61 votes, 4.97 average. Display Modes
Old 03-20-2014, 03:50 PM   #881
Kayss
My Ride: Bmw 328i 1999
Originally Posted by XKR View Post
It could also be a temperature issue. I retrofitted HIDs into my foglights and when we had very cold weather, one of them wouldn't turn on unless I turned them off and turned them back on. Your right bulb looks very dim. My AE have vert sturdy clips that clip on to the housing so since yours seem cheap, they may be finished since the clip may be broken. I doubt that water is getting into your headlights because in the back of them, they have a weather resistant rubber grommet that protects everything. It could honestly be anything so I hope someone else could chime in since these lights could be complicated. If you do tear down your lights and have to replace a projector, I suggest doing a clear lens retrofit because that would improve your lights so much. If it is retrofitted then check your harness because the relays could be bad. flickering on warm up is normal (for retrofitted xenons) so it may be something you might have to live with. I had this problem with me older car and it had a tiny battery so I had to replace the alternator because it needed a lot of power. So yea check your relay harness!
that adjusts your projector level
I dont think its ever auto adjusted in my ownership (purchased in september) so maybe not the weather but my angel eyes deffienetly dont turn on when I unlock the car like they usually do only because its cold. How do I find the relay? I searched but couldent find anybody talking about their locations and what they look like and being very new to this I have no clue where they could be. And I got a picture when I came in of the loose connection Click image for larger version
Any clue where this belongs? I think it could be my problem unless this is for the headlight washers.
Sent from my SGH-I337M using BimmerApp mobile app
Kayss is offline   Reply With Quote
Old 05-28-2014, 02:38 AM   #882
lasonrodd
My Ride: M3
Wow, I really like the chrome ones. But the 6k type lights are pretty high on price.
lasonrodd is offline   Reply With Quote
Old 07-17-2014, 07:46 AM   #883
blakxr
My Ride: 2001 325i
Hi , I've looked through this thread and I can't seem to find anything on fitting angel eyes to a prefacelift sedan with after market projectors fitted. My lights were halogen and terrible. My high and low beam shrouds are 146mm wide. I cannot seem to find angel eyes in the configuration. Does anyone know where I can purchase some?
blakxr is offline   Reply With Quote
Old 07-17-2014, 09:52 AM   #884
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
I have a preface sedan with aftermarket projectors. Get the angel eyes from umnitza. That's where I got mine and they work brilliantly.
lllRazorlll is online now   Reply With Quote
Old 07-17-2014, 11:21 AM   #885
blakxr
My Ride: 2001 325i
Yeah but in the sizes I need???
Old 07-17-2014, 11:31 AM   #886
lllRazorlll
Modded ///Member
My Ride: '00 328i
I think there's an option to specify exactly which ones you need. Just check it out
Old 07-18-2014, 01:52 PM   #887
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
Before you buy a set of angel eyes, ask your vendor if their angel eyes will stand up to this (Umnitza Orion V4 E60 Install):
Old 07-24-2014, 03:26 PM   #888
Savaged
Slowly working my way through this thread, but haven't seen exactly what I'm looking for yet.
Anyone have V2's 4300k, oem halogens, amber corners?
Savaged is offline   Reply With Quote
Old 10-24-2014, 11:08 AM   #889
kw930
My Ride: BMW E46 320i
Originally Posted by AxwelF View Post
This is not a pic, but I have a question which I dont feel deserve its own thread...
Im looking to buy AEs for my 2001 330ci coupe with OEM projector/xenon headlights. However, since i live in Sweden its going to be expensive to buy from umnitza... So my only alternative is ebay. However, its really hard to find a kit where the seller is clearly states whats included and for what specific type of headlights etc it is.
http://www.ebay.co.uk/itm/66-LED-SMD...item4179b0a319
Found these. Seller states it will fit the following:
BMW 3 Series E46 2D 1998-2003 (Pre-facelift)
BMW 3 Series E46 4D/5D 1998-2004 with projector lens 131mm x 4 ( 66 led each ring )
BMW 3 Series E46 2D/4D/5D 1998-2004 without projector lens 131mm x 2 ( 66 led each ring ) / 145mm x 2 ( 76 led each ring )
So first of it seems like it should fit. Then on the last line he says E46 2D without projector? Is the size of the rings the same for projector and non-projector? The seller is so inconsistent, mentioning different sizes for projector/non projector for some cars, and others not? Also, theres no clear statement on whether a harness for fade in/out functions is included. Almost every single seller is just as unclear in the description...
Im so confused haha... Any help would be appreciated!
Hi, wonder have you already got your answer of the correct size of AE to fit into your car?
I have the same issue of choosing the correct AE ring sizes for my E46 320i 4D sedan that come with factory equipped single HID projector light. I searched through eBay and found that most of the recommendation is getting 4x 131mm ring sizes AE. However, when I browse through this forum, which a group of owner are actually fitting 2 big (146mm) + 2 small (131mm) AE ring size (suppose to be used for halogen, non projector headlight) into the same model :
http://www.bmwclubmalaysia.com/newfo...-6#entry456872
So, now I'm getting confuse whether to get all 4x131mm rind size or 2big+2small ring sizes AE
Any owner has AE installed can share your experience & opinion?_nr_
kw930 is offline   Reply With Quote
Old 10-26-2014, 10:31 PM   #890
kw930
Deleted
Old 10-27-2014, 11:50 AM   #891
umnitza
8774866489
umnitza's Avatar
Most of the sellers don't actually build their own, they are just reselling the latest China build.
Look at our site, you'll find the correct spec rings - www.umnitza.com
You also don't have to go far to see some of our angel eyes in action on this thread, just go back through it
Old 10-29-2014, 12:16 PM   #892
kw930
Thanks for the feedback and advice.
Well,my situation now is I've bought a set of AE from eBay seller with the recommendation of 4x131mm ring size, I've yet install it and found other forum mentioning the correct size for my light should be 2 big (146mm) + 2 small (131mm). That's why need to seek more advice and experience sharing here.
Old 10-29-2014, 04:12 PM   #893
kplaten
My Ride: 2004 325CiC
Umnitza Orion V2.5 AE's in my 2004 325Ci convertible:
I had some issues, read more here: http://forum.e46fanatics.com/showthread.php?t=1054987
kplaten is offline   Reply With Quote
Old 11-03-2014, 01:56 PM   #894
kplaten
Umnitza Orion V2.5. New money shot... :-)
Old 11-03-2014, 01:57 PM   #895
umnitza
8774866489
umnitza's Avatar
OV2.5 look great!
Old 12-25-2014, 02:09 AM   #896
lkptpete
My Ride: 2002 E46 M3 Coupe
From bmwled
lkptpete is offline   Reply With Quote
Old 12-28-2014, 02:12 PM   #897
Carlos323ci
My Ride: Bmw 323ci 2000
Carlos323ci is offline   Reply With Quote
Old 12-28-2014, 03:18 PM   #898
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
^ Watch out, blue lights are illegal in most state.
Old 12-28-2014, 03:26 PM   #899
XKR
My Ride: 2001 M3 Convertible
+1
Ask me how I know
Blue lights belong on hondas anyway.
~SGT catless headers|Full BW 3.5" Resonated Race Exhaust w/ diffuser | Epic Motorsports Race Tune | BAC Filter | BW Intake Elbow
~Tein S-Tech Lowering Springs | Sebion CF hood | CF Kidneys | mnitiza Predator Orion V4
XKR is offline   Reply With Quote
Old 01-03-2015, 06:36 PM   #900
Imola.ZHP
My Ride: Imola ZHP
Installed February of 2010, still looking good!
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
